John McCallum 1 | 17/03/2020 13:09:08 |
![]() 42 forum posts 28 photos |
Does anyone have any knowledge of this fine engine? John |
Jeff Dayman | 17/03/2020 14:11:03 |
2356 forum posts 47 photos | Very nice engine! I wonder if the "Bray" reference could be related to Stan Bray, former editor of MEW and author of several model and workshop books. |
JasonB | 17/03/2020 14:19:55 |
![]() 25215 forum posts 3105 photos 1 articles | Looks like somebody lost or mucked up teh "A" frame standard of their Stuart vertical and made the most of what's left. Cutdown box bed and sole plate painted green and a modified cylinder and valve chest too. |
John McCallum 1 | 17/03/2020 14:21:27 |
![]() 42 forum posts 28 photos | I was wondering about that too, hopefully someone will be able to give me more information |
John McCallum 1 | 17/03/2020 16:19:20 |
![]() 42 forum posts 28 photos | I disagree, the box bed has not been modified in any way |
Former Member | 17/03/2020 17:24:02 |
1329 forum posts | [This posting has been removed] |
John McCallum 1 | 17/03/2020 17:44:42 |
![]() 42 forum posts 28 photos | Bill, I’ll photograph it tomorrow John |
Michael Gilligan | 17/03/2020 19:30:15 |
![]() 23121 forum posts 1360 photos | The plot thickens ... **LINK** https://www.worthpoint.com/worthopedia/vintage-barograph-bray-developments-1776924591 MichaelG. |
Mick B1 | 17/03/2020 19:54:07 |
2444 forum posts 139 photos | Posted by JasonB on 17/03/2020 14:19:55:
Looks like somebody lost or mucked up teh "A" frame standard of their Stuart vertical and made the most of what's left. Cutdown box bed and sole plate painted green and a modified cylinder and valve chest too. Yes, the box bed is shallower than my vanilla 10V, and I reckon the cylinder and valve chest may be scratch-made or modded from another casting set, as they look bigger. Must've been a bit 'interesting' assembling that crosshead running in blind slots in the guide rails. Good balance weights on the crank throws - one of the 10V's weakest design features. Edited By Mick B1 on 17/03/2020 19:57:18 |
John McCallum 1 | 18/03/2020 09:33:25 |
![]() 42 forum posts 28 photos | I think I'm getting somewhere now. There is an advert on Evilbay for Bray Developments dated 1969. The ad shows a Barograph fitted into an identical case and cover to mine. John |
Former Member | 18/03/2020 10:15:42 |
Mick B1 | 18/03/2020 11:07:20 |
2444 forum posts 139 photos | Posted by Bill Chugg on 18/03/2020 10:15:42:
Amazing how you found that. I am currently trying to date the period of the old telephone number. Just a thought - is it possibly a mismatch ? A defunct barograph base thathas been used for the engine ? Bill That'd be my guess too. |
John McCallum 1 | 18/03/2020 11:16:57 |
![]() 42 forum posts 28 photos | Yes, that's what my thinking is now. The cut out in the base plate is, I assume where the battery once lived and is now used to hold a piece of absorbent cloth Whoever built the engine was a Craftsman John |
Hopper | 18/03/2020 11:23:28 |
![]() 7881 forum posts 397 photos | It does look like a Stuart vertical bed plate as Jason says. The little chrome handrail has been screwed into the holes that would normally be used to bolt the A frame down. Just looks like the lower part of the bed plate has been left off, or maybe machined down?. Maybe the builder did away with the original valve chest cover because the S would be laid over on its side and replaced it with a piece of plain plate? Or turned it around so the S is concealed on the inside? Although it's in the back of my mind vaguely that the very earliest Stuarts did not have the S cast into the valve cover?
JasonB | 18/03/2020 11:28:45 |
![]() 25215 forum posts 3105 photos 1 articles | If it is Stuart based then the box bed has been cut down in height and as the flywheel now needs a hole in the base to clear but it could also just have been a bit of flat bar or plate.
JasonB | 18/03/2020 12:52:48 |
![]() 25215 forum posts 3105 photos 1 articles | Bill Chugg asked me to post this |
Former Member | 18/03/2020 12:56:30 |
Mick B1 | 18/03/2020 13:24:25 |
From the postage cost and absence of postcode I'd guess a date of later 1960s? First time I saw a postcode was on a Uni application in '68, but they were slower catching outside urban areas. OTOH decimal currency came in in '71. Even just before decimalisation, I'd reckon 7/6 was quite a lot to pay for P&P. |
