AJW | 03/03/2019 22:47:47 |
![]() 388 forum posts 137 photos | Just found a clip on YouTube that I put on a while ago (7 years!) and thought I would share it with you guys. This was my first attempt at a stationary engine, I bought the castings probably 35 years ago, they got put in loft till one day when I had a bit more time. I don't know if some of you steam boys are building this model if so you might find it interesting.
https://youtu.be/5HtCE3j7Z3I
Alan Edited By JasonB on 04/03/2019 11:11:22 |
Brian H | 04/03/2019 08:39:48 |
![]() 2312 forum posts 112 photos | A very nice piece of model engineering. Brian |
JasonB | 04/03/2019 11:11:43 |
![]() 25215 forum posts 3105 photos 1 articles | That's a nice slow smooth runner. |
Manfred Baer | 03/10/2019 08:19:46 |
15 forum posts 1 photos | Alan, right now I am also completing a ST #4 engine from the same period of casting production. 35...40 years old and still with a cast iron crankshaft. The ST #4 drawings I have were drawn in 1953. I found the dimensions of the webs of the crankshaft to be incomplete in the drawing. The size given is 5/8 x 3/8 x ? To what size did you finish yours? Thanks, Manfred |
JasonB | 03/10/2019 08:28:06 |
![]() 25215 forum posts 3105 photos 1 articles | About 1 1/8 to should do, The later drawing has the ends 5/16" from the pin and shaft ctrs but that does have a smaller 3/8" pin but still gives 1 1/8" on the later engines
Edited By JasonB on 03/10/2019 08:31:54 Edited By JasonB on 03/10/2019 08:34:24 |
Manfred Baer | 03/10/2019 09:39:02 |
15 forum posts 1 photos | Jason, Many thanks for your help. I think I'm going to adopt the dimensions of the built-up crankshaft as pictured in the more recent drawing you supplied. Regards, Manfred |
JasonB | 03/10/2019 09:41:57 |
![]() 25215 forum posts 3105 photos 1 articles | Just looked at it again, the pin is actually still 7/16", just the two ends reduced to help with spacing on the built up version |
AJW | 04/10/2019 19:41:05 |
![]() 388 forum posts 137 photos | Manfred, sorry I've only just seen your post. Not sure where I located my original drawings! but having a quick look at the engine the crank webs measure 3/8 by 3/4. I also upped the bearing diameters to 1/2 Hope this helps?
Alan |
Manfred Baer | 04/10/2019 23:13:31 |
15 forum posts 1 photos | Hi Alan, Many thanks. Problem solved. Manfred |
