new gear for Fortis lathe
Missing teeth
vic donnelly20/11/2019 18:42:59
4 forum posts
I have found that I have a number of teeth missing from one of my feed screw gears (aprox 6.25" 93 teeth) the lathe seems to be well worth a replacement, so I am looking for a machine shop to make one to pattern. Any advice would be appreciated. Thanks Vic Donnelly
not done it yet20/11/2019 23:46:04
7517 forum posts
20 photos
Are the missing teeth in one group or singly? Singles are easy to repair, groups a little more difficult (but not impossible).
Chris Evans 621/11/2019 09:22:45
2156 forum posts
Have a look on HPC gears website, they may have a standard or be able to make you one. They are based in Chesterfield UK.
Howard Lewis21/11/2019 12:25:38
7227 forum posts
21 photos
Don't know the lathe, (According to Lathes UK, it is based on the Clausing ) but 93 teeth and 6.25 diameter looks like 15 DP, if Imperial.
15 DP would be 6.33333 diameter 16DP would be 5.9375 diameter. 14 DP would be 6.785 diameter
Measure the OD of the gear(s ) with which it meshes, and count the teeth OD + (N+2 ) / DP, so DP = (N+2 ) / OD
If the gears are Metric, they will be Mod. so that Mod = Pitch Circle Diameter / N.
Where PDM is in mm, and N = No of teeth.
I fear that buying a gear may be expensive, and it will then need modification to fit onto the lathe...
Are you able to turn up a blank and cut the gear yourself? You will need a No.2 Brown and Sharpe cutter to do this. Someone like RDG or Tracy Tools could probably provide one for around £25.
Stating the obvious, to ensure concentricity, the blank should remain on the arbor when it is moved from the lathe to the Milling machine for cutting the teeth.
If not, is there a member of your club who would do this for you?
ega21/11/2019 14:18:01
2805 forum posts
219 photos
I see that GHT's dividing tools will do 93 divisions.
Howard Lewis22/11/2019 12:00:00
7227 forum posts
21 photos
So will a Vertex HV6 Rotary Table. You need 30 holes on a 31 hole circle on the B plate, per division (tooth ).
Marischal Ellis22/11/2019 13:03:49
77 forum posts
27 photos
Hi Vic
I had a couple of gears cut for 'my' Fortis a few years ago by Glasgow engineers, straight forward and painless. I cannot remember the DP and so on I worked out but will see what I have left after my recent tidy up. Let me know if Glasgow is suitable or within posting range.
M
Pete Rimmer22/11/2019 13:43:25
1486 forum posts
105 photos
Posted by vic donnelly on 20/11/2019 18:42:59:
Vic are you sure that it's 93 teeth and not 98? A stamped 8 often looks like a 3.
A 98 tooth 16DP gear would be 6.25" diameter exactly.
Bazyle22/11/2019 14:14:09
6956 forum posts
229 photos
Are you sure it's 93. - count again. Introducing a prime of 31 into a gear chain makes no sense at all. If the number 93 is cast onto the gear it might just be the part No, I have some gears like that just to confuse.
I assume it is the same as the pictures on Lathes.co.uk so this gear meshes with a smaller one on the gearbox input and they would be best as a 4:1 ratio. 96 or 92 are much better options. If 92 then the other two gears can be a 2:1 ratio for which 38:76 fits nicely.
Howard Lewis22/11/2019 15:40:44
7227 forum posts
21 photos
PM from OP revising tooth count to 95 and OD leads me to believe that it is 16 DP. But what pressure angle? 14.5 like Myford or 20 degrees?
Does anyone know for certain?
Brian Wood22/11/2019 17:03:03
2742 forum posts
39 photos
Howard,
These lathes were produced in the 1940s and 50s so I would imagine them to be 14.5 degree pressure angle. Furthermore, they were I believe based on the US Clausing of the 1940s which would almost certainly have been made to that PA.
I think it a fair bet that the 'clone' would be as little changed from original as possible.
I hope that helps
Regards Brian
Howard Lewis22/11/2019 17:19:56
7227 forum posts
21 photos
Thanks Brian,
You have confirmed what I suspected, for a machine of that era.
So together with raw materials for an arbor, and a gear blank, a No 2 Brown and Sharpe Gear Cutter; 16 DP,
14.5 degrees Pressure Angle is what is needed to make a replacement gear.
Howard.
Dave Halford22/11/2019 18:12:13
2536 forum posts
24 photos
If you don't make your own you can get a suitable 2nd hand gear, chain drill a ring about 1/2" inside the teeth then chuck and bore the drilling holes away leaving you with a ring gear.
Chuck you busted gear and turn the teeth off to close ish fit to whatever you bored the ring to. You need room in the joint for Loctite so not too tight a fit. Once set drill and tap two M6 holes on the joint line for bolts if belt and braces appeals.
This keeps all the existing gear center keyways, bore size etc etc
I've done this on a back gear it's not that hard.
Brian Wood22/11/2019 19:55:23
2742 forum posts
39 photos
That's neat idea David, I might vary it by using a holesaw to cut off the rim as you suggest rather than flog through the dozens of chain drilled holes. I have made big holes through both steel and cast iron using those.
ega23/11/2019 12:24:22
2805 forum posts
219 photos
Posted by Brian Wood on 22/11/2019 19:55:23:
The use of holesaws was discussed in a thread here some time ago when the interesting point was made by someone that (with the right setup) no pilot drill is necessary. I favour rotabroaches for this kind of job but they are much more expensive, particularly in the larger sizes.
I needed to remove the centre from a 4" diameter by 1" thick cast iron blank the other day and successfully achieved this with a 64mm holesaw ending up with a useful piece left over. The operation was done in the lathe, reversing the work at the halfway point to avoid hitting the chuck jaws although it looked to be possible to get through at one setting. A lot of torque is needed for this and I had to use a strap clamp to release the keyless chuck.
My impression is that this method is less successful with steel where the chip is less easily cleared from the cut.
Brian Wood23/11/2019 14:23:42
2742 forum posts
39 photos
Hello ega,
Light cuts and slow speeds with some coolant are the secret, I have made holes through steel with the holesaw arbor held in nothing more that a standard drill chuck. The arbor did have a six sided grip for that purpose
Edit. Frequent chip clearance is needed, especially when the saw teeth have cut into the material and buried the gullets
Edited By Brian Wood on 23/11/2019 14:25:22
