old mart | 20/10/2019 21:46:16 |
4655 forum posts 304 photos |
Not all vertical mills will be suitable to fit a captive drawbar to. I was lucky because there was space inside the spindle to fit a nut close to the lower end of the drawbar and also not foul the tooling.Some measuring will be necessary before any work is carried out. I cut the thread on the 7/16" en19T drawbar blank on the lathe, and put about 2 1/2" on either end. I made the bronze nut (in black) long enough to Loctite securely with a flange thick enough to not be in any danger of breaking off. At the top end, I used two half nuts for locking and a piece of threaded hexagon bar large enough to ensure that the upper locknut didn't foul the ring spanner that tightened and released the tooling. I was lucky to find a stub ring spanner with a handle of just 6" long, which is plenty. Due to the design of the mill, I had to put spanner flats on the bottom of the spindle, as there was no lock,or any way to hold it. With a minimum endfloat on the drawbar, it breaks the taper in 1/4 turn.
Chris Mate | 12/05/2022 08:26:22 |
325 forum posts 52 photos | Hi, thanks for showing this. |
KWIL | 12/05/2022 09:40:58 |
3681 forum posts 70 photos | I made an air driven drawbar, spindle does not need to be locked as "inertia" holds it enough for the drabar to tighten or release. 'Twas important to fit this as reaching the top with a spanner is stretching it a bit! |
noel shelley | 12/05/2022 10:16:35 |
2308 forum posts 33 photos | Hey KWIL, thats neat ! Yes on a bridgeport it's a bit of a climb up to the top ! Noel |
old mart | 12/05/2022 18:05:07 |
4655 forum posts 304 photos | I did this with the R8 conversion of the Tom Senior light vertical. R8 tapers were designed for mills with drawbars and it is easy to break the taper. The MT3 taper requires more force and I wonder if a bronze taper breaking nut would be the answer, assuming yours is steel. The one I made (shown in black in the drawing) is bronze. Also I used some moly grease when fitting the spindle. I am thinking of doing away with the R8 location pin in the drill mill, and making that a captive drawbar also, an excuse to fit some SKF taper roller bearings and mill some spanner flats near the bottom end of the spindle. |
bernard towers | 12/05/2022 21:18:04 |
1221 forum posts 161 photos | Chris mate, is it possible to have a vet shaped washer above the nut? |
Chris Mate | 12/05/2022 21:37:25 |
325 forum posts 52 photos | Bernard, very little space actually. |
old mart | 13/05/2022 15:44:36 |
4655 forum posts 304 photos | If there is a shortage of space for an extraction nut, it might be possible to shorten the ends or the MT3 tooling, provided there is at least 2 diameters of internal thread left afterwards. This could be done by hand on a bench grinder. Depending on how hard the spindle is, a little bit of boring could well also work. If the pressure face is rough, a cone shaped thick washer to give a flat thrust face might work. |
KWIL | 13/05/2022 16:23:49 |
3681 forum posts 70 photos | Posted by old mart on 12/05/2022 18:05:07:
I am thinking of doing away with the R8 location pin in the drill mill, and making that a captive drawbar also, an excuse to fit some SKF taper roller bearings and mill some spanner flats near the bottom end of the spindle. Location pin is not that important, I have run my R8 without one quite satisfactorily. |
old mart | 13/05/2022 17:10:12 |
4655 forum posts 304 photos | Having the Tom Senior R8 without the pins has had certain benifits, one is that you can clean the internal tapered portion with one of the BT30 taper cleaning wipers. The only disadvantage is if using an R8 collet, it can sometimes turn and there is nothing to hold onto. I make sure if using one, that the 7/16" thread is clean and lubricated with moly grease. The head end of the collets could be drilled with a small solid carbide drill axially in 3 places to use a ring tool with pins to stop the collet from turning while being tightened or loosened. |
Chris Mate | 13/05/2022 21:18:31 |
325 forum posts 52 photos | Hi, Old Mart.....I do not fully understand how you did exactly the following... Some measuring will be necessary before any work is carried out. |
old mart | 13/05/2022 22:32:27 |
4655 forum posts 304 photos | With the Tom Senior light vertical it is just possible to lower the knee far enough to fit the drawbar from the bottom without swinging the head. It would be a problem if the drawbar couldn't be fitted that end of the spindle as that nut inside has to be loctited so it cannot slip when it is used for breaking the taper. Removing the bed might give enough clearance, or even the Y axis part. Otherwise the head would have to come off. It can be done if you are determined enough and sure that the mill can be reassembled ok. Another way would be to remove the quill if there is one. |
Chris Mate | 14/05/2022 06:28:15 |
325 forum posts 52 photos | Hi OLd Mart, it seems the part I dont understand correctly is how you assemble your new Drawbar with the Brass Nut, and if the threads in Brass Nut is different than the rest of the drawbar not like in my case the threads in the MT4 section you draw into the MT4 of the spindle.
Edited By Chris Mate on 14/05/2022 06:33:25 |
old mart | 14/05/2022 18:20:45 |
4655 forum posts 304 photos | The nut is made from bronze, and the lower end of the drawbar has whatever threads are appropriate for the tooling. These threads extend as far as the nut needs to be screwed onto the drawbar. After degreasing the threads on both parts, I used Loctite 620 as a thread locker, even though it is intended as a sleeve and bearing fit. This is because it is very slow curing and the length of the nut can cause slight friction which makes most other grades such as 270 threadlocker harden before the nut is in its final position. If there was enough size of cavity to fit a long nut with sufficient wall thickness, then top and bottom parts of the drawbar could be loctited into the nut. You mentioned boring the spindle, but that would involve much more dismantling than just making room for inserting the drawbar from the bottom. The nut has to rotate with the drawbar, it is not glued into the spindle. |
Chris Mate | 15/05/2022 14:25:10 |
325 forum posts 52 photos | Hi Old Mart, it seems for me seeing I have to insert it from the bottom with your successfull option, which is problematic for me. I did make an option that worked, but I had to tighten it with 4x 4mm grubscrews after inserting the drawbar from the top town, but it does not have the easy torgue yours would have, and seeing the drawbar is in centre of taper its difficult to clean the the taper. |
old mart | 15/05/2022 14:49:26 |
4655 forum posts 304 photos | It would be helpful if you could tell us whick mill you have. Another option which would require very careful measuring would be to put the drawbar in position and then screw the nut on and loctite it into position. You would have to clean the bore of the spindle first, degrease the drawbar and nut when ready to screw them together and put loctite on the male threads when the nut has about 25mm left to screw on. Then leave the drawbar resting on the bed for 24 hours before throughly cleaning the surplace loctite off. Then put moly grease on the top part of the nut and lower drawbar threads, push it up and install the upper nuts. If this did not work, a hacksaw would be needed and you would have to resort to using the original drawbar. Many mill owners have modified the top end of the spindle to provide captive drawbars. If you started a new thread entitled " types of captive mill drawbars" there might be some very good suggestions. |
Chris Mate | 16/05/2022 14:01:17 |
325 forum posts 52 photos | I have ZX-45(ZX-7045) Drill/Mill a drill modified to be a mill, its better than trying to mill with a drill press, also manual=ZAY7045. I have a lot to buy before I can do all sorts of milling, waiting for a Walter Shoulder mill 40mm, it seems everything is out of stock now, was promised 7 days then after I paid its a month. Edited By Chris Mate on 16/05/2022 14:02:09 |
