What’s best glue for joining wood to PVC pipe?
Simon Robinson 421/06/2020 14:45:36
102 forum posts
Hi
What glue would you recommend for joining wood to PVC pipe? Also what is the best primer to paint on the PVC so the paint does not scratch off?
Also can I use epoxy resin to smooth the join between the PVC pipe and wood?
Edited By Simon Robinson 4 on 21/06/2020 14:47:00
Bo'sun21/06/2020 15:02:06
754 forum posts
Hi Simon,
I'm no expert, but here goes. Roughen the PVC pipe to get a key, and try some polyurethane glue. A little experimentation would be prudent. As for primer, my guess would be an etch primer. Epoxy will tend to find it's own level to some extent, so I'd be inclined to use a 2 part wood or car body filler, or maybe some form of caulk, depending on the intended purpose.
John Haine21/06/2020 15:19:08
5563 forum posts
322 photos
Gorilla Glue Clear seems to stick most things.
Martin Hamilton 121/06/2020 16:53:54
188 forum posts
You want Devcon Plastic welder 2 part adhesive, this is an acrylite glue intended for plastics. It is also good on metal, wood, glassfiber etc. Hobby shops or Ebay for around £8 or £9.
Ady121/06/2020 18:12:08
6137 forum posts
893 photos
I just use pinkgrip for everything
Steve Skelton 121/06/2020 18:32:19
152 forum posts
6 photos
Simon, a little more info would (NPI) help. What are you trying to achieve, what wood, what shape PVC - rigid or plasticised, the type of bond, application?
Steve
