celso ari schlichting | 10/07/2020 21:44:08 |
![]() 145 forum posts | how i make this simple tongs: https://youtu.be/O1FS9KktKH4 Greetings from Brazil |
IanT | 11/07/2020 10:16:10 |
2147 forum posts 222 photos | I liked the small welded fabrication aspect Celso, simple MMA and it looked vey good after grinding. The oil quench was a bit hairy - definitely an outside job. A well made and useful Blacksmiths tool though. Well done and thank you for sharing! Regards, IanT
Grizzly bear | 11/07/2020 18:50:34 |
337 forum posts 8 photos | Very good, you made it look easy. But many operations. I too liked the pivot. Do you read the English OK, or do you translate? Regards, Bear.. |
celso ari schlichting | 11/07/2020 21:18:08 |
![]() 145 forum posts | Posted by IanT on 11/07/2020 10:16:10:
Thanks Ian...Regards from Brazil
celso ari schlichting | 11/07/2020 21:22:41 |
![]() 145 forum posts | Posted by Grizzly bear on 11/07/2020 18:50:34:
Dear friend Bear, I understand a little English, I get a little confused when people
use slang or very technical or specific words, except that I can communicate
reasonably well
DMB | 11/07/2020 21:59:28 |
1585 forum posts 1 photos | Celso Ari, If you do not understand a word, try the translator and if its still a bit confusing, private message the person who posted it. Never be afraid to ask, one or more of us will try to explain things. Not helpful that there is different slang used in different areas of UK and some things have a different name depending on which part of the country. An English Lake is an Irish Lough or a Scottish Loch. There are many more examples. Regards, John |
DMB | 11/07/2020 22:22:00 |
1585 forum posts 1 photos | Celso Ari, Just watched your youtube on making tongs. Thanks for sharing. I like your design of the joint, might make a set of tongs using your design. John |
Bill Dawes | 12/07/2020 13:21:11 |
605 forum posts | Well done, greetings from Somerset in the UK. Something I have been thinking about for a while so this has given me some inspiration, It is about time i used my welder I have buried in the back of the garage, never used it enough to get past the stick welding itself to the job! Thank you for sharing, interesting to see how many different parts of the world we get posts from on this forum. Best regards Bill D. |
Michael Gilligan | 12/07/2020 18:30:06 |
![]() 23121 forum posts 1360 photos | The best translator I have found is DeepL . O melhor tradutor que encontrei é DeepL . MichaelG. . Edited By Michael Gilligan on 12/07/2020 18:31:21 |
celso ari schlichting | 13/07/2020 23:12:45 |
![]() 145 forum posts | Posted by DMB on 11/07/2020 22:22:00:
Celso Ari, Just watched your youtube on making tongs. Thanks for sharing. I like your design of the joint, might make a set of tongs using your design. John Thanks John, I'm glad you liked it ... a big hug from Brazil |
celso ari schlichting | 13/07/2020 23:15:19 |
![]() 145 forum posts | Posted by Bill Dawes on 12/07/2020 13:21:11:
Well done, greetings from Somerset in the UK. Something I have been thinking about for a while so this has given me some inspiration, It is about time i used my welder I have buried in the back of the garage, never used it enough to get past the stick welding itself to the job! Thank you for sharing, interesting to see how many different parts of the world we get posts from on this forum. Best regards Bill D. Bill, a welding job always helps in completing a project and is one of the things that I use a lot in the workshop Cheers Celso Ari |
celso ari schlichting | 13/07/2020 23:16:55 |
![]() 145 forum posts | Posted by Michael Gilligan on 12/07/2020 18:30:06:
The best translator I have found is DeepL . O melhor tradutor que encontrei é DeepL . MichaelG. . Edited By Michael Gilligan on 12/07/2020 18:31:21 Michael, i will definitely use it soon, thanks for sharing Greetings from Brazil |
