Thread form for Atlas 1 1/2" X 8 lathe spindle.
old mart20/09/2019 17:49:50
4655 forum posts
304 photos
I will be making an Atlas chuck backplate in the near future, and wondered if the threads are 60, or 55 degree. If they are 60 degree, I will have to buy a carbide insert, as the ones I have for Smart & Brown are Whitworth form.
David George 120/09/2019 20:18:31
2110 forum posts
565 photos
I believe that the thread is 55 deg Whitworth form but if you find that the thread is 60 deg just grind one in HSS as cast iron cuts better with HSS than carbide and you could save yourself the price of new tooling.
David
Jeff Dayman20/09/2019 20:59:36
2356 forum posts
47 photos
Being made in USA, I think you will find the thread angle on an Atlas lathe is 60 degrees. It was on the one I used to have. FYI You can buy ready -threaded 1 1/2 - 8 backplates from several suppliers in North America quite cheaply, if it's a bother to make your own thread.
old mart21/09/2019 18:34:10
4655 forum posts
304 photos
Not having the dimensions of the Atlas or Boxford is not a disaster for me as the lathe itself is available for measuring. The difficulty is gauging the thread angle. I would think the two makes are not compatible.
The prices of backplates from the USA is cheap, until the postage is added, which quadruples the price.
I already have the blank casting which is about 167mm diameter.
Pete Rimmer21/09/2019 18:50:25
1486 forum posts
105 photos
1-1/2" 10TPI on an Atlas is bound to be UNS. Can't see any USA lathe manufacturer specifying a Whitworth thread back in the 1930's/40's.
john brown 1728/09/2019 10:55:53
135 forum posts
I have a catch plate that fits the atlas ,if that is any good to you
ega28/09/2019 11:05:14
2805 forum posts
219 photos
How about referring a suitable tap or taps to the spindle thread? With everything clean and a light behind it should be possible to ascertain the angle.
John Hinkley28/09/2019 12:03:19
1545 forum posts
484 photos
I don't know what size Atlas lathe you have, but lathes.co.uk give the spindle thread size for the 10" lathe as 1½ x 8 tpi NF, so that's a 60° angle. I would have thought that they will have a standard thread form across the range, wouldn't they?
old mart28/09/2019 21:15:10
4655 forum posts
304 photos
I have now got an ex16 x 8 unified insert which will go in a left hand internal holder to thread away from the chuck when I do the backplate. The chances of the threads being Whitworth are pretty much zero, it being from the USA as mentioned. The standard UNF, formerly NF 1 1/2" has 12 tpi, so it must be a special. I think the lathe is a 12 X --.
