Made a device for a (very) non-mechanical friend and need to fix instructions to it.
David Palmer 1 | 04/06/2020 16:51:51 |
2 forum posts | I have made a piece of kit for a railway modeller friend who is not mechanically minded at all. I need to permanently fix the printed (by me ) instructions to the 3" painted ally cylinder which is the outer case. I need to fix the paper permanently to the case and then protect it from a degree of ham fistedness! Dave Palmer. |
AdrianR | 04/06/2020 17:43:13 |
613 forum posts 39 photos | I recently discovered that you can get water slide decal paper for your inkjet. Apparently print what you want, spray with clear spray varnish and put on like the old fashioned water transfers. You could put another couple of costs of varnish over it after it has dried. Adrian |
ian j | 04/06/2020 19:29:48 |
![]() 337 forum posts 371 photos | Laminate the printed instructions and use thin double sided tape to fix it in place. I use this method to produce control panel overlays etc with good results. |
martin perman | 04/06/2020 20:34:14 |
![]() 2095 forum posts 75 photos | Posted by AdrianR on 04/06/2020 17:43:13:
I recently discovered that you can get water slide decal paper for your inkjet. Apparently print what you want, spray with clear spray varnish and put on like the old fashioned water transfers. You could put another couple of costs of varnish over it after it has dried. Adrian +1 for this, I recently acquired a tractor and trailer for my 14 month old grandson and the stickers on them have come off, his name is Oliver and there was a company who built tractors called Oliver so I'm making new transfers for the tractor, I've already made names for his drinking bottles at Nursery which worked out well. Martin P |
Ian P | 04/06/2020 20:40:46 |
![]() 2747 forum posts 123 photos | I suggest trapping the printed label using a length of the heatshrink tubing commonly used to encapsulate cells to make up battery packs. It is thin walled, has a high shrink ratio and is available in several colours and in pre-shrunk diameters up to about 150mm, (clear is one of the colours) If you search for battery, pack, heat, shrink you will find lots of sellers
Ian P |
duncan webster | 05/06/2020 00:21:01 |
5307 forum posts 83 photos | You can get sticky back encapsulation pouches |
The Novice Engineer | 05/06/2020 23:10:25 |
85 forum posts 72 photos | For a similar job I used Waterproof Plastic self adhesive labels [Polylaser] that were printed with a Laser Printer. Find them on E bay or Amazon or even local office suppliers
