Bulbs
My current pet hate
Speedy Builder517/02/2020 11:10:28
2878 forum posts
248 photos
When I were a lad, we had 4 types of bulb in the house - all bayonet type, 40 watt,65,100 and candle bulbs. That was it, a few spare in the cupboard. Now we have bayonets, Edison large screw, small screw even bare wire ones, and don't even go down the pretty flickering ones, ones for ovens, fridges, LED, Halogen etc etc. AND don't forget low voltage ones
If that wasn't bad enough, you often have to buy packs of 2 or 3.
The lighting world has gone MAD !
Martin Kyte17/02/2020 11:17:42
3445 forum posts
62 photos
Used to be a single size gas mantle, before that it was just a flare. Even oil lamps had different sized wicks.
You could always go back to candles or even just go to bed when it gets dark.
regards Martin
Harry Wilkes17/02/2020 11:17:45
1613 forum posts
72 photos
Posted by Speedy Builder5 on 17/02/2020 11:10:28:
Gone mad maybe greed got something to do with it as well !
H
roy entwistle17/02/2020 11:18:00
1716 forum posts
I was always told that Bulbs are for planting, Lamps are for lighting
Roy cheeky
Martin Connelly17/02/2020 11:28:54
2549 forum posts
235 photos
Torch bulbs? They had Eddison screw and pre-focus and multiple voltages.
I was brought up in a Victorian mid-terrace that had been retrofitted with electricity and wired up by my uncle. There were two fuses in the fuse box, power and light, one socket in the two downstairs rooms, two in the kitchen, none in the pantry and none in the four bedrooms. If you wanted power in the bedrooms you had to run things off the light socket via a y adaptor with a pull cord for the light. As all the light sockets were put in at the same time they were all the same type, bayonet connectors. As there was a lack of power sockets we had no table lamps or standard lamps so no need for special bulbs for them. We had not replaced the hanging bayonet sockets on twisted twin purple cotton covered wiring so did not need specials for them either. The light switches were all round, brown bakelite on a wooden pattress fed by wiring that was mounted on the surface of the lath and plaster walls and covered with wooden trunking.
I prefer the options we have now and accept the possibility that if I change the lighting to miniature flush mounted spotlights that I will need something other than a large bayonet mounted bulb.
Martin
Edited By Martin Connelly on 17/02/2020 11:32:12
Bazyle17/02/2020 14:12:50
6956 forum posts
229 photos
Posted by Martin Kyte on 17/02/2020 11:17:42:
Would that be tallow or beeswax or synthetic wax and what diameter and length. Perhaps the Roman ones calibrated in hours which of course vary in length by season as they divided the night into the same number of hours regardless of the length of the darkness.
Edited By Bazyle on 17/02/2020 14:14:50
Swarf, Mostly!17/02/2020 15:22:38
753 forum posts
80 photos
A prominent microscopist of my (cyber) acquaintance sings the praises of whale oil.
I was going to write ' ... takes a lot of beating' but a beating is what you might get if you try to procure any!!
Best regards,
Swarf, Mostly!
PS: Not you, Michael, same first name initial but different first name.
Brian G17/02/2020 15:23:01
912 forum posts
40 photos
We may have had less types of light bulb, but we made up for it with six different non-interchangeable domestic power plugs (two pin and three pin in 2A, 5A and 15A sizes). Plus of course that bayonet plug that fitted into a bulb holder, a hangover from the days before electricity meters when consumers were charged per light fitting or socket, and the proprietary (and expensive) plugs needed for council houses with non-standard sockets.
People would go to extreme lengths to keep the bill down, many years ago, when my father was asked to wire a house for the first time he was told not to put a light fitting in the front bedroom as there was a lamp post outside.
Brian G
Dennis Rayner17/02/2020 15:29:05
137 forum posts
9 photos
And try explaining to older folk that you don't buy bulbs by wattage anymore - it's LUMENS!!
Howard Lewis17/02/2020 15:38:16
7227 forum posts
21 photos
Ah, lights that get on one's wick, even if they are not paraffin (kerosene ) fuelled! An aunt who lived out of town, beyond the reaches of the new fangled electrickery was a most accomplished cook with a paraffin heated oven.
Another aunt still used her Aga despite the farm having three phase power available.
Neil Wyatt17/02/2020 15:54:34
19226 forum posts
749 photos
86 articles
Most illuminating.
Harry Wilkes17/02/2020 15:58:05
1613 forum posts
72 photos
Posted by roy entwistle on 17/02/2020 11:18:00:
Roy cheeky
Or "ornamental bulbous plants" wink
H
SillyOldDuffer17/02/2020 16:06:52
10668 forum posts
2415 photos
Posted by Dennis Rayner on 17/02/2020 15:29:05:
Even worse, we can no longer hint a friend is dim by suggesting he's a 40W bulb. Even Einstein wasn't as bright as a 40W LED!
Andrew Tinsley17/02/2020 16:08:13
1817 forum posts
The problem of differing lamp base sizes.is all to do with the odd bayonet size that was a UK standard. I am not aware that it is used anywhere else. When we import large amounts of light fitings they are mainly intended for the major areas of the world which have Edison screw as a lighting standard.
As for only being available in packets of 2 or 3, I cannot agree. All of my local supermarkets sell lamps as singles. A couple of them have packs which are a saving over buying them as singles.
Andrew.
Nick Clarke 317/02/2020 16:18:22
1607 forum posts
69 photos
Roy cheeky
You can always plant an electric light bulb.
It won't grow, but you can always plant it laugh
SillyOldDuffer17/02/2020 19:56:56
10668 forum posts
2415 photos
How many Model Engineers does it take to change a light bulb?
None. Best practice is to keep She Who Must Be Obeyed in the dark.
Speedy Builder517/02/2020 20:01:45
2878 forum posts
248 photos
It used to be - UK was bayonet and France was Edison screw in - now everyone has both - "We are doomed Captain Mannering"
J Hancock17/02/2020 20:17:21
869 forum posts
One of my favourite jobs, feet on a salt rusted ring, safety clip on a similar ring, leaning backwards ,40ft up a cargo mast overhanging an 80ft drop into an empty cargo hold , to change a 500W GES lamp !
Did we really do this ?
Mike Poole17/02/2020 21:31:25
3676 forum posts
82 photos
Posted by SillyOldDuffer on 17/02/2020 16:06:52:
I thought dimness was measured against a Toc H lampsmiley
