boiler leak
Philip Burley05/04/2020 08:25:41
198 forum posts
I am having a second go at making a boiler ( never again ) The first was a disaster , At second attempt , soldered the tubes OK , soldered one end in the barrel , looks OK , but the second end must be a bit slack i , The solder runs through and wont bridge the gap in places I am thinking of putting in a narrow copper ring and hoping at will seal on that . What to more expert makers think ?
Thank goodness we have the shed to play in these days
Clive Brown 105/04/2020 08:41:33
1050 forum posts
56 photos
Some more detail on the size and design of the boiler would be useful. Perhaps a picture or two.
Apart from your ring suggestion, 2 other possibilities.
1. Copper tube can be expanded in diameter using a drift with a gentle taper.
2. Silver solders are available which form a larger fillet than the lower melting point types. They are less "runny". This could help.
Pickle/clean the new joint areas well.
Former Member05/04/2020 08:43:58
1329 forum posts
Philip Burley05/04/2020 09:13:59
198 forum posts
its a 4 inch diameter boiler barrel . I have already unsoldered it once and made new flanged , end plates and reduced the umber ot tubes but to get the tubes and ends into the barrel once they have been assembled together the flanges cant be too tight or they wont go down with out too much pressure .
I am ok machining engine parts , and I can silver solder a bike frame , but boilers have been a step too far for me . . If I cant get this to seal its going in the scrap bin and put it down to experience . Luckiy I do have a ST 504 and an up right boiler I hade a lucky ebay buy from which when cleaned up and new fittings made works well ,
Phil
Former Member05/04/2020 09:26:44
1329 forum posts
fizzy05/04/2020 09:57:09
1860 forum posts
121 photos
It needs to be a tightish push fit. If it isnt then when you apply heat to a boiler of this diameter the shell will expand a lot quicker than the plate and the gap is too big. This wasnt a problem when people used to rivet and solder. On bigger loco boilers I use rivets at a few key points to stop things moving and then remove them when completed. This is one I completed over the weekend but sadly Tim cant come and collect it right now.dscf2639comp.jpg
fizzy05/04/2020 10:01:18
1860 forum posts
121 photos
Thats a boiler photographed three years ago...uploaded wrong photo but same soldering, we use different burners and pressure gauge syphons now....just in case anyone notices!
IanT05/04/2020 10:09:15
2147 forum posts
222 photos
Boiler material is expensive Philip and it would a great pity to just bin the whole thing.
I think (?) you are saying that your tubes are either too loose or too tight in the flanged end plates when you assemble them. The tubes should be a free 'sliding' fit and this should be checked before any attempt to assemble or braze parts together. They certainly shouldn't be hard to push in but make sure the flanged plates are de-burred. A tube 'end' can be enlarged with a tube expander and a number of expander designs have been published (in ME) over the years (sorry - I don't have details to hand at the moment)
Take your time but stick with it - its very satisfying when you finally manage to overcome an obstacle like this one.
IanT
Philip Burley05/04/2020 10:21:01
198 forum posts
Ian it isn't the tubes in the end plate , they seem ok its the flanged end plate in the boiler tube , I have found a but of 1/8 copper rod , I will try soldering that round the joint , if that doesn't work then its hello mr scrap man
Phil
Former Member05/04/2020 10:34:30
1329 forum posts
Former Member05/04/2020 10:50:18
1329 forum posts
Philip Burley05/04/2020 12:28:45
198 forum posts
sounds as if I might as well chuck it under the bench and get back on my Red Wing engine , Working in the cylinder head now !!
Graham Swales05/04/2020 12:39:09
36 forum posts
Philip - have sent a private message.
Philip Burley05/04/2020 18:50:23
198 forum posts
boiler1.jpgmy boiler end plate sorry I cant see how to make it smaller
duncan webster06/04/2020 09:16:34
5307 forum posts
83 photos
Use a ball pein hammer on the outside to close up the gap. The copper will be soft after the previous heating
Brian H06/04/2020 10:53:38
2312 forum posts
112 photos
Duncan's suggestion is a good one but go gently as soft copper moves very easily.
If it was me I would use my stock of Easy-flo No 3 but as this is no longer obtainable I've waited to reply until I had more info. Well, that came this morning in an email from Johnson-Matthey who say that the equivalent is Argo-braze 502 which is normally used to braze carbide tips but can be used on copper.
It has 50% silver and melts at 660-705 deg C.
This is similar to Easy-flo No 3 but without the cadmium. I always use Tenacity 5 and find that the 'solder' has a very runny component that flows into the gap followed by a more pasty substance that is sluggish and forms a nice fillet and is excellent for making simulated 'castings'.
Edited By Brian H on 06/04/2020 10:54:18
duncan webster06/04/2020 11:39:26
5307 forum posts
83 photos
We don't know what alloy the OP used, so I'd try with the lowest melting alloy (630/660) so as not to melt the joins that are already made causing more holes. For some reason I used to understand, you have to get it hotter to melt it second time, so with care it should be possible to fill in the (closed up) gaps without causing more. Apply the heat to the outside of the shell, not to the side with the solder on
Edited By duncan webster on 06/04/2020 11:40:17
Philip Burley06/04/2020 11:42:28
198 forum posts
its in the pickle , will try again this afternoon
