Special nuts: Any name to what I may need?
Richard Rogalewski10/01/2020 20:15:30
72 forum posts
14 photos
Hi. I need to bolt on a 25mm square bar to the side of something. An M6 stud protrudes from a surface and that will go through a hole made in the square tube. But, I have a small problem: The stud is rather short, it does not protude beyond the surface of the tube, so I cannot use a regular nut on the stud.
I need something like a thumb screw, which will recess into the tube and make contact with the stud. The length of the shank of the thumb screw needs to be 25mm or so. I've not yet found a suitable thumb screw. If not a thumb screw I need something very similar, perhaps with an hexagonal head. Do such things exist? Things like thumb screws, but with hexagonal heads? Thanks. Rich
michael darby10/01/2020 20:18:42
48 forum posts
You could open the top hole and use a regular nut tightened with a socket
JasonB10/01/2020 20:26:04
Sleeve nut, barrel nut and Joint connector would be suitable searches
michael darby10/01/2020 20:26:23
48 forum posts
Sorry, thinking of box section. You could always counterbore the bar and fit a nut in the recess
Robert Atkinson 210/01/2020 20:27:37
1891 forum posts
37 photos
How about a joint connector nut
www.screwfix.com/p/joint-connector-nuts-m6-x-17mm-50-pack/83521
www.screwfix.com/p/joint-connector-nuts-m6-x-12mm-50-pack/83501
Robert G8RPI.
Robert Atkinson 210/01/2020 20:28:31
1891 forum posts
37 photos
JasonB beat me to it!
Richard Rogalewski11/01/2020 12:59:32
72 forum posts
14 photos
Hi. Sorry, I said "bar" at one point, and meant to say "tube". Or perhaps it's better to say "box section". Also, the stud is M8 not M6. Thanks for the suggestions. I know what I would do if I had a lathe and M8 hexagonal threaded spacer - I'd turn the spacer just leaving the end as the hexagonal head. Now Googling for "Joint Connector Nut M8". Sleeve part of nut needs to be about 25mm long. Don't think I'll find one at 25mm
Edited By Richard Rogalewski on 11/01/2020 13:10:34
Edited By Richard Rogalewski on 11/01/2020 13:23:14
Richard Rogalewski11/01/2020 14:23:39
72 forum posts
14 photos
My best search result:
M8x22 Sleeve nut
According to my drawing, which is a drawing of a machine I have, so measurements are by way of my using a ruler to measure distances, if the sleeve is 22mm long, which I belive it is, the sleeeve nut will screw into the stud 5mm. That ought to be enough, because the box section I'm attaching is only being held in place, it's not taking a load.
Edited By Richard Rogalewski on 11/01/2020 14:25:30
michael darby11/01/2020 15:55:27
48 forum posts
At 5mm you wont have much holding it. The stud will be tapered to allow the cutter to start the thread and the nut likewise
Michael Gilligan11/01/2020 19:22:05
23121 forum posts
1360 photos
Posted by Richard Rogalewski on 11/01/2020 14:23:39:
M8x22 Sleeve nut
It should be quite easy to make a good sleeve nut from a long M8 hex socket screw [which will have a suitable length of plain shank].
Richard Rogalewski11/01/2020 22:40:38
72 forum posts
14 photos
M8x30 Barrel Nut TORX
Probably OK for length. 5 for £9.99
Actually, in it's simplest incarnation all I need is threaded sleeve rod/spacer, that screws into the stud, and I attach the box section by screwing into that sleeve an M8 screw.  Probably my cheapest option.
Edited By Richard Rogalewski on 11/01/2020 23:01:07
Michael Gilligan11/01/2020 22:50:47
23121 forum posts
1360 photos
Posted by Michael Gilligan on 11/01/2020 19:22:05:.
Oops ... Just noticed your increase from M6 to M8 blush
Please increment my suggestion accordingly.
’though I think Richard’s find trumps it anyway.
Richard Rogalewski11/01/2020 23:37:15
72 forum posts
14 photos
OK, I just bought 5x M8x40 threaded spacer for £3.50. I'll just use a spacer and an M8 hex screw. Might even try to weld the screw to the spacer. So, that's about it for this thread. Rich
