mark smith 20 | 27/05/2020 14:47:50 |
682 forum posts 337 photos | HI, I was busy using the sander today and then switched it off . When i went to switch back on ,no power. From experience its usually the crappy nvr magnetic on/off switch these things are usually fitted with. So tried another but remembered it was broke. Decided to use one out of a cheap grinder but still will not work,the switch rumbles when pressed but will not start. Any suggestions as i get sick of replacing these cheap chinese switches .Or is something else wrong. Brushes look fine. They are the KJD switches or similar the one in the machine was unmarked (just 250V 6 amp) Thanks Edited By mark smith 20 on 27/05/2020 14:49:38 |
Andrew Tinsley | 27/05/2020 15:08:10 |
1817 forum posts 2 photos | Hello Mark, If it does turn out to be the switches again, then maybe you should upgrade the switches to better quality ones. I am not being flippant, I have had exactly the same problem with those very same switches. After two failures, in relatively quick succession. I went out and got some good quality items and have never had a problem since. Andrew. |
mark smith 20 | 27/05/2020 15:24:30 |
682 forum posts 337 photos | Could you point to suitable one of better quality as all i see is variations of the same chinese switches on google. |
mark smith 20 | 27/05/2020 15:31:09 |
682 forum posts 337 photos | Are these suitable |
Andrew Tinsley | 27/05/2020 15:41:27 |
1817 forum posts 2 photos | Hello Mark, The Eichoff switches which you have found would be an excellent replacement. I can't remember what the make of my switches were. I got them from my local factors, I suspect they may have been MEM, I sold on the kit that used them so I cannot check. I went through the usual Ebay lists and Amazon too and basically found about 3 or 4 versions being sold by hundreds of people. That is when I gave up and went to my local electrical factors. Andrew. |
mark smith 20 | 27/05/2020 15:44:36 |
682 forum posts 337 photos | Thanks , but still puzzled why the working one from the bench grinder doesnt work on the sander . (It definitely works on the grinder as i just checked again.) The only thing between the motor and switch is this board, which i havent a clue about. Edited By mark smith 20 on 27/05/2020 15:49:39 |
mark smith 20 | 27/05/2020 19:07:10 |
682 forum posts 337 photos | No more thoughts, im doubtful that the switch is the problem. The board above is supposedly some crude ac/dc converter .Motor is dc brush motor rated at 450 watts. Anyone? |
Anthony Knights | 28/05/2020 07:35:21 |
681 forum posts 260 photos | The PCB looks like a 4 diode rectifier with suppressor chokes / capacitors and a couple of VDR's. |
Frances IoM | 28/05/2020 07:49:49 |
1395 forum posts 30 photos | is it possible that the VDR means that the initial current taken by the sander is insufficient to keep the NV switch held - presumably the VDRs are there to limit surge on switch on Edited By Frances IoM on 28/05/2020 07:50:17 |
Joseph Noci 1 | 28/05/2020 07:57:55 |
1323 forum posts 1431 photos | Posted by Anthony Knights on 28/05/2020 07:35:21:
The PCB looks like a 4 diode rectifier with suppressor chokes / capacitors and a couple of VDR's. Anthony has it - that board is just a suppressor board -common mode/series inductor chokes and bypass capacitors. The AC is rectified and that seems to be what feeds the motor - Maybe a diode is duff? Check the diodes, check there is no bad solder joint/wire connection on the underside of that board, and then, if all OK, bypass the magnetic switch momentarily and see if the motor runs- If the Grinder switch works on the grinder and not the sander, I doubt it's the switch - more likely there is insufficient current flow to keep the switch active, which means either faulty diode(s), bad connection somewhere, open winding on armature/stator, bad brushes/connections.. Joe Edit - one other thing - those blue blobs - sometimes those are capacitors, but sometimes there is a device in series with the supply line that is used for short circuit protection - said device often looks like a capacitor - these devices are basically a resettable fuse - when cold ( room temp) they are close to zero ohms resistance,but if there is a short, the high current heats it up and the resistance climbs rapidly to megohms, effectively opening the circuit. When cold, all is well again..unless the device has popped open-circuit. Do you have an ohm-meter/multi-tester? Try to determine from the PCB layout if the one device, the smaller one, lower left in your picture, is in series with the power lines and if so measure across it to see if it is opencircuit. If all those blue devices are ACROSS the power lines, they are capacitors, to be ignored for now..
Edited By Joseph Noci 1 on 28/05/2020 08:05:53 |
mark smith 20 | 28/05/2020 10:44:30 |
682 forum posts 337 photos | Thanks for the replies. Im terrible at electrical diagnosis. I do have a multimeter but unsure where to put the probes and on which settings. Heres a photo of some of the components. The only thing that maybe looks odd to me is behind each of those two round things with a coil going round the circumference . Messy black areas on the back of the pcb. |
mark smith 20 | 28/05/2020 12:08:13 |
682 forum posts 337 photos | If it helps all the diodes have tested 0.495v forward and OL in reverse. The two rectangular black capacitors measure 0.31uF (stated on capacitor as 0.22uF), I cant seem to get any straight stable readings on the blue ceramic disc capacitors (taken from the pins at the back of the pcb.) multimeter seems stuck on nF
Edited By mark smith 20 on 28/05/2020 12:09:48 Edited By mark smith 20 on 28/05/2020 12:12:30 |
Joseph Noci 1 | 28/05/2020 12:27:34 |
1323 forum posts 1431 photos | Mark, lets first be sure those blue jobs are capacitors - can you read the text on them at all? It should be fairly obvious if they are caps. Also, there appears to be some legend printed on the board, seems partially under the components? What is the legend under those blue jobs? The diodes as you measured seem fine. The larger black inductor - the one tied to the PCB with a white tie wrap - measure with your ohm-meter from the lower left black wire to the upper left black wire in as seen in your image below - then measure from the lower right to upper right - each measurement should show low resistance - if not, try lower left to upper right, etc. If all low res, that common mode inductor is ok and not open circuit. Lets take it from there.. Joe EDIT - not clear in the photo, but it appears that there are 3 black wires from the PCB to the motor - where do they connect on the motor - I would expect 2 ? Is one a ground connection?
Edited By Joseph Noci 1 on 28/05/2020 12:29:55 |
mark smith 20 | 28/05/2020 12:32:29 |
682 forum posts 337 photos | The blue things are marked JD222MY1 400v- X1 400v -Y1 The black wire in the middle of the photo going to the right is the earth (screwed to motor casing) Tested larger inductor. lower left to upper left 0.4 ohms, lower right to upper right 0.4 ohms (lower left to upper right etc reads OL) Upper the blue caps it says C4 and C3. The blue caps measure 4.52nF from the back on the solder joints but dont know if accurate as some solder joints touch others.Cant get to the caps legs from the front. Edited By mark smith 20 on 28/05/2020 12:32:46 Edited By mark smith 20 on 28/05/2020 12:36:47 Edited By mark smith 20 on 28/05/2020 12:39:22 Edited By mark smith 20 on 28/05/2020 12:46:07 Edited By mark smith 20 on 28/05/2020 12:50:40 Edited By mark smith 20 on 28/05/2020 13:02:18 |
Joseph Noci 1 | 28/05/2020 13:58:23 |
1323 forum posts 1431 photos | Ok Mark. Just to be clear - all THREE blue jobs are marked JD222MY1 400v- X1 400v -Y1 - correct? ie, they are identical? If so , they are all three capacitors and will not be part of your problem. They are 2.2nf 400V class X1/Y1. The only two components left are the two toroids - upper and lower right - Measure across each coils wire ends for low resistance. Then, instead of measuring all wires/cables for continuity, can you apply mains power safely, bypassing the magnetic switch? The wires end in spade terminals - This trick works - BUT BE CAREFUL - THIS IS NOT RECOMMENDED PRACTICE - PLEASE BE CAREFUL... DISCONNECT THE UNIT FROM THE MAINS SOCKET _ PULL OUT THE PLUG ETC...!!! Take two paper clips (!) and press the ends into each of the spade terminals of your cable, ie, in place of the switch. So, using a paper clip as a shorting jumper, connect the PCB end of the cable to the end of the mains cables, in place of the switch. Do this for LIVE and NEUTRAL. Check that the connection is good and firm. TAPE EACH KLUDGED JOINT UP INDIVIDUALLY WITH GOOD INSULATION TAPE. Make sure there can be NO accidental contact with this thing! Mains wall plug switch in OFF position, plug in the sander's plug. Make sure the sander motor is stable, the PCB is fixed and nothing can short out because of the kick on startup... BEING CAREFULL....Switch on.. Did the motor turn or not??? If not.. Switch off and remove wall plug. You now need to measure some voltages at the motor brushes and on the PCB, so make sure the motor is stable so that you can use one probe per hand and probe about without the pcb moving away etc. You are dealing with a killer voltage here, so CARE IS NEEDED. Please also make sure your multimeter is safe, eg, probes are in good condition, with no chance of conduction along the probe insulation ( dirty, etc..) When sure, plug in again, and switch on. Please be aware that while probing, if there is a loose connection that makes while probing, the motor may start up, startling you. Flayling about with metal probes at that point requires care.. Measure on AC and DC settings, at the motor brush wire connections ( set meter to read 220VAC/220VDC) If nothing appreciable, then measure at the leads of the two toroids - the toroids are each in one leg of the rectified mains to the motor it seems - so on the lower right one, on the black wire just below the phillips head screw, and on the uppr right toroid, the black wire just above the phillips head screw. This should be full wave rectified DC, so meter to DC, but try AC as well ( also 220V settings - or greater depending on meter available settings) Next... Joe |
mark smith 20 | 28/05/2020 14:23:03 |
682 forum posts 337 photos | Bypassed the switch and nothing! The two toroids?? both measure 0.5 ohms. Second half of your instruction i am lost! No idea where to put probes etc.... Edited By mark smith 20 on 28/05/2020 14:31:22 Edited By mark smith 20 on 28/05/2020 14:35:45 |
Joseph Noci 1 | 28/05/2020 14:31:47 |
1323 forum posts 1431 photos | I am trying to help Mark...'nothing' tells me 'nothing'.... I presume the motor did not turn. Did you measure at the brush terminals? Nothing? At the rectifier outputs ( the two toroids black wires?) - Nothing?
mark smith 20 | 28/05/2020 14:36:49 |
682 forum posts 337 photos | Sorry, no humming noise and no movement of motor spindle at all. |
mark smith 20 | 28/05/2020 14:38:08 |
682 forum posts 337 photos | Where do i put the probes to measure the brush terminals ? One probe on one terminal and one on other ?
mark smith 20 | 28/05/2020 14:55:25 |
682 forum posts 337 photos | There is 240v ac going into the board measured with the meter but at the other side of the board ,the points that go to the motor brushes there is no DC but 70V AC when measured between those two points ??? But when i measure between the two toroids i get -250V DC
Edited By mark smith 20 on 28/05/2020 14:56:33 Edited By mark smith 20 on 28/05/2020 15:19:02 |
