A question of beat
Sam Stones28/01/2020 02:38:30
922 forum posts
332 photos
As a one-clock ‘expert’, I have often wondered why the late Mr John Stevens, in designing his skeleton clock with English lever escapement, chose wheels and pinions that produced a beat of 0.893 seconds instead of a very handy 1.0 beat per second.
In a simple spreadsheet for determining the ratios of the existing wheels and pinions while leaving the number of pinion teeth alone, I tested the feasibility.
With little more than intuition I changed three of the wheels from 84, 72, and 56 teeth down to 80, 70, and 54. I was amazed that it took so little effort.
Apart from shifting the arbor centres, slightly increasing the mass of the balance wheel, and/or using a slightly ‘softer’ balance spring, I can see no other obstacle.
Unless I’m off the beam for some reason I could (just for fun) make new wheels and even grab parts from my CAD file.Isometric of the Whole Clock
Any thoughts?
Sam
Edited By Sam Stones on 28/01/2020 02:45:45
not done it yet28/01/2020 06:40:09
7517 forum posts
20 photos
Perhaps he found the 0.893 seconds per beat was more pleasing, to his ear, than only once per second? Certainly can’t so easily count ticks for a minute period!
As a matter of interest, do all other clock designs have a beat of 1.0 seconds?
Mathematically, the 0.893s is to one more significant figure, so should be more accurate than one only to two significant figures - or did you mean 1.00s?🙂
As this makes absolutely no difference to the time-keeping, does it really matter that much? A design simply needs to accurately mirror the true time of day.
Do these tooth counts require fewer set-ups or cutters than other tooth counts?
I would particularly frown on the use of smaller pinions being sized as a factor of the larger wheel it contacts. Any comment on this?
As only a clock repair ‘bodger’, I’m not particularly qualified to make too many meaningful comments (just to make it clear to those that are ‘funny’ about replies). Last comment is that it does show that a one second beat is not the ‘be all and end all’ of clock making.🙂
John Haine28/01/2020 07:24:23
5563 forum posts
322 photos
Unlike a pendulum I guess making a balance for a specific period is rather hard unless you have a lot of data on the spring material etc. So maybe he started with the balance and designed the train to suit?
Michael Gilligan28/01/2020 09:31:26
23121 forum posts
1360 photos
Posted by not done it yet on 28/01/2020 06:40:09:
Yes, one comment: ... Sam wrote:
“ In a simple spreadsheet for determining the ratios of the existing wheels and pinions while leaving the number of pinion teeth alone, I tested the feasibility. “
[my emboldening, for emphasis]
John Haine28/01/2020 09:36:31
5563 forum posts
322 photos
Well, they are always going to be a "factor" surely, since both have integer numbers of teeth? Was the point to try to make sure that they are relatively prime (if possible) to distribute wear evenly, or something like that? In any case you have to have specific ratios between hour and minute, and minute and seconds hand, if it has one.
Michael Gilligan28/01/2020 09:39:21
23121 forum posts
1360 photos
dont know
For anything reasonably approximating accurate time-of-day-keeping we need many more orders of magnitude better than either of those representations. [so, of course, they are both very rough approximations]
SillyOldDuffer28/01/2020 10:46:44
10668 forum posts
2415 photos
Just a suggestion as I've only made two clocks, both out of Meccano and one didn't work!
However the principle of all mechanical clocks is the same: an accurate oscillator, such as a pendulum, counts out steps allowing a gear train to translate a power source (spring or dropping weight) into a spindle turning at a known rate useful to humans, such as one rotation per hour.
Getting the required human rate is achieved by altering the period of the oscillator and the ratios of the gear train to get the required result. Designing the gear train is a little tough: clocks call for big ratios, ie small pinions engaging big wheels, and this is a challenge because there's a mechanical limit. Pinions with less than, say, 12 teeth are in the danger zone, and 6 teeth is probably the practical minimum. Friction rises and pinion teeth have to be undercut. Then, because gears only do integer division, there are limits to the number of gear combinations that achieve the desired ratios.
Sam's picture of Mr Steven's gear train shows a sensible combination of gears, in particular he avoids small pinions. But I think the reason for the 0.893s period lies in the Balance Wheel, which isn't shown.
Not mechanically difficult to make a pendulum oscillate at any reasonable period. The disadvantage is they take up a lot of space, and dislike vibration. Balance wheels can be made much smaller, and they don't mind if the clock is moved. But they're much more complicated to design. They also have mechanical limits: small and light is best for timing accuracy and low friction but they have to store enough energy to work the escapement. A big, heavy balance wheel will happily drive the escapement, but it will hammer the bearings, and need more effort to maintain oscillation which will spoil the time-keeping.
Sam said 'I have often wondered why the late Mr John Stevens, in designing his skeleton clock with English lever escapement, chose wheels and pinions that produced a beat of 0.893 seconds instead of a very handy 1.0 beat per second.' More the other way round I think. 0.893s is in the the zone that allows a sensible balance wheel and there's a sensible integer gear train to bring it to 1 revolution per hour. I think Mr Steven's clock brings together a practically sized balance wheel with an equally practical gear train. Not necessary for him to start with a neat round number oscillator, or even desirable to do so. Once the maths are understood, it's possible to design clocks so the mechanical details are optimised as a whole to improve timing, reduce wear, and simplify the movement.
Edited By SillyOldDuffer on 28/01/2020 10:50:25
Michael Gilligan28/01/2020 11:21:25
23121 forum posts
1360 photos
Posted by John Haine on 28/01/2020 09:36:31:
Well, they are always going to be a "factor" surely […]
I’m not sure if that ^^^ was intended as a comment on my response to ndiy, John
If so, I must emphasise that Sam computed his new train for the existing pinions.
If not ... please ignore this interjection
not done it yet28/01/2020 11:49:55
7517 forum posts
20 photos
Factors are whole numbers which will divide into the other number by a whole number. All primes, other than two, have only two factors.
Using factors is bad practice with gear sets, as the same teeth will be engaging every revolution. Far better for even wear is to have the gears wearing with any of the teeth wearing against all the teeth on the other gear.
You never had an exact 4.00 differential in your car - it would wear much better and evenly if the ratio were the pinion teeth multiplied by an integer, then plus (or minus) one for the crown wheel. A much higher rotational speed and power, but the same physical principles still apply - but clearly ignored in the clock movement exampled.
John Haine28/01/2020 12:20:15
5563 forum posts
322 photos
Yes I do know what a factor is, thanks. It was just the expression that puzzled me. Quite common I think to see a 60:1 ratio as an 8:60 x 8x64 teeth = 7.5 x 8 = 60.
Michael Gilligan28/01/2020 12:21:13
23121 forum posts
1360 photos
Posted by not done it yet on 28/01/2020 11:49:55:
Factors are whole numbers which will divide into the other number by a whole number. […]
Apologies ... I evidently misinterpreted your usage of the word ‘factor’ in your first response.
I wrongly thought that you were saying that the number of of teeth on the pinions would be a relevant factor [rather than a mathematical one].
not done it yet28/01/2020 15:47:58
7517 forum posts
20 photos
Let me put it another way.
It is bad practice to make gears pairs with whole number ratios.
Is that more clearly understood? I don’t design gear boxes or anything like that and maybe clock makers ignore the principle (that gears pairs should not run on the same teeth for the whole life of the machine). Comments? I’d like to know if they do (and if they do, why?).
Michael Gilligan28/01/2020 16:07:36
23121 forum posts
1360 photos
Posted by not done it yet on 28/01/2020 15:47:58:
Agreed ...
https://www.mobiusinstitute.com/site2/item.asp?LinkID=8062&iVibe=1&sTitle=Gearbox
Edited By Michael Gilligan on 28/01/2020 16:08:03
Bazyle28/01/2020 18:02:18
6956 forum posts
229 photos
Yes they do in the motion work. Getting that 12:1 ratio is not easy in two stages when limited to pinions probably of 8, 9, 10, 11, 12 so tend to use 3:1 x 4:1.
There are combinations with factors of, 2.2 or 3.3 that work with 2.4, 2.5, and 3.2 as runners up.
Michael Gilligan28/01/2020 18:23:27
23121 forum posts
1360 photos
Posted by Bazyle on 28/01/2020 18:02:18:
Yes they do in the motion work. Getting that 12:1 ratio is not easy […]
Which is, of course, one of the reasons why clocks in the ‘Regulator’ class typically omit motion work.
John Haine28/01/2020 22:24:13
5563 forum posts
322 photos
Well a pair of gears is bound to have a whole number ratio surely!
In the motion work as opposed to the going train the gears carry very little load.
Neil Wyatt28/01/2020 22:37:35
19226 forum posts
749 photos
86 articles
Maybe he made a balance wheel, tested it, then mcame up with a train that worked for its practical range of adjustment.
Michael Gilligan28/01/2020 23:12:12
23121 forum posts
1360 photos
Posted by John Haine on 28/01/2020 22:24:13:
So ... What are the various whole number ratios between the wheels and pinions in Sam’s first picture ?
Ratio being, by convention, expressed as N to 1
[ tried to use a colon, but that generated a stupid smiley thing ]
Edited By Michael Gilligan on 28/01/2020 23:40:43
Sam Stones29/01/2020 01:53:40
922 forum posts
332 photos
What a wealth of responses and information. Where do I start?
I think it might be easier (for me at least), to address some of these in separate postings.
I'll be back!
Sam
Sam Stones29/01/2020 03:52:41
922 forum posts
332 photos
NDIY – I enjoyed your replies, so here are my thoughts.
Q. Pleasing to his ear? Perhaps it was. Maybe he didn’t have a preference for the pace of a military beat 120bpm (shades of square-bashing). Personally, I enjoy a good brass or military band.
The ratios the designer selected were 8.4:1, 8:1, and 4:1. The calculated beat (per ‘scape wheel tooth) is 0.892666(recurring) seconds. Whatever reason crossed my mind, I resisted the temptation to quote #1 followed by a string of zeros.
Unintentionally, the three ratios emerging from my choice of wheel teeth were …
8:1, 7.777778:1, and 3.857143:1. Not bad for little effort
Q. Do ALL other clock designs beat at 1.0s?
My guesses …, in not knowing much about clocks would be …
Antique clocks? … not many … apart from longcase (pendulums close to 1 metre).
Electric clocks? … Hummm? … locked into mains frequency at 50 or 60cps.
Quartz clocks? … most of them that I’ve heard ticking ... [sourced from a 2^15 crystal.]
I agree that none of it (i.e. the ratios) really matters other than that the clock keeps accurate time which, as I found out while building and setting up the clock, is another story altogether.
I chose to refrain from ‘messing’ with the pinion count. Other than a 6-leaf pinion onto a 72 tooth (motion work) wheel, the drive train for the Stevens clock uses lantern pinions.
It seems I've overrun the number of characters ... I'll be back.
