Aled Dafis | 28/08/2019 09:00:05 |
![]() 14 forum posts | Hi, I've just aquired a Boxford C lathe and was wondering which oil I should use to keep it running nicely? Is a modern engine oil suitable? Also, it has quite a few nipple type oiling points, so I need a reliable oil gun. I've read about Wanner guns, are there any other reliable (and cheaper) alternatives? Many thanks in advance, I'm sure that I'll be back with other beginner type questions in due course. Aled |
Howard Lewis | 28/08/2019 10:16:50 |
7227 forum posts 21 photos | For ball oilers the Reilang is superb! Works at any angle and rarely are there any leaks. May even work OK with "grease" nipples. For ordinary grease nipples, the Wanner is excellent, but small capacity. Incidentally, although the nipples may be grease ones, only use oil. Grease hardens and then blocks the passages. Howard |
Kevin Murrell | 28/08/2019 11:17:32 |
59 forum posts 6 photos | Cleverer people than me will know the whole answer, but I believe modern engine oil is not suitable for your lathe. Those oils are designed to work at a much higher temperature. I suspect that the various additives in them wont help either! |
Kiwi Bloke | 28/08/2019 11:50:15 |
912 forum posts 3 photos | 'Cleverer people than me will know the whole answer, but I believe modern engine oil is not suitable for your lathe. Those oils are designed to work at a much higher temperature. I suspect that the various additives in them wont help either!' What he said! 'Hydraulic' oil is the stuff to use, eg Nuto 32, in gearboxes and nipples, with 'way oil' on slideways.
Aled Dafis | 28/08/2019 12:38:53 |
![]() 14 forum posts | Thanks, I've just ordered some Hydraulic oil.
Aled |
Robert Atkinson 2 | 28/08/2019 12:39:39 |
![]() 1891 forum posts 37 photos | Posted by Kevin Murrell on 28/08/2019 11:17:32:
Cleverer people than me will know the whole answer, but I believe modern engine oil is not suitable for your lathe. Those oils are designed to work at a much higher temperature. I suspect that the various additives in them wont help either! Actually a modern 5 or 0 weight engine oil is probably OK and better than a engine oil comtempary to the lathe. Modern oils have fewer additives that might harm yellow metal bearings. That said I'd still go for a good SAE32 hydraulic oil. I just bought a 5l tin (lifetime supply for me) of OM33 (UK military spec oil similar to Nuto 32. Hyspin 32ZZ meets the OM33 spec) on ebay for £10 www.ebay.co.uk/itm/HYDRAULIC-OIL-FUCHS-LUBRICANTS-MIL-SPEC-PREMIUM-QUALITY-HYDRAULIC-OIL-5L-CAN/143226367787 Robert G8RPI. |
Aled Dafis | 28/08/2019 12:44:40 |
![]() 14 forum posts | Posted by Robert Atkinson 2 on 28/08/2019 12:39:39:
Cleverer people than me will know the whole answer, but I believe modern engine oil is not suitable for your lathe. Those oils are designed to work at a much higher temperature. I suspect that the various additives in them wont help either! Actually a modern 5 or 0 weight engine oil is probably OK and better than a engine oil comtempary to the lathe. Modern oils have fewer additives that might harm yellow metal bearings. That said I'd still go for a good SAE32 hydraulic oil. I just bought a 5l tin (lifetime supply for me) of OM33 (UK military spec oil similar to Nuto 32. Hyspin 32ZZ meets the OM33 spec) on ebay for £10 www.ebay.co.uk/itm/HYDRAULIC-OIL-FUCHS-LUBRICANTS-MIL-SPEC-PREMIUM-QUALITY-HYDRAULIC-OIL-5L-CAN/143226367787 Robert G8RPI. Thanks for the link Robert, is it correct that it'll take a month and a half to get here from Cambridge? |
Howard Lewis | 28/08/2019 14:09:02 |
7227 forum posts 21 photos | Yellow metal bearing are likely to be affected by the sulphur additives in the EP oils intended for rear axles. (Such as Spiral bevel, or Hypoid. Worm axles usually having a yellow metal worm wheel will not use them, just a straight SAE 90 or 140 ) Modern Front Wheel Drive vehicles will be unlikely to use them, since the gears will be helical, rather than bevel. Modern engine oils will contain additives which are not needed for lathe use, such as detergents, anti foaming, anti oxidant, or low viscosity index, and can withstand high temperatures. I would imagine that they are unlikely to do much damage to a lathe or a mill. You would be paying for a lot of features that you do not need and will not use. Having said that, I have been using up my stock of engine oil on my machines over the last sixteen or more years with no apparent ill effects! A comparatively straight oil should suffice. .Howard |
Vic | 28/08/2019 15:21:36 |
3453 forum posts 23 photos | I’ve got a flexible spout oiler like this one. Works fine. |
Neil Wyatt | 28/08/2019 16:27:23 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Vic on 28/08/2019 15:21:36:
I’ve got a flexible spout oiler like this one. Works fine. Ditto - Although I have the slightly higher-class Toolstation version SAE 32 oil should be avialable anywhere in the world. Neil |
Oldiron | 28/08/2019 16:57:21 |
1193 forum posts 59 photos | I have several oilers similar to Vic's some with flexi spouts and some with tube style spouts.. I use one on my AUD oilers and another for way oil and yet another with cutting oil for turning/milling etc. They all work well no matter what the weight of oil in them. |
Vic | 28/08/2019 17:12:19 |
3453 forum posts 23 photos | I should have added that mines loaded with slideway 68 at present. |
Aled Dafis | 28/08/2019 23:03:04 |
![]() 14 forum posts | Thanks guys, looks like you've saved me a few quid, I had placed some hydraulic oil in my ebay basket, but further research showed that compressor oil is the same spec, and I have a litre of that going spare. I'll also try my standard oil can to see how i get on. Cheers Aled |
Nigel McBurney 1 | 31/08/2019 14:15:47 |
![]() 1101 forum posts 3 photos | My 50 year old Tecalamit oil gun finally expired earlier this year so bought an oil gun from a company called Press Parts, it is suitable for oil and grease and comes with two nozzles base cost £17 plus the usual vat etc, it was mentioned on this model engineer site last year It works ok and a lot cheaper than other makes,use for my Myford S 7 and omnimill. the only nipple it will not get to is the one for lubricating the back gear shaft ,so made an adaptor. [email protected] cat part no PP637 Wanner products are very good,but expensive,my grease gun was purchased in 1962 and still never fails to work, was lucky earlier this year,bought an identical Wanner back in the spring for £5 at an autojumble,real bargain ,took a while to get the old solid grease out ,now used for the deck of my ride on mower which requires a flexible hose with nozzle, so saves me repeatably changing the fixed and flexible hose on one gun. |
IanT | 31/08/2019 14:57:49 |
2147 forum posts 222 photos | Posted by Vic on 28/08/2019 15:21:36:
I’ve got a flexible spout oiler like this one. Works fine. I've got two of those type (among an amazing collection of oil cans gathered over the years) - mine are a different brand but look identical. They do work but when you put them down, expect a puddle of oil to form. Mine now sit in small cake tins (I get of a lot of useful things from my wife) and that helps control the mess. I also of course have the Myford oil gun (the later version I believe) which is extremely messy and wasteful (so not recommended!). You can get it to seal to a nipple by using a small piece of linen between gun and nipple but it's very far from ideal. I keep it in a bit of vertical plastic piping (with an end cap screwed on the bottom) which stops it dripping and so I can occasionally recover the leaked oil from it. Have been tempted by a Reilang but I'm also not too sure if they would attach cleanly to a Myford nipple? IanT |
Bruce Newman | 31/08/2019 16:03:04 |
20 forum posts 2 photos | Just a note on modern engine oils, on my old Triumph Thunderbird motorbike there is no oil filter, it relies on the dirt sinking to the bottom of the oil tank and staying there for ever. Modern engine oil have detergents in them which keep the dirt suspended in the oil so it can be removed from by the filter. If I was to use a modern oil it would wreck my bike's engine bearings so I have to use an oil for vintage vehicles which Halfords sell, the bonus is that it comes it a proper metal can which is a good source of tin plate. |
