NEMA selection for electronic leadscrew
Kevin McCartney04/03/2020 10:06:10
9 forum posts
9 photos
Hi
Another lurker here with only a couple of previous posts. I enjoy logging on most evenings and have learned so much just by reading through the forum.
I have a 1955 Colchester Student Roundhead with no gearbox. It performs well and although I have a full set of gears, changing them is a pain in the neck. I have studied Clough42's ELS project and have ordered some components for a build. I am fairly confident as I have successfully completed many arduino projects in the past.
If anyone can help my questions (so far) are: what size Nema Hybrid servo motor would be suitable for my lathe? I think some Students had 3HP motors, mine has an original 1.5HP as I think some were supplied with lower power for college use - I don't know if this info will help. Certainly 1.5 HP has always been enough for the jobs I have undertaken.
I have taken measurements of motors and made up templates - a NEMA 23 3Nm would fit nicely. Would this provide enough torque? I intend belt driving and gearing 3:1.
A larger NEMA 34 would be a squeeze in the location preferred as I don't really want to butcher the original end cover, although a shorter 4Nm may fit.
Clough42 mentions 3ph steppers although many of the ones I've seen are 2ph - is this a consideration or does the supplied driver box take care of this?
Any help gratefully received.
Kevin
mgnbuk04/03/2020 11:08:12
1394 forum posts
103 photos
There are also NEMA 24 motors that are slightly larger (60 square vs 57 square) but use the same spigot & mounting hole dimensions as NEMA 23. These can be obtained in 4 and 4.5Nm holding torque, so maybe a viable alternative to a NEMA 34 4Nm if space is tight & you need more torque than a NEMA 23 frame can provide. Stepperonline do these & I have also seen NEMA 23 rated 4 & 4.5Nm at CNC4you.
Nigel B.
Tony Pratt 104/03/2020 12:16:41
2319 forum posts
13 photos
I am using a Nema 24 on my Warco WM 290V [ 4 Nm allegedly] running 1:1 & it is underpowered on heavy roughing cuts, I'm thinking of going to a 2:1 ratio which should improve things I think.
Tony
mgnbuk04/03/2020 12:23:39
1394 forum posts
103 photos
Out of interest, what drive are you using with this ?
Nigel B
Martin Connelly04/03/2020 12:29:02
2549 forum posts
235 photos
If you buy closed loop stepper motors you can have an error signal to stop things if there is an issue with lost steps. It may cost more initially but you are only doing this once so may be a consideration. If you then have a slightly smaller stepper motor the occasional times you try to move things either too fast or too hard the error signal will trigger. Leadshine make closed loop driver and steppers but there are probably others, I haven't looked for a while.
This photo is of a rotating ball nut operating a push/pull ballscrew connected to the carriage. Note the small stepper motor. It is a Leadshine 3 phase closed loop matched to their driver unit.
Martin C
John Haine04/03/2020 13:13:19
5563 forum posts
322 photos
I'm using NEMA 23 via 2:1 reduction on my Super 7 leadscrew, driven from DM254 type drivers. No sign of lack of torque or lost steps (except when driven against the end stop!). Strikes me that just stopping on an error signal in the middle of cutting a thread is not a great idea!
Oven Man04/03/2020 16:16:40
204 forum posts
37 photos
The power supply for stepper motors is an important consideration. I have a NEMA 24 4Nm stepper directly driving the Z axis on my Champion V20 mill. I use a 40volt DC home made linear power supply and the system has more than enough power to lift the head without any other assistance.
Neil Wyatt05/03/2020 21:05:43
19226 forum posts
749 photos
86 articles
I think we often over-estimate the torque needed.
The typical leadscrew handle has a radius for the handle of about 40mm. A 4.5Nm stepper would give the equivalent torque to putting about 25lbs of pressure on the handle (1000/40 * 2.2 * 4.5).
That suggests to me that problems with lack of torque are possibly due to poorly set up drivers or too-weak power supplies.
The example Oven Man gives of lifting a mill head is far more demanding.
mgnbuk06/03/2020 10:36:39
1394 forum posts
103 photos
Which is why I was interested in the drive being used - limited testing with a couple of cheap single chip solution drives (Toshiba TB6600 & TB67S109ATFG) and a Stepperonline digital drive on a 2.2Nm Nema 23 motor from Arc Eurotrade has shown noticable differences in performance using the same 36V power supply.
The digital drive from Stepperonline performs much better than the other two - quieter, much less resonance & the motor warms up more, suggesting that the current is higher than the cheapies (not had a meter in circuit yet to check the actual currents) . This drive was more expensive, but not outrageously so (£13 delivered versus £5-6 each for the cheapies) but is rated for 50 V DC supply or 36V AC compared to 30 or 40V for the others - I have yet to try a 48V supply with the Stepperonline drive, as it only arrived last week.
Testing so far has not involved driving anything, just the motor alone being driven while hand held (the resonance can be so bad with the cheapies it dances about on my desk) & it may be that adding a driven load will change things (just adding an aluminium pullley changed the resonance somewhat).
Nigel B.
SillyOldDuffer06/03/2020 11:27:44
10668 forum posts
2415 photos
Powering a stepper isn't straightforward in that most cheap PSUs are switch-mode stabilised types carefully designed to maintain a steady output voltage into a moderately well-behaved load. The one I use is designed to drive a string of LED lamps and the PSU doesn't perform any electrical acrobatics.
A stepper motor is a very different load. It's fed pulses. For speedy step response, the pulse should start at relatively high-voltage but then concentrate on delivering a short burst of amps. The volts don't need to be stabilised. The PSU needed to run a stepper is relatively simple, a big transformer, rectifier and capacitor. Unfortunately, these are hard to find and pricey. Big transformers are expensive, and because most of the world wants stabilised volts, most cheap PSUs are switch-mode stabilised types. While they will usually run a stepper, they don't do it well, and sometimes shutdown entirely because a stepper pulse can be mistaken for a short-circuit.
Can anyone recommend a suitable cheap supply?
All steppers I've used suffer from resonance. Worse when run unloaded on a table, but can be annoying at certain speeds when mounted on a machine. Rattle dampers are easy to make, not sure how effective they are because this one is unfinished.
Each hole contains a slightly loose fitting 10mm ball bearing. The idea is they break up resonances by bouncing around inside - when a resonance causes the wheel to decelerate, their inertia reduces the effect. Likewise, they slow short sharp accelerations by soaking up energy.
As shown the rattler noticeably reduces resonance but the holes should be filled with oil to dampen the balls and sealed with a cover.
Need to make another one - there's a broken tap in one of the cover threads, I shouldn't have chamfered the top (it wasn't on my drawing!), and I carelessly misaligned the fixing screw hole so it broke into one of the chambers.
I've no idea what theory says about optimising the design. There must be a relationship between resonance and the number and weight of the balls arranged in a particular diameter. Hopefully it's not critical. Anybody understand how to design rattle dampers?
Joseph Noci 106/03/2020 13:12:16
1323 forum posts
1431 photos
I did quite a bit of work on the 'rattle dampers' - fitted one to each axis of my small CNC router, which upped the rapids hugely Also fitted one to the stepper on my rotary table/hobber, which likewise upped the max rates tremendously. For the life of me I cannot find it in all my posts on this forum! No search mechanism here helps...
Anyway, I don't wish to contaminate this thread with info on all that, but to extract the available torque from a stepper requires that the correct supply voltage be used - as high as possible - to overcome Di/Dt at high(er) rpm's, where torque will fall anyway, but if the supply volts are as high as possible, at least that will not cause premature loss of torque.
Another critical element is stepper acceleration. If accelerated very slowly you would normally not have any issues - and unless really undersized, no steps easily lost. This would be the typical use in an auto-feed say on a mill axis, where acceleration is not normally an issue. It is a different matter on a NC application, where rapid moves are at high(er) speed, so acceleration tuning becomes key.
However, a stepper can also lose steps, and even start to go in reverse(!) when it hits bad mechanical resonance.
Coupling the stepper to the machine shifts the resonance point, but it is still there. Coping with this resonance is achieved in two ways - acceleration through the resonance point(s) as quickly as possible, fitting a flywheel to force the rotor through the resonance without stalling, or fitting a viscous or rattle damper.
There is a lot of info available of the design of a viscous damper, and they work very well - are the best type. However, it is still almost impossible to design one in the hobby shop, as you need to know so many paramaters regarding the machine the stepper is driving - all inertial masses, friction coefficient, damping constants, stiction, etc - nigh on impossible for the hobby man to measure.
My rattle dampers were a fair suck on both thumbs - first I found the resonance point of the system ( stpper mounted on the machine) where the stepper would stall or lose steps. Then I added a plain flywheel and sized that till it no longer occurred. Then search for new resonance point and change the flywheel circumferential mass till that resonance no longer caused a stall - then checked the first resonance point, etc...
When resonance was no longer an issue of concern, I then pushed the stepper acceleration , till it stalled or lost steps, and then drilled out that flywheel and fitted mild steel slugs - rods - as close to the periphery as practical. I found the acceleration achieved was then easily 2 to 3 times more, before problems reappeared.
Unlike the viscous damper, there is NO design info, patent, or published science on the rattle damper..
But is does work very well indeed, even if you have to become a little infantile and suck your thumb.
I have no idea if my 'design' is optimal, or what can be done to make it better, but the concept does seem to be effective over a broad design envelope, and very forgiving of error margins. But do the flywheel versus resonance thing first - the flywheel alone already enabled around a 1.2 to 1.5 times acceleration increase.
High stepper acceleration is not required as all, for powered axis drives, lathe auto-feed drives, mill Z axis raising, etc. I doubt you will need more than a 2NM stepper to lift the bench top mill Z axis, with a good ratio drive between stepp and leadscrew. If you accelerate slowly all will be fine.
However, electronic threading on the lathe, or gear hobbing is different. When pushing the envelope - high RPM ( 150 to 400) and large thread pitches ( 3mm say) require that the stepper accelerate the leadscrew ( and carriage) very rapidly to ensure the cutting tool and thread being cut are in synch when starting to cut the thread. Lost steps here are a major pain.
And there's the dissertation again. I have a few very detailed posts on these subjects, on the forum - can't find them...penalty for posting to much rubbish.
Joe
blowlamp06/03/2020 13:55:37
1885 forum posts
111 photos
The last two posts from Dave and Joe are the reason I went with 'hybrid' stepper motors & drivers.
My lathe suffered badly from resonance and losts steps, so something needed to be done about it.
I too explored the idea of going down the damper route, only the results seemed unpredictable as well as adding to more installation headaches.
I came across steppers with feedback (hybrid), decided to buy two and after fitting, everything came right. No more vibration and no more unnoticed missed steps. The 'intelligent' driver constantly monitors & compensates motor position and varies electrical requirement according to conditions.
In use, I've had no missed steps at all and happily sail on with my machining, knowing that if an unresolvable error should occur due to a position fault, then the driver will power down to alert me.
I also found that acceleration could be ramped up along with higher traverse speeds as well. Movement is very smooth and quiet.
As for the power supply, my toroidal transformer packed up this week so after looking here I gambled on one of these and it is working well so far despite the seemingly poor feedback. smiley
Martin.
Edited By blowlamp on 06/03/2020 13:57:04
duncan webster06/03/2020 13:56:35
5307 forum posts
83 photos
Link to Joe's rattle damper
scroll down to 07/11/18
mgnbuk06/03/2020 14:06:56
1394 forum posts
103 photos
The "link" doesn't appear to go anywhere ?
I thought those were refered to as "closed loop" steppers, rather than "hybrid" ?
There appear to be a couple of suppliers of "off the shelf" viscous dampers (Vexta & Lin Engineering) but both appear to be US based & I have not yet come across a UK source. Rattle dampers seem easy enough to make (though trial & error as suggested by Joe) - maybe Dave could 3D print a hub & try one out made that way ?
My interest is driving a Denford Triac CNC vertical mill, with the initial control system being an Arduino running GRBL fed by a Raspberry Pi 3+
Nigel B.
blowlamp06/03/2020 15:28:05
1885 forum posts
111 photos
Posted by mgnbuk on 06/03/2020 14:06:56:
Nigel B.
Just interchangeable terms, I think.
Martin.
duncan webster06/03/2020 15:56:48
5307 forum posts
83 photos
missing link (no not me)
I've just clicked it and it worked for me, scroll down to 07/11/18
Edited By duncan webster on 06/03/2020 15:59:20
Kevin McCartney06/03/2020 17:34:51
9 forum posts
9 photos
Thank you for all of your replies and information.
I have gone for a hybrid NEMA 24 4Nm hybrid kit from omc-stepperonline, shipping from Germany. Maybe a little overkill, but the physical difference between the 23 and 24 doesn't make a lot of difference to the location preferred - if the jump up to a 34 had been required for more torque I would have needed to rethink the fitting location.
The PSU discussion is interesting - Cough42 uses a switched mode with some spare capacity over the needed spec. This seems to work although I realise a hefty linear one is probably better in the long run.
Watch this space....
Kevin
SillyOldDuffer06/03/2020 18:04:44
10668 forum posts
2415 photos
Posted by Kevin McCartney on 06/03/2020 17:34:51:
Kevin
Me and Cough42 both, and this switched-mode type has worked reasonably well for me twice (Just an example - choose one with volts and amps to suit the motor.)
For about twice the price, say £60, it would be possible to buy a toroid transformer, rectifier, capacitor, box, fuse, and grommets etc and build an unregulated power supply that would do a better job. I noticed Duncan Webster went that way with his ELS build, pics posted 25 Feb in the workshop progress thread.
Very little in this arrangement to stop power being pulsed straight into the motor, exactly as wanted.
Martin Connelly06/03/2020 21:29:39
2549 forum posts
235 photos
Temperature of stepper motors is not a good guide to a good system. As hybrid steppers monitor position the matched drivers back off the current when they are stationary so in practice do not get hot doing nothing.
Like Blowlamp my experience with hybrid closed loop stepper systems is no resonance on lathe or mill.
Martin C
duncan webster06/03/2020 23:07:43
5307 forum posts
83 photos
I chose to use the toroidal transformer because I had it! I've got at least one more somewhere, my ex employer liked throwing good stuff in the skip.
