john barnes 4 | 15/07/2020 21:29:13 |
32 forum posts 3 photos | Hi all, I need a couple of gears for my Boxford model A gearbox. I have identified them as 16dp using the formula - number of teeth plus 2 divided by diameter. Can anyone confirm that is correct. Also does anyone know the pressure angle.
larneyin | 15/07/2020 23:48:03 |
17 forum posts 19 photos | I think the gears are 18 D.P. with a 14.5-degree pressure angle and 0.125" depth of tooth. They are 3/8" wide, have a 9/16" bore, and have a 1/8" keyway. I stand to be corrected on this and suggest you wait for others to confirm, or otherwise |
larneyin | 15/07/2020 23:50:34 |
17 forum posts 19 photos | Oops! On re-reading the post I see it is the gearbox gears you need the info for, not the change gears. Sorry for for not reading the original post correctly |
larry phelan 1 | 16/07/2020 08:26:05 |
1346 forum posts 15 photos | You know what they say "Read twice, comment once" or something like that !! No offence intended, Larneyin, just could not resist it ??? |
Bazyle | 16/07/2020 08:45:01 |
![]() 6956 forum posts 229 photos | The normal changewheels are 18DP, the back gear cogs are 16DP but I've no idea what the ones internal to the gearbox are. If you have it apart try running a gear with the ones mentioned above and it should confirm either way. |
Brian Wood | 16/07/2020 09:18:13 |
2742 forum posts 39 photos | If it's any help, when I overhauled my Smart and Brown Sabel on purchase, [their clone of the Southbend lathe], the gears in the gearbox were all 16 DP and at that age they would be 14.5 degree pressure angle. I imagine Boxford followed the design in that respect as well. Regards Brian Edited By Brian Wood on 16/07/2020 09:18:28 |
larneyin | 16/07/2020 09:22:09 |
17 forum posts 19 photos | Larry Fair comment - I can only plead advancing (even advanced) years in mitigation
Tommy |
William Chitham | 16/07/2020 09:35:54 |
156 forum posts 56 photos | There was a thread on this topic recently: **LINK** William. |
larry phelan 1 | 16/07/2020 14:32:41 |
1346 forum posts 15 photos | Hi Larneyin, Welcome to the club. The older you get, the worse it gets, trust me !, I ,m well advanced at this stage. I need to keep two pairs of reading glasses around all the time, to be sure of finding at least one set when required, and I,m only 82 and a bit ! I hate to think what I,ll be like when I get REALLY OLD !!! |
john barnes 4 | 16/07/2020 17:42:34 |
32 forum posts 3 photos | Thanks for all the replies guys. I know the gearbox gears are definitely not 18dp because they would not mesh with my change gears when I stripped the gearbox last weekend. Unfortunately I can not try them with my back gears as Bazyle suggested because the gearbox is now reassembled and re fitted. I assumed the back gears were the same as the change gears. I am leaning towards 16dp and 14.5 degree pressure angle. I am going to try Williams link to confirm pressure angle. If I am correct does that mean I can use Myford gears. I know they will need to be adapted but they seem more readily available and much cheaper. |
Brian Wood | 16/07/2020 18:21:04 |
2742 forum posts 39 photos | John, Myford gears are 20 DP so they will definitely not mesh with the 16 DP gearbox gears. Regards Brian |
john barnes 4 | 16/07/2020 19:21:36 |
32 forum posts 3 photos | Thanks for that info Brian. I have had a quick look for the gears that I think I need. One in particular seems very uncommon. It may be cheaper and quicker to make my own. |
not done it yet | 16/07/2020 23:31:00 |
7517 forum posts 20 photos | Raglan and Drummond, amongst others, used 16DP with 14.5 PA change wheels. Presumably they would need keyways cutting, if hard enough. Both were 16mm bore and 3/8” thick, I think. Give us a clue of tooth count required? And any other pertinent detals. Edited By not done it yet on 16/07/2020 23:31:46 |
Keith Long | 16/07/2020 23:40:26 |
883 forum posts 11 photos | Posted by not done it yet on 16/07/2020 23:31:00:
.........Drummond, amongst others, used 16DP with 14.5 PA change wheels. No, Drummond used 14DP with 14.5 deg PA. |
john barnes 4 | 17/07/2020 18:00:21 |
32 forum posts 3 photos | I have been searching for gears using Boxford as a keyword but I am going to omit Boxford from my searches from now on just in case there is another maker such as Raglan or Drummond using 16dp gears. The gear I want to replace is a 16 tooth / 32 tooth combination. I also have a couple of 32 tooth gears showing signs of wear which I will change if I can find them cheap enough or can find the cutters I need to make them. The gearbox was dismantled and all gears cleaned and deburred where necessary, oiled and replaced. It is working better than it was but when the 16 / 32 combination is selected it sounds noisy and feels rough. I wish I had taken pictures of the strip down so you could see the damage but it did not occur to me. |
Brian Wood | 18/07/2020 08:59:07 |
2742 forum posts 39 photos | Hello John, Here's a suggestion. There are two combination gears [16/32 teeth] in the doubling gearing part of the gearbox. The noisy one has perhaps had a lot of use and you could perhaps put off the day when action has to be taken by swapping them over Regards Brian |
john barnes 4 | 18/07/2020 11:25:30 |
32 forum posts 3 photos | Hi Brian, I am not absolutely sure but I think one pair of gears is keyed and the other pair not. I tend to avoid using the bad gear unless I need it for screwcutting. John |
Brian Wood | 18/07/2020 16:32:19 |
2742 forum posts 39 photos | Hello John, You could well be right, it is several years since I rebuilt the Sabel gearbox and I could easily have forgotten that small but important detail. Sorry if I have raised your hopes prematurely Regards Brian |
john barnes 4 | 18/07/2020 19:39:50 |
32 forum posts 3 photos | No need to apologise Brian I welcome your input. John |
