New Member - John Payne (aka knightrideruk)
Knightrideruk | 20/07/2019 10:29:53 |
4 forum posts | Hi all, My name is John Payne at present residing near Chelmsford Essex. I am 68 years old and a retired military armourer. I have always been into woodworking but have recently setup a metalworking workshop with a Chinese 7 X 16 lathe and SX2 mill with the aim of developing a electrical control valve for pre-charged air weapons. At present I am modify the lathe and mill to correct some of their problems, hence the purchase of MEW. At present I am looking for a decent indexer for the lathe, looked at several mostly American yet to find something that works maybe have to design my own. Look forward to communicating as things progress. Regards Knightrideruk Out of the darkness comes light... |
Brian H | 20/07/2019 12:05:33 |
![]() 2312 forum posts 112 photos | Welcome John to this very friendly and helpful forum, I'm sure you will find answers to an questions that you may have. Brian |
David George 1 | 21/07/2019 07:35:11 |
![]() 2110 forum posts 565 photos | Hi John welcome to the forum loads of information on here, if you look in the back threads there are lots of other people's efforts to give you inspiration. What are you looking at a rotary table or dividing head. David |
SillyOldDuffer | 21/07/2019 10:45:19 |
10668 forum posts 2415 photos | Hi John and welcome, Can you explain more what you mean by an Indexer, I know of three types and there may be more. My example pictures are from arceurotrade's website apart from the Dividing Head, which is from Wikipedia. 1. A stand alone spin indexer where a pin engages in holes in a disk:
2. A stand alone Rotary Table where a handle drives a worm gear allowing angles to be traversed. Can mounted flat or vertical. 3. A Dividing Head. Also stand alone, usually with a Spin Indexer disk, plus a Rotary Table worm drive and also with the holed disk with brass 'clock hands' and drive handle arrangement at front. Divider Plates are an important aid to turning accurate angles as when making gears. There are further variants, in particular I wonder if you mean a spin indexer attached to the lathe spindle, which allows work in the chuck to be held in a known position while - for example - horizontal splines are cut. These are far more common on woodworking lathes, where they are used to add decoration as when making pens. There was a thread a while ago on this forum about a metal-working lathe that appeared to have been factory fitted with a spindle indexer. It attracted a lot of interest because it was so rare! As can be seen from the photos, dividers and rotary tables are more often used on a Mill than a Lathe. Rotary Tables can usually be fitted with Divider Plates as an accessory. Or, it's becoming increasingly common to drive rotary tables with a stepper motor and computer-controller that replaces the Divider Plate/Clock Hand unit and does all the sums for you (and doesn't lose count when the phone rings!) If you can say what type of cutting operation(s) you want to do, then loads of experienced machinists on the forum able to help. Apologies if I'm preaching to an ex-military armourer who already knows all this stuff! Dave
