Speedy Builder5 | 19/07/2019 12:29:32 |
2878 forum posts 248 photos | What threads are used on electrical fittings, between a lightbulb socket and a tubular brass support bracket. I am trying to help out a friend (By telephone) who has a 14mm OD thread which is not metric fine, but still a fine thread which goes into a larger light fitting. I have see somewhere that the thread angle may be 80 degrees. Any ideas out there please ? BobH |
JasonB | 19/07/2019 12:38:54 |
![]() 25215 forum posts 3105 photos 1 articles | PG conduit thread maybe |
Speedy Builder5 | 19/07/2019 12:57:25 |
2878 forum posts 248 photos | thanks Jason, PG are 80 degrees but not a 14mm OD (There is a 14mm cable size though). The 80 degree bit may have been just an idea I had. These fittings are often found on thin brass and steel fittings. The light fitting in question was bought in London, wholesaled from USA and made in China ! What hope have I got of telling my friend what thread he has ????? |
Robert Atkinson 2 | 19/07/2019 13:01:04 |
![]() 1891 forum posts 37 photos | No real standard. As Jason says PG is not uncommon, mostly on industrial fixtures though. Brass holders commonly have 10mm x 1.5, 20mmx 1.5 or 1/2" x 26tpi which does not seem to fit your description. Quite possibly some odd pipe thread. Robert G8RPI. |
JasonB | 19/07/2019 13:03:11 |
![]() 25215 forum posts 3105 photos 1 articles | Are you sure it is not 1mm pitch, a lot of the smaller size electrical stuff is 1mm pitch eg M10x1 14mm is also quite close to 9/16 x 26 or 20 tpi |
Keith Rogers 2 | 19/07/2019 14:07:29 |
88 forum posts 2 photos | Back in the day when I repaired chandeliers and light fittings I came across all sorts of threads. Most fitting tended to be Brass thread , 9/16 x 26 BSB is 14.2mm OD so as Jason says is a very likely candidate. Electrical conduit threads are based on american national pipe pitches, so 1/4 NPT would be .540" OD (close to 14mm ) but is 18t.p.i which sounds a bit coarse for the OP. Later fittings were mostly Metric, again as Jason says 1mm pitch being common. Alth'o being from the US I would think that less likely. Keith. p.s. Sorry for the acronyms |
Speedy Builder5 | 19/07/2019 14:13:30 |
2878 forum posts 248 photos | 9/16 x 26 sounds about right, I will give my friend a ring. Anyone live in Lowestoft with a 9/16 x 26 BSB tap ?? BobH |
Sandgrounder | 19/07/2019 14:14:26 |
256 forum posts 6 photos | There is a 'British Brass' thread which is exactly 14mm dia, actually 0.5512" and at 26TPI very close to 1MM pitch. from Machinery's Screw Thread Book. Edited By Sandgrounder on 19/07/2019 14:15:34 Edited By Sandgrounder on 19/07/2019 14:17:22 |
