magpie | 09/11/2019 10:18:35 |
![]() 508 forum posts 98 photos | A simple question. Is it possible to soft solder BZP items. I want to solder some BZP nuts onto some BZP threaded tube. I have a small solder bath, and both bakers fluid and solder paste. Would this be possible of should I use Locktite. Dek. |
Mike Poole | 09/11/2019 10:35:50 |
![]() 3676 forum posts 82 photos | Should be straightforward, might be worth giving the nuts a clean first. Mike |
Emgee | 09/11/2019 11:19:47 |
2610 forum posts 312 photos | Posted by magpie on 09/11/2019 10:18:35:
A simple question. Is it possible to soft solder BZP items. I want to solder some BZP nuts onto some BZP threaded tube. I have a small solder bath, and both bakers fluid and solder paste. Would this be possible of should I use Locktite. Dek. Have you checked the Bakers Fluid recently ? when I last went to use mine I found it had eaten through the tin and rusted some HSS dies stored next to it. Emgee |
mechman48 | 09/11/2019 16:20:30 |
![]() 2947 forum posts 468 photos | Posted by Mike Poole on 09/11/2019 10:35:50:
Should be straightforward, might be worth giving the nuts a clean first. Mike 'ee bah gum lad, there's nowt like clean nuts... George. |
magpie | 09/11/2019 18:02:00 |
![]() 508 forum posts 98 photos | Emgee, the same thing happened to a tin full I had some years ago, but I bought some in a plastic bottle from the Midlands show a few years ago. It is still clean with no leaks. Thanks to Mike Poole for the info, and to mechman48 for the laugh. The nuts and threaded tube are new ones and were by my standards expensive, which is why I didn't want to try something I have never done before with them, IE solder on zinc plating. |
