Brian H | 02/02/2019 07:47:23 |
![]() 2312 forum posts 112 photos | I've been trying to source some 3/32" c/s copper rivets but no one seems to stock them anymore. It's not a huge problem, I can turn (not talking lathe work here) some snaphead ones into c/s but the lack of them at suppliers puzzled me. Brian |
Former Member | 02/02/2019 09:00:45 |
1329 forum posts | [This posting has been removed] |
Chris Trice | 02/02/2019 09:01:35 |
![]() 1376 forum posts 10 photos | Same with copper flat head armour rivets, also 3/32nd. I ended up turning brass ones. |
Harry Wilkes | 02/02/2019 10:23:52 |
![]() 1613 forum posts 72 photos | Check out this supplier **link** H |
Brian H | 02/02/2019 15:12:00 |
![]() 2312 forum posts 112 photos | Many thanks for the replies but I need 3/32" X 5/8" and I think I'll just set to and make some. Brian |
Samsaranda | 02/02/2019 15:33:29 |
![]() 1688 forum posts 16 photos | H, are you aware that your link is to a supplier located in the USA, my experience is that the products are usually reasonably priced but the carriage costs can be eye wateringly expensive in comparison, I speak from experience. Dave W |
Nick Hughes | 02/02/2019 16:32:39 |
![]() 307 forum posts 150 photos | For the UK, try contacting:- http://www.sapphireproducts.co.uk/index.htm |
Harry Wilkes | 02/02/2019 16:41:26 |
![]() 1613 forum posts 72 photos | Posted by Samsaranda on 02/02/2019 15:33:29:
H, are you aware that your link is to a supplier located in the USA, my experience is that the products are usually reasonably priced but the carriage costs can be eye wateringly expensive in comparison, I speak from experience. Dave W Point taken Dave H |
Richard Wilson 4 | 02/02/2019 16:41:44 |
5 forum posts | When I needed some csk rivets a while ago, I drilled a piece of MS flat using a shank sized drill, then countersunk the hole. Put a round head rivet in the hole, tap the head flat with a light hammer, and Bingo! you have a countersunk rivet. Works particularly well with copper rivets.
Richard |
Brian H | 02/02/2019 16:54:05 |
![]() 2312 forum posts 112 photos | Posted by Richard Wilson 4 on 02/02/2019 16:41:44:
Richard That's exactly what I intend to do Richard but thanks for sharing that. Brian |
Ian Hewson | 02/02/2019 17:46:13 |
354 forum posts 33 photos | You don’t even need a rivet, a piece of whatever type of material you are using put in to the countersunk hole can be hammered in using a ball pein hammer to close it into the hole. The try squares I made 60 years ago and still use were made this way, no sign of the joint or rivets showing. |
