Unkown small lathe
Can anyone help to identify this lathe?
Grindstone Cowboy18/03/2020 20:53:53
1160 forum posts
73 photos
Hi folks, hoping somebody might be able to identify this lathe I recently inherited. It has absolutely no makers marks that I can see, nor any serial numbers. Slowly working my way through each manufacturer on lathes.co.uk but it's a long job!
It appears to be simply, but sturdily made, there don't appear to be adjustable gibs on the slides.
Thanks for any suggestions.
(edited to get the text before the pictures...)
Edited By Grindstone Cowboy on 18/03/2020 20:55:22
Pete.18/03/2020 22:54:08
910 forum posts
303 photos
Looks like a nice old machine that hasn't been abused like so many of these old obscure little lathes, I can't help you with the model unfortunately.
When you start researching old machine tools like this, it's shocking just how much industry we used have making so many tools etc, so many small obscure companies making machinery in the first half of the 1900's.
Steviegtr18/03/2020 23:29:24
2668 forum posts
352 photos
Posted by Pete. on 18/03/2020 22:54:08:
Makes you wonder now. If all the large companies go under. Lots of new small enterprise may spring up.
Steve.
Ady118/03/2020 23:43:05
6137 forum posts
893 photos
Certainly built to a price with the minimum of metal possible
It's not like pouring big lumps of cast iron back in "-t' good old days-" was expensive
The expense was in the level of machining in the product, but this one has quite careful, almost fragile, castings
Edited By Ady1 on 18/03/2020 23:44:58
Grindstone Cowboy18/03/2020 23:49:17
1160 forum posts
73 photos
Thanks Pete - yes, it appears to be in excellent condition for it's age, with just a little rust on the chuck and on one spot on the bed, and no visible wear on the bed or leadscrew. I'll probably have to sell it as I now have six lathes and very little space left due to the passing of a close friend and acquiring the entire contents of his garage. But deciding what has to go is difficult.
There's also a hand shaper that I'm trying to identify, but it is in bits at the moment - I think it could be a Perfecto (there's a lot less shapers to look through on lathes.co.uk) - but hopefully it's all there so it can be got back into working order.
Hopper18/03/2020 23:54:57
7881 forum posts
397 photos
You might try sending some pics to Tony at Lathes.co.uk if you can't find it on his site, He may be able to identify it.
Interesting old machine, especially the combination top/cross slide set up. Good to see the dog clutch on the leadscrew. Very handy and something Myford should have fitted to the ML7 etc.
Grindstone Cowboy18/03/2020 23:57:19
1160 forum posts
73 photos
Hi Ady
Yes, it's neat little machine, but surprisingly heavy - the bed has (to my inexperienced eye at least) plenty of stiffening ribs underneath and I'm pretty sure it would cope with the type of work it was designed for. One interesting part is the handle for the dog clutch on the leadscrew - the castellated nuts holding the handle on put me in mind of an old lawnmower I have, and it almost looks like an afterthought.
Grindstone Cowboy19/03/2020 00:04:05
1160 forum posts
73 photos
Thanks Hopper, I'll get some better pictures from all angles and see what Tony can do. The top slide swivels 360 degrees, the handwheel on it looks like something I could make myself - very plain, and cheap-looking when compared with the main castings, so it may not be original.
Redsetter19/03/2020 07:29:33
239 forum posts
Interestingly it seems to have a right handed leadscrew. Also packing blocks under the headstock, so it may be somewhat modified from the original.
