Mini mill riser block
Bob Perkins29/01/2020 20:27:43
249 forum posts
60 photos
Hi all
I would be interested to have some feedback on your thoughts, experience or comments on fitting a 50mm riser block at the base of the column of a mini mill to add a bit more distance between the spindle and table.
thanks
Bob
old mart29/01/2020 20:33:16
4655 forum posts
304 photos
Good idea, you might even consider 75mm , but the existing height, quill movement and lowest clearance while milling very low work have to be taken into consideration.
Phil H129/01/2020 20:48:02
467 forum posts
60 photos
Bob,
I will keep an eye on this thread. I have a Chester 16V with quite a restriction on the spindle table distance - specially if I try to use a rotary table with 3 jaw chuck and drill chuck. I usually need to transfer over to my bench drill.
The column is detachable - so it is possible (a spacer) but spacers would also be needed to raise the vice to ensure the milling cutter goes low enough - as old mart points out.
Phil H
Dave Halford29/01/2020 20:48:33
2536 forum posts
24 photos
Or to put it another way.
You may need a raiser block for the milling vice as well for some small jobs smiley
Bob Perkins29/01/2020 20:54:12
249 forum posts
60 photos
Hi Phil H
I think there will be adequate travel on the spindle. I'm looking to overcome similar issues when I'm using a rotary table in the horizontal or vertical. I bought an 80mm swivel vice at the Ally Pally, and it's great, but has reduced the clearance I have a bit more than my old vice.
not done it yet29/01/2020 21:04:29
7517 forum posts
20 photos
Posted by Dave Halford on 29/01/2020 20:48:33:
Or buy a vise with a rotating base - or rather one that is mounted on a base. Most discard the base for sundry reasons.🙂
old mart29/01/2020 21:08:04
4655 forum posts
304 photos
You get the best of both worlds having a raiser block for the vise as well as the column. On a small mill, both blocks could be made from aluminium. A swivel base for a vise comes come in useful occasionally, and, as mentioned, adds height. Most vises with a base will fit on the table without the base.
Edited By old mart on 29/01/2020 21:13:00
