Problems with R8 collets
IanH | 30/07/2020 14:41:51 |
![]() 129 forum posts 72 photos | I need to make a piece of tooling involving some odd sized small holes. I could bore one of them, but the other two are a bit small, so I decided to head off down the home made D bit route. I carefully made 2 of the three D bits required on opposite ends of a piece of silver steel, then hardened and tempered them. I set the silver steel up in the 4 jaw and clocked it up before turning the required diameters so all nice and concentric. Transferring the finished tool to the Bridgeport, I mounted it in an R8 collet and drilled a test hole. It drilled fine, but I was disappointed to find the resulting hole oversize! I had a think and decided to measure the run out of the tool in the collet - TIR 5 thou. I took the collet out and measured the spindle run out - bob on as it should be. I cleaned everything up and put the collet and tool back in the spindle and same result TIR 5 thou. My conclusion is that it is the run out that is causing the oversize holes. These are typical R8 collets and not the rather more expensive high precision collets that can be bought. I have got into the habit of running milling cutters in these R8 collets rather than the Osborne collet chuck, partly for reasons of rigidity and partly because not all my cutters are of the screwed shank type. So.....should I invest in the high precision R8 collets, or should I go for one of the ER types that seem popular with folk on this forum. If ER, which one and what source to get decent precision? Ian |
John Haine | 30/07/2020 14:50:05 |
5563 forum posts 322 photos | I don't think you will find the usual ER collets any better unless you buy the expensive ones such as Regofix, with the chuck to match. Maybe just buy one expensive R8 for the size you want? Maybe the steel distorted on hardening? |
Emgee | 30/07/2020 14:50:25 |
2610 forum posts 312 photos | Hi Ian If you want to hold a range of sizes you need a good quality R8 to ER chuck to ensure utmost accuracy, any run-out within the chuck will never be corrected by high class collets. Emgee |
Henry Brown | 30/07/2020 15:20:13 |
![]() 618 forum posts 122 photos | I've bought a couple of replacement R8 collets from Gloster tooling on ebay (but they do have a website) to replace the most eccentric of the ones I got in an Axminster set with my mill. Very impressed with them... |
Clive Brown 1 | 30/07/2020 15:27:02 |
1050 forum posts 56 photos | 5 thou. run-out seems a lot even for the type of stuff I favour buying. |
JasonB | 30/07/2020 16:26:06 |
![]() 25215 forum posts 3105 photos 1 articles | Are you measuring the 5 thou runout at the shank of the tool or the cutting edge, quite possible it distorted when quenching. My "typical R8 collets from ARC give half a thou or less. |
IanH | 30/07/2020 17:03:21 |
![]() 129 forum posts 72 photos | Ah ha! Swapped out my D bit for a commercial milling cutter and clocked that - spot on near as makes no difference. The problem is my D bit. Sighting down the length of it (approx 2" Time to start again I think. Any hints on keeping it straight during heat treatment? Ian |
Dave Halford | 30/07/2020 17:18:09 |
2536 forum posts 24 photos | quench it vertically. |
Neil Lickfold | 31/07/2020 10:53:37 |
1025 forum posts 204 photos | Seen as you are making it from silver steel, it needs to be annealed before the final shaping and hardening and grinding.. |
Rod Renshaw | 31/07/2020 11:26:47 |
438 forum posts 2 photos | I have found it best to harden and temper while the blank is still symmetrical, and quench vertically as suggested by Dave, then check it is hard and straight. Then rough grind the flat on the off-hand grinder if nothing better is available Then finish the flat with a diamond file while supporting the blank in a rough vee groove in a piece of hardwood held in the vice. The blank rotates slightly in the groove under the pressure of the file and the flat comes out better than one might think. Check progress with a mic. Rod
Rod Renshaw | 31/07/2020 11:29:34 |
438 forum posts 2 photos | Add : could use a flat oilstone instead of a diamond file. Rod Edited By Rod Renshaw on 31/07/2020 11:30:35 |
Maurice | 31/07/2020 11:37:21 |
469 forum posts 50 photos | When you file or mill away the steel to produce the flat, make sure to finish it a few thou over half the diameter, or the "side" will have a cutting edge, and will remove material fro the side of the hole. Maurice Cox |
