4 Wire motor wiring
Cornish Jack26/03/2020 15:29:11
1228 forum posts
172 photos
Recently bought this miniature sensitive drill and fitted the 'Universal' sewing machine motor to power it. img_0071a.jpg
Works OK apart from motor rotation. I would like to reverse the present setup. The connection is 4 pin and I (wrongly) assumed that swapping pins 2 and 3 would do the necessary
Can anyone suggest a. if it is possible to reverse the rotation and b. if it is , how to reconnect, please?
TIA
rgds
Bill
Keith Long26/03/2020 15:40:14
883 forum posts
11 photos
There is a very good chance that the motor isn't reversible, reverse on a sewing machine is generally done mechanically I believe. I tried to reverse one of these motors but gave up when I opened it and found that the brushes were off-set for optimum operation in the originally intended direction. I believe that you can buy these type of sewing machine motors set up for either clockwise or anti-clockwise rotation but not electrically reversible types.
Journeyman26/03/2020 15:48:16
1257 forum posts
264 photos
Used to have one of these motors on a home built fretsaw. As far as I can remember the the 4 pins are linked to a foot pedal for speed control but no reverse. If possible you can turn the motor up the other way to achieve reverse on a permanent basis.
Roger Woollett26/03/2020 15:51:50
148 forum posts
6 photos
It may be possible to take the motor apart and reverse either the commutator or the field winding connections. I did this a while back with a similar motor.
Bruce Newman26/03/2020 16:25:44
20 forum posts
More details needed.
Have you details of make and model number or a picture of red plate on the motor?
Can you confirm the green wire is the earth wire and connected to motor body?
Are you numbering the pins with number one at the top?
Do you have the other half of the plug and if so how is that wired to the mains and does it have the foot pedal?
Swapping wires around at random can be very dangerous.
To reverse this type of motor you reverse the connections to the field coils with respect to the armature connections ( the brushes).
You need to identify which wires connect to what inside the motor.
If your lucky, it may be that the red wires connect to the field coils and the black to the brushes or visa versa but that may not be the case and they are interconnected internally in the motor. Again I repeat it can be dangerous if you are not confident in what you are doing! At least check with a multimeter that it is safe.
Bruce
Ag
Cornish Jack26/03/2020 16:42:01
1228 forum posts
172 photos
Keith, Journeyman, Roger, Bruce - Thank you all. The no-reverse would seem to be the most likely. My wiggly-amps skill is best restricted to rewiring plugs. so I think I'll leave well alone! Mechanical options are possible, so I'll have a ponder.
Again thanks
rgds
Bill
Brian Morehen26/03/2020 16:45:22
191 forum posts
11 photos
Motor plug 4 leads Top of Pic Earth 2 Lead Neatral 3 lead Live 4 Lead incomeing live takeing feed by the black lead to foot pedal and back to motor at No 3 single red live to .
Brian M
Journeyman26/03/2020 16:57:07
1257 forum posts
264 photos
This *** PAGE *** from Vintage Sewing Machines might help. The fat pin is the earth.
Cornish Jack26/03/2020 17:36:48
1228 forum posts
172 photos
Thank you - Brian and Journeyman again - that link is ideal
rgds
Bill
Speedy Builder526/03/2020 17:56:36
2878 forum posts
248 photos
Could you put a twist in the belt to reverse rotation or would it foul the column ?
Bruce Newman26/03/2020 19:33:30
20 forum posts
Looking at the details in link posted by John you would have to open up the motor to reverse the connections.
Nice to see a cluttered bench, just like mine.
Cheers
Bruce
Michael Gilligan26/03/2020 19:42:09
23121 forum posts
1360 photos
Posted by Journeyman on 26/03/2020 16:57:07:
That’s a great link, John
If I understand correctly; the pictured plug wiring [and the related comment] suggests that Bill’s motor has already been reversed
... correct me if I am wrong, Please
Bruce Newman27/03/2020 10:05:28
20 forum posts
No the motor has not been reversed, its just the wires to the speed control pedal are swapped over which makes no difference to the direction of motor.
Bruce
Cornish Jack27/03/2020 10:30:41
1228 forum posts
172 photos
Thanks all -
SB5 - unfortunately too close centre-to-centre to twist.
Bruce - fiddling with wiggly-amps is a 'no-no'! ... I feel that I should point out that the pic shows my TIDY work area!!!blush
MG - Pic wiring is original - I did try the 2 and 3 reversed but no difference, as Bruce pointed out, so reinstated.
Have dug out another, similar sized motor, completely without ident info but double ended drive. Is it possible to SAFELY identify/connect it to use? ... Answers in the "John and Jane look at electric motors" category, please!
rgds
Bill
Michael Gilligan27/03/2020 13:27:08
23121 forum posts
1360 photos
Posted by Bruce Newman on 27/03/2020 10:05:28:
Bruce
Noted ... Thanks
