John O | 19/09/2019 02:42:30 |
4 forum posts 3 photos | Hello all, quite new to model engineering specifically but have been machining odd ball things for years. Reading through the threads on here and there's so much good info and great projects, will definitely be seeking advice from some brighter chaps than me in the future. Have just put up my shed so still settling in and finishing the insides but have a Myford ML7 to move in along with an Alpine DM25 Mill. Current project is a Briquette cutter that runs off the briquette being fed through straight from the press, so no electrics and no human input once the press is running. We use a reciprocating saw at the moment but when you are making lots of briquettes at a specific size, that method doesn't make much sense and the commercial cutters are too pricey and bulky. Anyway, enough rubbish from me. Hello |
David George 1 | 19/09/2019 07:01:27 |
![]() 2110 forum posts 565 photos | Hi John welcome to the forum. There are many helpful members on here and you may be helpful to others but it helps so I if you give a locality were you are to suggest local supliers etc. Have you any pictures of past projects I am always on the look out for things to make. David |
Brian H | 19/09/2019 07:16:38 |
![]() 2312 forum posts 112 photos | Hello John and welcome to this excellent forum. Brian |
John O | 19/09/2019 09:08:58 |
4 forum posts 3 photos | Thanks chaps, I'm based just outside Aberdeen, I don't have a lot of pics on this phone and I'm away with work at the moment, but here is a couple snaps of my cutter, however poor they may be! Haha P.s. ignore the state of the garage I'm somewhere between moving stuff out to the shed and working on this haha. |
John O | 19/09/2019 09:25:08 |
4 forum posts 3 photos | Plenty room in there for toys🤘
Bazyle | 19/09/2019 15:45:30 |
![]() 6956 forum posts 229 photos | Nice big shed but while it is empty get 6 inches of insulation on the walls or you will only be working in there for a week or two a year Edited By Bazyle on 19/09/2019 15:48:09 |
John O | 19/09/2019 23:39:41 |
4 forum posts 3 photos | Thanks pal, yeah I'm swithering about putting insulation in or not. I should, but will probably wind up spending my pennies elsewhere and just putting on an extra layer! haha |
David George 1 | 20/09/2019 07:49:46 |
![]() 2110 forum posts 565 photos | Line the inside with a vapour barrier and insulate. It will save loads of money in the long run in heating and trying to avoid damp and rust. David |
Bazyle | 20/09/2019 12:47:27 |
![]() 6956 forum posts 229 photos | Posted by John O on 19/09/2019 23:39:41:
I'm swithering One for my dictionary Pay now to save later - that's a hard one for a Scotsman. I'm the son of a Yorkshireman grandson of a Scotsman so even harder! |
old mart | 20/09/2019 16:06:53 |
4655 forum posts 304 photos | It would be so much easier to do any insulation in the shed before there is anything in it. |
Howard Lewis | 20/09/2019 16:25:18 |
7227 forum posts 21 photos | DEFINITELY insulate! Not only will it be warmer (and CHEAPER TO HEAT ) but there will be less problem with rusting. Do build in some, if only slight, ventilation. as near as possible to the floor, a fixed vent, or vents, will allow moist air to exit. We all exhale moist air and we perspire. My small shop is well insulated, and has floor level vents. Rust is not a problem. Despite what others will say, moist air is heavier than dry air (Churches combat moisture by placing unglazed earthen ware pipes into walls, with the external end lower than the internal. The damp air enters the tube, and falls out of the lower end. How do I know? My late father was a vicar and his book on church maintenance advocated this as means of combatting damp ) Don't skimp on power sockets, you won't find that too many remain unused at some some, (Power tools, vacuum cleaners, battery chargers, engravers, extra lights, etc will all need a socket when you have too few) If you use VFDs, do consider feeding from a suppressed socket, to avoid the risk of feeding unwanted noise back up the mains into your house, and any other on your phase of the mains. Enjoy yourself, hours of fun to come! Howard |
Neil Wyatt | 20/09/2019 18:10:36 |
![]() 19226 forum posts 749 photos 86 articles | Welcome to the forum John. How long can you keep he shed that neat? Neil |
