Open Crank IC Plans
Philip Burley26/03/2019 12:12:13
198 forum posts
hello , has anyone come across plans for an open crank engine made from bar stock ?
John Rudd26/03/2019 12:19:26
1479 forum posts
Steam or ic?
There is the Webster OC engine that is ic....
JasonB26/03/2019 12:29:20
The Webster and kerzel open crank hit and miss engines can be found on the web if you want something small.
Model Engine Builder will sell the two back issues that have very good drawings for the Zero-six engine in digital format for a modest cost. I built it with some modifications so it did not look so much like a barstock engine but mechanically all the same.
Jerry Howell's "farmboy" is also a nice looking opencrank from barstock and ideal for those that like making aluminium swarf
Edited By JasonB on 26/03/2019 12:36:46
Bazyle26/03/2019 12:32:39
6956 forum posts
229 photos
It started here Dad's horizontal
went on here still horizontal
There's no stopping him now vertical but this thread starts a bit funny, page two has a picture.
Stewart has done more and more complex
BTW it would help others in future searches if you made your title more explanatory and the text a bit more detailed.
Philip Burley26/03/2019 13:33:22
198 forum posts
sorry , I should have indicated that I am after an IC engine , made several steamers , and just fancied a change , but the casting sets are so expensive
JasonB26/03/2019 13:39:50
One more for the list but it's quite big. J & E Junior
Philip Burley26/03/2019 13:49:02
198 forum posts
the J&E looks interesting , if it was reduced a bit
JasonB26/03/2019 13:55:09
Yes I should think half or two thirds that size would work out OK. If you prefer metric then working to a ratio of 1/16" = 1mm will give mostly whole numbers, 192mm dia flywheels and 32mm bore.
John Olsen27/03/2019 00:17:03
1294 forum posts
108 photos
The Rina engine was described in Model Engineer a few years back. were a few problem areas in the drawings but I can help with corrections. I haven't actually built the engine.
