Making a tiny reamer
Nick Clarke 302/06/2019 10:04:30
1607 forum posts
69 photos
At some point in the near future I will need a 2mm reamer for a one off job.
I have made 'toolmakers' reamers in the past by filing silver steel down at an angle - but not often, and in larger sizes only.
Any hints/suggestions on making such a tiny reamer, particularly the best way to hold it while making and what speed to run it at
No hurry as only just ordered the 2mm silver steel.
Thanks
Nick
Hopper02/06/2019 10:06:00
7881 forum posts
397 photos
Hold it in a pin vice. Or a drill chuck held in the vice with soft jaws etc.
Phil P02/06/2019 10:14:49
851 forum posts
206 photos
Hi Nick
I know it might not be in the spirit of doing everything yourself, but you can buy a 2mm chucking reamer in the UK for less than £2 post free on Ebay, even if the quality is not perfect I think at that price I would be tempted to buy one and try a test hole before making one.
Phil
Nick Clarke 302/06/2019 10:50:32
1607 forum posts
69 photos
Posted by Phil P on 02/06/2019 10:14:49:
Hi Nick
Phil
Thanks Phil - I saw those - my thinking was as a 2mm silver steel shaft has to run in the hole making a reamer from the same steel might mean the size was more accurate.
This is all tiny stuff for me!
Ian S C02/06/2019 12:59:41
7468 forum posts
230 photos
Big, small, tool makers reamer is the way I usually go, usually with the same steel as the shaft that will fit the hole. For a one off hole(maybe two or three) in brass or aluminium I sometimes get away unhardened.
Ian S C
John Reese02/06/2019 18:31:39
1071 forum posts
https://www.youtube.com/watch?v=5rwl-e_KI4U
John Reese02/06/2019 18:31:45
1071 forum posts
Nick Clarke 302/06/2019 18:57:31
1607 forum posts
69 photos
Posted by John Reese on 02/06/2019 18:31:45:
https://www.youtube.com/watch?v=5rwl-e_KI4UT
Thanks John - With the larger reamers I have made I have just held them in fibre jaws in the vice and filed a single flat and I was wondering how to hold such a thin piece for filing without bending it.
I will probably make a similar holder, but I'm waiting for the silver steel to arrive as I said, so not done it yet (apologies to the member NDIY)
Thanks again,
Nick
Edited By Nick Clarke 3 on 02/06/2019 19:01:08
Speedy Builder502/06/2019 19:25:34
2878 forum posts
248 photos
Swiss Broaches are good to have - Not strictly reamers, as they leave a tapered hole, but in thin components, the taper is negligible. Ideal for changing carburettor jet sizes by a gnats whisker etc.
John Reese03/06/2019 16:44:36
1071 forum posts
Hold it in soft jaws in a vise with only enough projecting to file the point. Hold it in a pin vise or small chuck when reaming,
