Needing source of Stoneder clutch pads or similar
ken king, King Design | 05/02/2020 20:59:39 |
![]() 144 forum posts 239 photos | I'd like to get hold of some Stoneder centrifugal clutch pads, or similar product, to fit inside a 52mm drum or thereabouts. A couple of suppliers I've tried list them, but out of stock. Any suggestions will be gratefully received. Dimensions are not carved in stone, early design days so can be flexible. |
AlanW | 09/02/2020 17:41:40 |
92 forum posts 12 photos | If you can't source any, would there be enough material in a car disk brake pad to machine some? Of course you would need to wear appropriate ppe. Another possible option may be to machine from a hard wood like oak, although tey probably wouldn't last long. Alan |
clogs | 09/02/2020 18:56:56 |
630 forum posts 12 photos | there are specialist clutch n brake material suppliers........ I often have to resort to these people for help with antique machines...... ALSO dont forget tractors, industrial machines n cranes use block friction pads in the jib.... just google what u want but don't name the product......or friction material suppliers...... |
ken king, King Design | 09/02/2020 20:46:45 |
![]() 144 forum posts 239 photos | Thanks AlanW and clogs for your suggestions. The thing is, I'm not just after some friction pad material, but Stoneder or similar centrifugal clutch parts which comprise a metal shoe with pivot hole, and friction material on the outside face. These would lend themselves perfectly to my intended used as brake shoes in wheel hubs of a large RC model aircraft . If I can find a supplier it will save a lot of fabrication effort. I haven't given up, I know they are out there, Thanks again, Ken |
John Baron | 09/02/2020 21:46:34 |
![]() 520 forum posts 194 photos | Hi Ken, Hotpoint top loading washing machines used a metal backed centrifugal clutch as you described and later went on to use plastic ones which didn't require the mazak metal backing. A pair were contained in a cast iron cup about four inches in diameter.
Spurry | 09/02/2020 23:06:20 |
227 forum posts 72 photos | Sounds just like the setup for clutch in RC model helicopters. Pete |
I.M. OUTAHERE | 09/02/2020 23:34:45 |
1468 forum posts 3 photos | Maybe the centrifugal clutch shoes from a 1/5 scale Baja buggy would do the job ? you should be able to get them via ebay or a local rc car / hobby store . i think the shoes from a line trimmer would be a bit big as would be the shoes from a mini dirt monkey bike but you could also check them out - once again ebay is where i would start as some of the sellers do have stores that sell to the public if you don’t like buying through ebay . |
mike T | 10/02/2020 01:39:47 |
221 forum posts 1 photos | Search on e-bay for "FG clutch". You can find the clutch bell (brake drum) and the shoes all for 52mm diameter.
Mike |
pgk pgk | 10/02/2020 04:21:30 |
2661 forum posts 294 photos | Posted by Spurry on 09/02/2020 23:06:20:
Sounds just like the setup for clutch in RC model helicopters. Pete My RC helis had the clutch bell lined to be gripped by a spinning shoe. Zenoah small engines have sprung clutch shoes with friction material attached to the shoe: zenoah small engines pgk |
ken king, King Design | 10/02/2020 11:12:08 |
![]() 144 forum posts 239 photos | My thanks to all responders to my request. Between you I've been supplied with several sources for these parts. Just goes to show, when you know where to look......., and now I do. Thanks again, Ken |
