Can I justify the cost of a replacement bulb
ega | 14/04/2020 12:01:47 |
2805 forum posts 219 photos | My Serious Readers brand LED desk lamp wouldn't turn on this morning and, having checked with an alternative mains socket, I looked on the SR website for a replacement bulb. The lamp has been in continual use for some years and the cost of £44 including postage may well be justified; it would, however, buy a (non-SR) replacement lamp! My knowledge of LED lighting is limited but I suspect the bulbs are SR-specific. It would be good to know if there is likely to be a generic replacement available or, indeed, any other useful comment from members. |
Kiwi Bloke | 14/04/2020 12:19:59 |
912 forum posts 3 photos | LED technology has come on a bit in the time you've apparently had your lamp. There seems continually to be more choice, prices have come down a lot, and availability to the public is much better. I think I'd be looking to re-engineer the lamp to take something easily available. |
Former Member | 14/04/2020 12:30:50 |
1329 forum posts | [This posting has been removed] |
Former Member | 14/04/2020 12:30:54 |
Ian Parkin | 14/04/2020 12:33:32 |
![]() 1174 forum posts 303 photos | Ega Are you sure its the “bulb” i would suspect the power supply first and certainly SR wont be making leds so its just a matter of finding the emitter part of the bulb |
ega | 14/04/2020 15:11:15 |
2805 forum posts 219 photos | Gentlemen: Many thanks for your responses. I will check the power supply and think about the re-engineering suggestion. In the meantime I have replaced the lamp with a budget item from Ikea whose cost was about one fifth of the cost of the replacement bulb. |
Ian Parkin | 14/04/2020 16:19:00 |
![]() 1174 forum posts 303 photos | What’s the bulb look like ega? can you post a picture? can you see the difference between bulbus expensivicus and the ikea one? |
Howard Lewis | 14/04/2020 17:08:59 |
7227 forum posts 21 photos | It is known as "Market Place Pricing" or "what the traffic will bear" If nobody buys, the price will fall! It may well be worth re engineering the standard, if it needs it, to a standard lampholder, and then fit one of the more economically priced LED lamps, either BC, or E27 Howard |
ega | 14/04/2020 17:09:29 |
2805 forum posts 219 photos | Ian Parkin: I've put photos of the bulb and PSU in an appropriately named album. The SR bulb is 50mm dia, the Ikea item (which is stated to be non-replaceable) c. 28mm dia. Thanks for your continued interest. Might you elaborate your "emitter" point (I think of valves when that word comes up)? |
ega | 14/04/2020 17:15:21 |
2805 forum posts 219 photos | Posted by Howard Lewis on 14/04/2020 17:08:59:
It is known as "Market Place Pricing" or "what the traffic will bear" If nobody buys, the price will fall! It may well be worth re engineering the standard, if it needs it, to a standard lampholder, and then fit one of the more economically priced LED lamps, either BC, or E27 Howard Two standards for the price of one?! SR do make some "serious" claims about the quality of the light from their lamps. A relative whose judgment I trusted had a couple of these for many years and I probably bought on the strength of this. I suppose the other consequence of nobody buying would be the seller ceasing to trade. Thanks for the pointer to LED bulb types. |
Andrew Tinsley | 14/04/2020 17:28:50 |
1817 forum posts 2 photos | Unfortunately, outfits like "Serious Reader" are little more than a con. In the days of Halogen lamps, they just used ones from the major manufacturers. Nothing special at all! Exactly the same with the newer LED versions. They charge an arm and a leg for bog standard lighting products.. You can get better engineered luminaires from most of the lighting retailers. for a fraction of the cost. It has been my misfortune to have to repair a couple of these offerings and they are simply crap. In case anyone questions my opinions, I have been involve in lighting R&D for well over 20 years, so I know what I am talking about! Andrew. |
Howard Lewis | 14/04/2020 17:39:54 |
7227 forum posts 21 photos | ega, By standard, I meant modifying the whole device to use a standard lamp holder (Bayonet Cap or Edison Screw ) In that way replacement lamps will be widely available, at sensible prices, and easily obtainable. Petrol or Diesel may be £7 a litre at the pump, but can be much more expensive when someone brings it to you after you run out five miles from home at midnight! If I make something which is held together with 7 mm x 10 tpi bolts, I will capture the spares market and can charge silly prices, until someone starts making spurioius spares, or a conversion kit to allow use easily available fasteners. Howard |
Ian Parkin | 14/04/2020 18:14:26 |
![]() 1174 forum posts 303 photos | Ega so have you fitted a 12v bulb? and used your original power supply? if all that works and the lamp is held securely and you like the light output then everything’s ok? |
Enough! | 14/04/2020 18:15:16 |
1719 forum posts 1 photos | Posted by Howard Lewis on 14/04/2020 17:39:54:
Really? Gotta be something wrong ... a typo? It's 65 cents (CDN) a litre here. |
Former Member | 14/04/2020 18:49:28 |
Howard Lewis | 14/04/2020 19:21:57 |
7227 forum posts 21 photos | Bandersnatch, Where you live, you are not paying more tax than for the fuel, Bill Chugg, They omitted to say "And profitability" Howard |
Mick B1 | 14/04/2020 19:35:38 |
2444 forum posts 139 photos | I came across an advert for Serious Reader lamps IIRC in the back of the TV comic we buy. I'm afraid I was instantly suspicious - I wondered what they do that a <=20 squid anglepoise clone from Ikea or suchlike doesn't. I've never found these latter deficient - we've several in various places in the house, including one mounted over the Warco. What's supposed to be unique about the SR light quality? |
Andrew Tinsley | 14/04/2020 19:42:34 |
1817 forum posts 2 photos | What absolute BULLSHIT, "superior light quality"..........."They are unique and deliver the core benefit of the light". These people should be prosecuted for such rubbish. They are run of the mill, mainstream manufacturer's lamps in shoddy luminaires., at seriously ridiculous prices. Andrew. |
Peter H | 14/04/2020 20:08:35 |
10 forum posts | They look like standard MR16 12v LEDs to me. |
Mick B1 | 14/04/2020 20:09:11 |
2444 forum posts 139 photos | Posted by Andrew Tinsley on 14/04/2020 19:42:34:
What absolute BULLSHIT, "superior light quality"..........."They are unique and deliver the core benefit of the light". These people should be prosecuted for such rubbish. They are run of the mill, mainstream manufacturer's lamps in shoddy luminaires., at seriously ridiculous prices. Andrew. You'd end up jamming the courts with them and their like, then. I spent long enough in the software industry to recognise undefined 'quality' hype - but then it's everywhere, in every business area. Edited By Mick B1 on 14/04/2020 20:09:28 |
