merlin | 21/08/2019 18:38:32 |
141 forum posts 1 photos | I dare hardly show my ignorance of this subject on this forum, but after years of rubbing shoulders with clever model railway engineers I have realised that I don't know what eg 71/4" gauge means. Is it the inside measurement between rails? Are the enginese and stock to 71/4" to the foot? Wikipedia tells me so much that I become confused. Years ago I walked the footpath past the McAlpine house near Henley and could see the layout throught he trees; it is this gauge that interests me. Thanks |
not done it yet | 21/08/2019 19:04:54 |
7517 forum posts 20 photos | First hit on ‘goggle’, from Ride on Railways, says distance between the rails, not scale. Good enough for me. |
Former Member | 21/08/2019 19:47:56 |
1329 forum posts | [This posting has been removed] |
Howard Lewis | 22/08/2019 09:44:02 |
7227 forum posts 21 photos | The gauge of the railway on the estate of the late Sir William McAlpine, at Fawley Hill, is the standard 4 ft 8.5 inch. Howard |
Former Member | 22/08/2019 10:13:00 |
SillyOldDuffer | 22/08/2019 10:44:15 |
10668 forum posts 2415 photos | Posted by 34046 on 21/08/2019 19:47:56:
... 7,25 inch locos and rolling stock are built to a scale of 1.5 inches equals 1 foot. ...Bill
Like Merlin I'm confused slightly by scale and gauge. A scale of 1½" to 1' is 1:8 so standard gauge ( 4'8½" ) rail track should be modelled 7¹⁄₁₆" apart. Not that it makes any difference, but why jump to 7¼" or even 7½" as is popular in the USA? Dave
Edited By SillyOldDuffer on 22/08/2019 10:45:12 |
Former Member | 22/08/2019 11:08:02 |
Former Member | 22/08/2019 11:18:41 |
Former Member | 22/08/2019 11:32:44 |
JasonB | 22/08/2019 11:43:23 |
![]() 25215 forum posts 3105 photos 1 articles | Then the whole scale thing goes out the window when you put narrow gauge models onto standard gauge based track widths For example a 2ft narrow gauge model built to run on 7.25" track is approx 1/3rd scale or 4" to the foot. |
Ron Colvin | 22/08/2019 12:08:48 |
91 forum posts 6 photos | Posted by SillyOldDuffer on 22/08/2019 10:44:15:
With passenger hauling model locomotives it is the gauge that is important, the scale is nominal. If someone is a stickler for having a correct scale/gauge ratio, they can tweak the scale accordingly. With small scale scenic model railways the scale is generally kept constant, and it is the gauge that is adjusted by the purist.
Former Member | 22/08/2019 12:40:53 |
Perko7 | 22/08/2019 13:04:16 |
452 forum posts 35 photos | In Australia some 5-inch gauge models of standard (4ft 8-1/2inch) gauge locos are built to a scale of 1-1/16inch to get the scale/gauge proportions correct. Like model railways there are always compromises to be made, either for ease of construction, or to provide greater clearances, or because a scale reduction of actual dimensions would not provide sufficient tolerances or clearances for satisfactory operation. As others have said, narrow-gauge prototypes have different scale/gauge combinations. My model of a 3ft6inch gauge Queensland loco is built to 1-1/2inch scale to run on 5inch gauge track. It's not exactly correct, but I'm not going to use a scale of 1-27/64inch just to make it so. I don't know where or when the adoption of 7-1/4inch gauge occurred in the UK and Australia, but that is what has become common use so we adjust the necessary dimensions to suit the 'slightly wider than scale' track gauge while keeping the rest of the loco to scale. |
Ron Colvin | 22/08/2019 14:01:47 |
91 forum posts 6 photos | Posted by 34046 on 22/08/2019 12:40:53:
That is interesting Ron i always understood back along when I spoke to Reeves that drawings for locos were drawn to scale ie 0.75 inch for 3.5 gauge, 1 inch for 5 gauge and 1.5 for 7.25 gauge ? Is this correct please ? Bill
More likely that someone who has chosen to build with a correct scale/gauge ratio has decided to build a model of a prototype for which no drawings or castings are available. There is a lot of extra design/drawing work involved in producing a more authentic representative of a given locomotive from a published standard design. For example see the current ME series of articles by Doug Hewson on updating LBSC's pannier tank locomotive "Pansy". |
John Baguley | 22/08/2019 16:19:40 |
![]() 517 forum posts 57 photos | The scales and gauges were standardised way back in Henry Greenly's day. Standard gauge locos in 2½" gauge were originall built to a scale of 1/2" to the foot but this later became 17/32" to the foot to give more accurate proportions. As stated, Standard 3-1/2" gauge is a scale of 3/4" to the foot and 5" gauge is 1-1/16" to the foot. The Americans etc. mostly use 4-3/4" gauge which is 1" to the foot. 5" gauge in the USA is rare. It's often stated that the American 7-1/2" gauge came about because of a mistake by someone as they did originally use 7-1/4". John |
Neil Wyatt | 22/08/2019 16:35:32 |
![]() 19226 forum posts 749 photos 86 articles | Posted by John Baguley on 22/08/2019 16:19:40:
As stated, Standard 3-1/2" gauge is a scale of 3/4" to the foot and 5" gauge is 1-1/16" to the foot. The Americans etc. mostly use 4-3/4" gauge which is 1" to the foot. 5" gauge in the USA is rare. Logic is in short supply with regard to gauges and scales in railway modelling... probably because the strange standard gauge of 4'8.5" doesn't scale accurately to anything convenient. 7 1/2 and 7 1/4 are found in the USA, although 7 1/2 is more common. One thing I don't understand is that, for example, both 3 1/2" and 5" gauge locos happily run on the same dual gauge tracks. So why not use 3 1/2" gauge flanges on 5" gauge models to get a more scale appearance? I can see this might be a step too far for 7 1/4" gauge, but surely they would get away with 5" flanges? I bear in mind that large 3 1/2" wheels are bigger than small 5" gauge ones... Neil
Bazyle | 22/08/2019 17:48:34 |
![]() 6956 forum posts 229 photos | Posted by Neil Wyatt on 22/08/2019 16:35:32:
Logic is in short supply with regard to gauges and scales in railway modelling.. There is a sort of logic. Starting with G1 the gauges go up or down in a ration of root 2 so that the size of your model railway doubled or halved. That exact ratio was then rounded to a convenient, mostly imperial, dimension because most people didn't have a Babbage machine in their back room to do the scaling. Then awkward people got in on the act and wanted things to be more accurate than cheap tinplate pressings so every size got split and some models can even be one scale at one end and another at the other. |
Ron Colvin | 22/08/2019 18:37:41 |
91 forum posts 6 photos | The origin of having a set of standard gauges was introduced by a toy manufacturer in 1891 (Märklin ) . They were gauges numbered 1 to 5 Number 1 gauge = 45mm Number 2 gauge = 54mm Number 3 gauge = 67mm Number 4 gauge = 75mm Number 5 gauge = 120mm
The only one that has remained to its original dimension is gauge 1. |
Former Member | 22/08/2019 18:47:22 |
Brian G | 22/08/2019 19:52:03 |
912 forum posts 40 photos | Posted by 34046 on 22/08/2019 18:47:22:
... And yet they waited until 1893 before they brought out their 0 gauge loco for some unknown raeson ? Bill
According to NEM10 issued by MOROP the current large scale gauges and scales are: 0 32mm (No equivalent stated) at 1:45 (7mm/ft is 1:43.5) I 45mm (1 3/4" II 64mm (2 1/2" III 89mm (3 1/2" V 127mm (5" VII 184mm (7 1/4" X 184mm (10 1/4" Personally, I won't lose any sleep over these differences, I quite enjoyed riding on the RHDR today, and wasn't worried about 1/3 scale locos running on 1/4 scale track. Brian
