Free cutting mild steel
Glyn Davies17/06/2019 10:40:09
146 forum posts
56 photos
I want to make some grinding wheel adapters for my universal cutter grinder, which involves a lot of turning 50mm bar down to 20mm. Much of the BMS I've bought in the past does not really turn well using HSS tools on my little Myford so I'd like to get some mild steel that is truly free cutting.
Should I be asking for EN1a Leaded as being the free-est cutting BMS that money can buy?
ega17/06/2019 10:56:23
2805 forum posts
219 photos
You could follow the advice for the Quorn and use Loctite to combine the components, perhaps.
If there is a flange next to a paper "blotter" I would recommend (free-cutting) stainless steel to avoid rusting.
colin hawes17/06/2019 10:57:15
570 forum posts
18 photos
Yes....and make sure you keep the tools sharp. Colin
SillyOldDuffer17/06/2019 11:03:36
10668 forum posts
2415 photos
Simple answer is 'yes', but I suspect there may be more to it. I'd expect a little Myford and HSS to cope reasonably well with BMS. Although BMS isn't wonderful, it shouldn't be awful. Usually it's the finish that suffers.
Have to say the first time I turned Free-cutting I was delighted - it does what it says on the tin. However, if Free-cutting doesn't fix the problem, ask again. There are several reasons why a lathe might struggle other than the metal.
Martin Kyte17/06/2019 11:07:07
3445 forum posts
62 photos
GLR Kennions free cutting machines really well.
Martin
Hopper17/06/2019 11:23:31
7881 forum posts
397 photos
Posted by Glyn Davies on 17/06/2019 10:40:09:
... turning 50mm bar down to 20mm. Much of the BMS I've bought in the past does not really turn well using HSS tools on my little Myford ..
That's about six cuts of about 2.5mm deep each. Easy peasy on a Myford with HSS. Sharpen your toolbit as per LH Sparey's instructions for knife tool in "The Amateur's Lathe".
Ian S C17/06/2019 15:44:59
7468 forum posts
230 photos
I find no difficulty turning hot rolled "mild Steel"(no spec) with a fairly worn Box-Ford A using HSS or carbide tools.
Ian S C
Glyn Davies17/06/2019 17:20:06
146 forum posts
56 photos
Thanks for the replies - I'll grind a right hand knife tool with 55 degrees top rake and give it a go with whatever EN1a steel I find.
I think a 100 thou depth of cut is going to make it chug a bit though!
