Small Milling/Drilling Spindle (again)
Steve Crow07/01/2019 17:08:09
429 forum posts
268 photos
Hello, I posted on this same subject a few months ago but I've struggled to come up with a compact design using bearings. These are my requirements:-
I want to make an 8mm watchmaker spindle for my Sherline lathe.
20mm dia. housing. (O/D of spindle is 1/2"
Housing no more than 3" long.
To be used for drilling and very light milling/engraving.
Max speed will be 5000 rpm.
How about using bronze bushes? Don't Potts and other spindles use them? Could I use Oilite bearings?
If anyone has any thoughts, advice or designs I would be very grateful.
Many thanks, Steve
HOWARDT07/01/2019 17:29:59
1081 forum posts
39 photos
Use a combined needle and ball thrust running on hardened shaft. Shaft would need to be ground to attain best fit.
Steve Crow07/01/2019 17:48:48
429 forum posts
268 photos
Sorry about the weird emoji thing in my post. It's meant to be a bracket.
John Haine07/01/2019 18:00:00
5563 forum posts
322 photos
There's a useful book on "spindles" in the WS Practice series. I don't think you need to harden the shaft especially if you use rolling bearings. The Quorn spindle is 8mm I think, maybe that would be a good design, or basis for one? I think you'll find 5000 rpm limiting with small cutters, aim for much faster. Main problem is that common bearings with 1/2" bore will have too large an outside dia - Quorn uses magneto bearings. I got some special bearings from Ketan at Arc for an MT2 spindle where I needed a smaller OD housing, they had much smaller balls than normal so the difference between OD and ID was quite small - worth asking him perhaps?
Steve Crow07/01/2019 18:00:06
429 forum posts
268 photos
Posted by HOWARDT on 07/01/2019 17:29:59:
Thanks Howard but that set up would be too bulky. I'm looking for something more compact - hence bushes.
Michael Gilligan07/01/2019 18:14:00
23121 forum posts
1360 photos
Sorry, Steve ...It's your choice, of course, but I still can't understand why you decided against adapting the WW headstock.
[quote] Much as I agree with Michael's suggestion to use my existing headstock, I do feel the urge to make one from scratch.[/quote]
Previous thread, for reference:
Edited By Michael Gilligan on 07/01/2019 18:14:48
Enough!07/01/2019 18:21:31
1719 forum posts
Posted by Steve Crow on 07/01/2019 17:48:48:
Always use a space in front of a closing parenthesis on this site.
HOWARDT07/01/2019 18:35:14
1081 forum posts
39 photos
Igus L250 flanged bearing, not read the specs but certainly smaller so long as thrust is light. Maintaining endfloat may need a spring loaded end thrust face but as diameters are small will work. Spring could be wavy washer.
JasonB07/01/2019 19:08:46
As was suggested a couple of months ago, use one of the designs from the spindle book and adjust sizes to suit your small needs.
Take this one for example
At the business end use a 61701RS thin bearing, 12mm ID and 18mm OD
Front nut threaded M19 x 0.5 will just fit your 20mm block.
Rear nut that bears against the inner race of the front bearing M12 x 0.5
11.3 OD spindle back to the rear bearing then step down to 10mm dia
Rear bearing 61700RS 10mm ID x 15mm OD
10mm ID drive pulley
M10 x 0.5 Nut to pull the pulley and bearing inner tight up against the 11.3mm dia.
Edited By JasonB on 07/01/2019 19:10:24
geoff walker 107/01/2019 19:53:14
521 forum posts
217 photos
Hi steve,
MEW issue number 73 has a article on a re designed Potts milling spindle..
The spindle and the housing have been modified, based on a illustration in a watchmakers book by Donald de Carle.
Looks very tricky to make but the author of article maintains it would be very accurate and suitable for high speed work.
It uses double opposed cone plain bearings. It is slimline design and like I say not easy to make but it may be of interest to you.
I have a copy of the magazine. You can have it for postage (paypal £2).
Message me if you are interested
Geoff
Ady107/01/2019 20:05:48
6137 forum posts
893 photos
I like the upgraded Drummond system because it makes different bearings do different jobs
There are the sleeve bearings in the original design around the spindle
There are roller bearings at each end 90 degrees to the spindle
So all loading scenarios are covered
As an additional contribution to the mix I noticed a huge stiffness improvement when the front roller bearing was fitted at the front and rested on the housing, it made the spindle behave like a better machine with a bigger spindle
GL
Edit: The drummond bronze bearing adjustment system is worth considering too, it's very strong and reliable but it's not simple to replicate unless you have a good skill level
Edited By Ady1 on 07/01/2019 20:11:28
Steve Crow08/01/2019 11:09:28
429 forum posts
268 photos
Posted by Michael Gilligan on 07/01/2019 18:14:00:
Hi Michael,
I did come round to your suggestion but the WW headstock is too big for the very limited space I have.I want to be able to mount the spindle horizontally on the cross slide at centre height as well as on my vertical slide. I only have 23mm from cross slide to centre height. I have a headstock riser block but that just complicates other things.Another problem with the WW is the pulley position would mean getting a drive to it would be a nightmare.
Thank you anyway.
Edited By JasonB on 08/01/2019 11:36:35
Michael Gilligan08/01/2019 13:41:52
23121 forum posts
1360 photos
Thanks for the clarification, Steve yes
I've been thinking about your question whilst out for my 'fresh air and exercise' walk.
As you are very limited on space ... I would make the body from good cast iron, or bronze, and turn the bearing surfaces directly into it. Preferably a double cone each end [as per the classic watchmaker's lathe headstock bearing]; but realistically, I'm sure a single cone each end would do nicely.
Plain cone bearings tend to 'bed in' rather than wearing out.
Steve Crow08/01/2019 18:33:23
429 forum posts
268 photos
Thank you Jason, I've reread the Spindle book and I like your idea very much. I think I can beef up the housing to 1" and go with slightly bigger bearings. Do you think there is much advantage in a double set of front bearing as in some designs in the book?
Michael, I'm also liking your idea for cone bearings into bronze. Any idea of the best angle for such cones?
Also, has anybody built the wheel cutting frame described in the Spindle book?
Cheers, Steve
JasonB08/01/2019 18:40:06
Two at the front would not hurt and if you stay with the thin section ones they are only 4mm wide.
geoff walker 108/01/2019 18:58:25
521 forum posts
217 photos
Steve
Steve.
In the potts article, MEW 73 the included angle is given as 8 degrees. It has a double cone at each end as per Michaels suggestion.
Geoff
Michael Gilligan08/01/2019 19:02:46
23121 forum posts
1360 photos
Posted by Steve Crow on 08/01/2019 18:33:23:
Any 'self releasing' taper would probably do
... but I would guess 20° to 30° included angle. [*]
The optimum would depend upon the balance of axial and radial forces.
[*] Edit: assuming that we are talking about single tapers at each end.
The double taper, of course, has one steeper and one shallower, to achieve the best of both.
Edit: This may help inform your choice:
http://www.dlindustrial.com/profiles/blogs/steep-tapers-fast-tapers-at3-and-what-it-means
Edited By Michael Gilligan on 08/01/2019 19:10:10
Michael Gilligan08/01/2019 20:26:17
23121 forum posts
1360 photos
These might be useful, for the traditional angles :
Steve Crow09/01/2019 15:43:31
429 forum posts
268 photos
I've a couple of more questions.
The bearing retention nuts. Is brass ok?
Also, what is the minimum "step" to retain a bearing on shaft? For example a 15mm bearing against a 5/8" diameter is less than half a mm each side. Do I need more meat?
Cheers, Steve
duncan webster09/01/2019 18:25:17
5307 forum posts
83 photos
If you go on SKF website they give all relevant mounting dimensions
