Any uses for an old tired lathe bed
David K03/08/2019 16:49:43
258 forum posts
259 photos
I replaced the bed on my Myford S7 a while back and the old bed has been sat under my bench ever since. Before I have my next tidy up and take it to the tip is there anything it might be useful for.
RobCox03/08/2019 16:55:54
82 forum posts
44 photos
Raw material for your next project?
Mike Poole03/08/2019 16:59:03
3676 forum posts
82 photos
Did you replace it because the old bed is beyond being reground? If there is enough meat for a regrind then it may have some value to someone. Maybe a super long bed could be rigged for making cues or the like.
Nick Clarke 303/08/2019 17:19:13
1607 forum posts
69 photos
Maybe talk to the poster in this thread? **LINK**
Bazyle03/08/2019 17:55:23
6956 forum posts
229 photos
If the S7 has the bed type with a flat bed not inverted v then each shear can make a nice camelback transfer reference flat.
Zan03/08/2019 18:37:14
356 forum posts
25 photos
Posted by Bazyle on 03/08/2019 17:55:23:
The point here is that the bed is stuffed so how could it be a ref. flat?
and yes myford beds are flat.
Pete Rimmer03/08/2019 18:45:27
1486 forum posts
105 photos
My first scraping project was a S7 bed. The simple shape makes for a great first project.
David K03/08/2019 19:38:22
258 forum posts
259 photos
Posted by Mike Poole on 03/08/2019 16:59:03:
The problem with a re grind is the cost , I managed to pick up an excellent second hand bed much cheaper than a re grind
David K03/08/2019 19:39:29
258 forum posts
259 photos
Posted by Pete Rimmer on 03/08/2019 18:45:27:
That's an idea , I might have a go at scraping it.
Phil H103/08/2019 19:47:11
467 forum posts
60 photos
David/ Peter,
Do you have an idea (perhaps from measurements with straight edges and feelers etc) how much wear is on the bed you have? Peter, how much wear was on your S7 bed scraping exercise before you started?
Phil H
Pete Rimmer03/08/2019 19:52:20
1486 forum posts
105 photos
Posted by David Kenyon 2 on 03/08/2019 19:39:29:
Scrapers are easy to make. Buy a sandvik tip and make the rest. Get a 1500-2000 grit flat lap disc off ebay (or get a set of three different grits for about 12 quid) and fix it to your chuck face with double sided tape. Turn lathe at 300-400 rpm and use it to sharpen to 5 degrees negative.
Pete Rimmer03/08/2019 20:06:36
1486 forum posts
105 photos
Posted by Phil H1 on 03/08/2019 19:47:11:
David/ Peter,
Phil H
Phil, see the image below. wear is marked in ten-thousandths of an inch.
Bazyle03/08/2019 21:45:06
6956 forum posts
229 photos
Posted by Zan on 03/08/2019 18:37:14:
The point being it is a nice bit of cast iron which when cut down to say 2ft long could be reground and scraped with a lot less trouble than a proper bed regrind.
Douglas Johnston04/08/2019 09:06:03
814 forum posts
36 photos
Posted by Pete Rimmer on 03/08/2019 19:52:20:
I was hoping to make a scraper and tried the link above but no joy, the link has no mention of making scrapers. Was the wrong link posted?
Doug
Pete Rimmer04/08/2019 10:40:30
1486 forum posts
105 photos
I'm sorry yes it is the wrong link. I will remedy that right away, though I can't edit the previous post so I'll put it here.
EDIT: here is the link I meant to post.
Buy the steel to make the shank from here
Edited By Pete Rimmer on 04/08/2019 10:46:21
