Electrical conducting paint
Car demister panel
Speedy Builder527/03/2020 12:17:50
2878 forum posts
248 photos
The electrical tab connector has detached from the rear screen heating grid on the car. I have seen a tube video showing a guy soldering it back onto the grid, but I hesitate as I have a concern that the thermal shock may shatter the glass.
Would electrical conducting paint be better with an epoxy coat to make it more secure once the paint has dried.
Anyone had same experience ?
Stuart Bridger27/03/2020 13:25:01
566 forum posts
31 photos
Wow, it must be over 30 years since I used that stuff for the exact same repair. From memory it worked well, I didn't need epoxy on top. Still have a little bottle rattling around in my took box, not sure if it still any good!
noel shelley27/03/2020 13:25:38
2308 forum posts
33 photos
Solder with as big an iron as you can ! In, solder flows and out, quick ! Heater is high current. I would question resistance of the paint which may heat. Best wishes Noel
Robert Atkinson 227/03/2020 13:59:04
1891 forum posts
37 photos
Assuming the element is on the surface, rather than embedded in laminated glass, the best repair is t use silver loaded conductive epoxy. Not cheap though
https://uk.farnell.com/multicomp/mc002966/epoxy-adhesive-syringe-6ml-silver/dp/2917615?st=ilver%20epoxy
Make sure it says it is ELECTRICALLY conductive, some are designed for thermal conducttivity and may not be good electrically.
Robert G8RPI.
old mart27/03/2020 16:19:23
4655 forum posts
304 photos
I bought some of this, but haven't tried it yet, I am waiting for warmer weather.
Speedy Builder527/03/2020 16:25:49
2878 forum posts
248 photos
This is the video I saw:
de mister repair
old mart27/03/2020 16:50:19
4655 forum posts
304 photos
It looks like you could get away with soldering it, but during this lockdown at present, if the window did shatter, who would replace it?
john fletcher 127/03/2020 18:01:05
893 forum posts
I think I used my 100 watt soldering iron, maybe it was 80 or 90. I warmed up the connector first, then quick dab, job done.I also remember buying some expensive Silver conducting paint, from I think Radio spares now RS for fail rear widow heater and that worked. John
Speedy Builder528/03/2020 16:08:06
2878 forum posts
248 photos
Thanks for the replies, so soldering iron it is, but A) wait for some hot sunshine and B) do it when the auto glass shop is open for business.
