Brian H | 03/06/2019 07:54:23 |
![]() 2312 forum posts 112 photos | How easy is it to achieve the above in term of weight and awkwardness of handling of the vertical head? Brian |
not done it yet | 03/06/2019 11:52:58 |
7517 forum posts 20 photos | Not got one, but the Centec head weighs north of 30kg and is awkward and heavy, but I manage it reasonably well in a confined space (I’m north of 70!). That is locating it horizontally, not vertically. The Tom senior head (assuming you are referring to the S-type head) may be even heavier, so it might depend on how high you need to lift it to get it into position... |
old mart | 03/06/2019 22:20:47 |
4655 forum posts 304 photos | Looking at the lathes UK site, it would seem that your M1 has the same head assembly as the light vertical. The first thing to do would be to remove the motor, just the wiring to attend to, the locking adjuster and the pivot screw and derail the belt so it doesn't get caught up.. Then the two caphead screws holding the head onto the M1 adaptor, and gently work the head off of the spigot by pulling and rotating slightly. Lastly, the M1 adaptor. This breaks down the weights into three more manageable loads. |
Kiwi Bloke | 03/06/2019 22:41:11 |
912 forum posts 3 photos | Brian, it depends on whether you're talking about removing the self-powered, quill-type vertical head or the non-quill, right-angled head (it also depends on how strong you are). The former is pretty heavy, the latter isn't. A decade ago, I could manage to manhandle the entire self-powered head onto and off the machine with ease, but a hoist seems safer, these days. The awkwardness is in getting the alignment right by 'feel', making sensitive, small positional adjustments, whilst trying not to sag or wobble under the load (which seems to increase as the task progresses), whilst balancing on some sort of step-up. Bad back = use mechanical aid! My Senior is a late 'Universal', with the prismatic overarm. On the rare occasions that I have removed and replaced it, it was a sphincter-tightening experience to try to align it with the female dovetail, whilst supporting the considerable weight of the thing on my (well-padded) shoulder. I had visions of the end of a dovetail cracking off. Next time it comes off, it will be with a hoist... |
Gary Wooding | 04/06/2019 07:02:38 |
1074 forum posts 290 photos | You can make it somewhat easier by putting a suitably sized box, or some such, on the mill table, which can then be used as jack to raise and lower the box until the VH can be transferred between it and the mill. Works fine for my Centec. |
Brian H | 04/06/2019 07:16:37 |
![]() 2312 forum posts 112 photos | Many thanks for the replies, very helpful. Brian |
Kiwi Bloke | 04/06/2019 08:34:39 |
912 forum posts 3 photos | Yes, great idea from Gary. Centec heads weigh nothing, compared to the self-powered Senior head! |
Mike Poole | 04/06/2019 10:01:30 |
![]() 3676 forum posts 82 photos | If you want to change mode regularly it would be handy to have a swing away arm to just park it out of the way. Mike |
Clive Foster | 04/06/2019 13:59:10 |
3630 forum posts 128 photos | If you plan to switch heads on a fairly regular basis you will also need some simple way of supporting the head when off the machine. If that is indeed the case consider killing two birds with one stone by making a suitably sized foot plate having a vertical arbor matching the machine taper. Effectively the turbocharged with nitrous injection version of Garys idea. When in store the head sits on the taper held nice and stable by the drawbar. To fit on the machine lift the whole kit and kaboodle up onto the table and adjust until it lines up. Slide to get it roughly in place then use the table feeds for final alignment. Release taper, drop table so it clears the spindle then remove foot. Job done. Simples and no heavy lifting if you have a suitable hoist. A neat side benefit is that you can fit appropriate lifting points to the foot for the hoist to hook to so it goes up nice and straight. Rule one of the vertical head designers union appears to be " make it sufficiently unbalnced that it won'y hang straight". Rule 2 seems to be "make the shape such that its impossible to get a stable arrangment of lifting straps without obscuring the bolting flange". I have such a plate and arbor combo in the slowspeed "as and when workshop lane" as the varispeed head on my Bridgeport needs to come off for servicing in the not too far distant future. Needs an extra support at the motor end but thats no great issue as its only off for servicing. Clive. Edited By Clive Foster on 04/06/2019 14:01:02 |
Dave Halford | 04/06/2019 16:53:01 |
2536 forum posts 24 photos | Pretty sure all of these were never meant to be swapped back and forth if you needed both, then buy two machines, hence the difficulty. Also you should be of a working age and know what you are doing. As none of the above is relevant to any of us its all difficult. |
