fizzy | 05/01/2019 10:22:11 |
![]() 1860 forum posts 121 photos | The rocket, currently on display at MOSI has cylinders at about 5 degrees from parallel to the ground and yet in most illustrations they look to be nearer to 45 degrees, can anyobe shed light on why this is? |
John Haine | 05/01/2019 10:31:50 |
5563 forum posts 322 photos | Hmm, a mystery. Must be rocket science... You are quite right - also see this video of a replica, obviously connected with MOSI. |
Pete White | 05/01/2019 10:41:25 |
223 forum posts 16 photos | Got this wrong, from the title thought you were planning on building one. lol Anyway couldn't help with that or the real question. Did like the video of the replica though. Pete |
Keith Long | 05/01/2019 10:43:45 |
883 forum posts 11 photos | Fizzy if you do a google search on "Stephenson's Rocket, history" you should find a Wikipedia page about the Rocket. Part way down is a heading "modifications". According to "The Engineer" publication at that time, 12 months after the Rainhill trials Rocket had been modified so much that it looked like a different locomotive - with near horizontal cylinders. |
fizzy | 05/01/2019 10:47:08 |
![]() 1860 forum posts 121 photos | Thanks - just found same info on mosi - The remains of Rocket we see today on display at the Science and Industry Museum look different from the locomotive seen at the Rainhill Trials, partly because of the dull patina of its finish compared to its bright yellow paintwork when it was first made. A larger smokebox has been fitted to its front end, and its cylinders have been lowered from the upper part of the boiler down to a near horizontal position.
Doesnt say why though. |
John Haine | 05/01/2019 10:58:26 |
5563 forum posts 322 photos | Possibly because they would be nearer the frame and stiffer? |
Ian S C | 05/01/2019 11:13:25 |
![]() 7468 forum posts 230 photos | From what I can find out, the angle of the cylinders was 35*, later reduced to 8*( the preserved one in the London Science Museum has the cylinders in the 8* position. Another site quotes the angle a 45*, and later nearly horizontal. Probably these engines in their day exceeded what we call "rocket science". Ian S C |
Weary | 05/01/2019 12:24:01 |
421 forum posts 1 photos | The angle of the cylinders was reduced to reduce the propensity of steeply angled cylinders to lift and lower the driven wheel with each thrust. The development of 'Rocket', the 'Northumbrian' class were built with the cylinders at the lower angle.
The Science museum produced a technical booklet about 'Rocket' some years ago which went into forensic detail over the remains as they are currently and showed that in its' short working life the loco underwent significant changes. Technological development of the steam locomotive was moving at such a pace that it was outmoded almost immediately upon entering service.
Regards, Phil |
fizzy | 06/01/2019 11:21:51 |
![]() 1860 forum posts 121 photos | Im actually off to see the preserved Rocket this afternoon in Manchester. I built a 7.25 gauge Invicta and experienced the problem of axle movement first hand. Tight suspension cured the problem. So if one were to build a replica in 7.25 gauge either inclination would be accurate?
