Threading a bar for 6ba
Former Member07/02/2019 16:07:32
1329 forum posts
Howard Lewis07/02/2019 16:15:20
7227 forum posts
21 photos
The Model Engineer's Handbook, Third Edition, by "Tubal Cain" gives the top diameter of 6 BA as 0.1102" or 2.80 mm, so you should be OK with 0.110"
Clive Brown 107/02/2019 16:39:16
1050 forum posts
56 photos
Bill,
Have you considered buying 6BA threaded rod? Rather less hassle than DIY if you need any significant length.
Lots of hits on google/Ebay in several materials.
Neil Wyatt07/02/2019 17:03:32
19226 forum posts
749 photos
86 articles
That's right althouigh slightly undersize won't do any harm.
I doubt you will be able to buy those sizes off the shelf.
The Novice Engineer07/02/2019 17:11:44
85 forum posts
72 photos
Try here for 6BA Studding
https://maccmodels.co.uk/ba-fastners-washers/ba-studding/6-ba-steel-studding.html
or click on the link below
not done it yet07/02/2019 17:28:15
7517 forum posts
20 photos
I expect you can use any size above the minimum, but if long lengths you will need a traveling steady to turn the rod to size. Are you single pointing or running a die down the rod? As above, buying threaded rod may be easier, but obviously several choices. But threaded rod is expensive if you only need the threads on each end.
JasonB07/02/2019 17:38:24
EKP sell 7/64" which will take 6BA quite nicely.
Alternatively can you substitute 3.0mm rod and thread M3
Former Member07/02/2019 18:03:56
1329 forum posts
Ian Skeldon 207/02/2019 19:25:43
543 forum posts
54 photos
Firstly my apologies is this post is considered to be hi-jacking the original thread (there's a pun in there somewhere).
What is considered to be the best way to create very small diameter threads ( 1mm for instance) both internal and external, can you buy taps and dies in that sort of size?
Thanks,
Ian
Benjamin Day07/02/2019 19:34:50
61 forum posts
Ian, search watchmaker die plate. Several size dies are all on one plate, they usually come with the silly tiny taps too. Hope this helps!
IanT07/02/2019 20:08:56
2147 forum posts
222 photos
Hi Ian S2
Surprisingly (at least I was surprised) Machine Mart sell a set of taps and dies that range from 1mm to 2.5mm. I've only used mine on brass (and will not use them on ferrous at all) but they seem OK. Usual cautions - you need to guide the tool - both the taps and dies in these sizes - especially the small ones. I've just checked and they are currently £38.39 a set
Probably not top quality at that price but for occasional (and careful) use they were the best option for my needs.
IanT
Nick Clarke 307/02/2019 20:22:08
1607 forum posts
69 photos
Posted by Ian Skeldon 2 on 07/02/2019 19:25:43:
Thanks,
Ian
I have the set that IanT suggested and second his views.
Have a look at Tracy Tools website, or if you are at Doncaster Show pick up one of their catalogues. - usual disclaimer - just a satisfied customer - other suppliers are available etc etc
Ian Skeldon 208/02/2019 20:45:23
543 forum posts
54 photos
Thank you Benjamin, IanT and Nick, I will check out both of those suggestions.
Ian
Chris Trice09/02/2019 11:20:21
1376 forum posts
10 photos
https://www.amazon.co.uk/Small-0-70mm-Plate-Match-Postage/dp/B00BJ2RFYW
Chris Trice09/02/2019 11:22:20
1376 forum posts
10 photos
https://www.amazon.co.uk/Rolson-59154-HSS-Mini-Tap/dp/B0080R1M6G
