Paul L | 08/03/2020 11:45:02 |
![]() 87 forum posts 26 photos | Many years ago i worked on a CMM that had 'leadscrews' that were round bars that had a nut consisting of 3 roller bearings set at a shallow angle to the bar. As the bar rotated the nut travelled along the bar. A colleague of mine used to call then a ewin / euan / uwin drive but google doesnt seem to know about them. Anyone cast any light on this? |
Michael Gilligan | 08/03/2020 11:53:49 |
![]() 23121 forum posts 1360 photos | Will this do, Paul ? https://www.researchgate.net/figure/Concept-2-An-angled-traction-drive-where-the-rollers-are-not-mounted-parallel-to-an_fig1_265509008 The source document is interesting, even though it’s a little off-topic. MichaelG. |
Journeyman | 08/03/2020 11:57:09 |
![]() 1257 forum posts 264 photos | Seem to show up in 3D printers *** LINK *** Principle can be seen in photo where bearings are on the skew. John Edit: Spelling Edited By Journeyman on 08/03/2020 12:02:07 |
Paul L | 08/03/2020 12:21:14 |
![]() 87 forum posts 26 photos | That's the Badger! Its a simple cheap and effective solution. It appears the correct term is uhing (seen here from the link in Journeyman's post). Thank you for the info.
Pete Rimmer | 08/03/2020 12:42:44 |
1486 forum posts 105 photos | I saw one of those in 1987, back when brushless dc motors were not commonplace (our company were specialising in prototypes). It was to be used for some kind of sub-sea monitoring system in the oil industry. |
colin brannigan | 08/03/2020 14:08:03 |
125 forum posts 29 photos | Uhing units were cheaper way of winding wire onto reels used as a traverse unit left and right but could only be used on light wire as lack torque proved an issue, input speed was constant with variable pitch adjustment and no need for reverse. We tried a couple but not man enough for heavy work and stayed with left/right leadscrews or leadscrews with fwd/rev clutches.
duncan webster | 08/03/2020 20:11:00 |
5307 forum posts 83 photos | There is a similar system applied to wheels. Barrel shaped rollers are attached in chevrons, like traction engine strakes, opposite sides are opposite hand. Then by selectively driving the wheels forward and/or backwards you can make the chassis go forward, backwards, sideways, rotate on the spot. It all looks a bit bizarre. See and |
