Vic | 10/10/2019 16:45:24 |
3453 forum posts 23 photos | Do any of you know off hand how small a section O Rings are available? I’ve just ordered some 1mm ID 1mm cross section O rings but they may be a bit too big in cross section. |
David George 1 | 10/10/2019 17:09:36 |
![]() 2110 forum posts 565 photos | I believe that 0.5 mm section is the smallest size have a look on simply bearings web site. David |
Vic | 10/10/2019 17:25:11 |
3453 forum posts 23 photos | Pretty sure it was simply bearings I looked at, smallest was 1mm. I’ll check again. |
Michael Gilligan | 10/10/2019 18:20:37 |
![]() 23121 forum posts 1360 photos | Browse around here, Vic: **LINK** https://www.marcorubber.com/o-ring-size-chart-index.htm MichaelG. |
Vic | 10/10/2019 21:10:12 |
3453 forum posts 23 photos | The smallest standard size seems to be 1mm CS but I’ve found a specialist supplier that make miniature O rings. I’ve now found a supplier though that has O rings specifically for my needs. Not sure what size they actually are so I’m going to see if the ones I’ve ordered elsewhere fit first. |
S.D.L. | 10/10/2019 21:19:05 |
236 forum posts 37 photos | Seen down to 0.1mm cross section x 0.3mm OD
Steve Edited By S.D.L. on 10/10/2019 21:19:24 |
Grindstone Cowboy | 10/10/2019 21:51:59 |
1160 forum posts 73 photos | You could try Polymax |
Vic | 10/10/2019 21:57:57 |
3453 forum posts 23 photos | Thanks for the link GC. |
