AJW | 01/01/2019 16:19:52 |
![]() 388 forum posts 137 photos | I require some posh 2ba and 0ba steel washers, I think they are called engineering washers? I believe they are produced from bar stock and have a small chamfer to one face. Alan |
Jeff Dayman | 01/01/2019 16:29:07 |
2356 forum posts 47 photos | If you have access to a lathe, or know someone who does, why not drill and turn a mild or stainless bar to OD and ID required, chamfer to suit, part off as many as you need. Far cheaper than buying them and may be less time to make them than searching for them. Don't need any plating paint or oiling for corrosion resistance if you make them in stainless. |
Andrew Johnston | 01/01/2019 16:42:34 |
![]() 7061 forum posts 719 photos | Posted by Jeff Dayman on 01/01/2019 16:29:07:
If you have access to a lathe, or know someone who does, why not drill and turn a mild or stainless bar to OD and ID required, chamfer to suit, part off as many as you need.... That's what I do, although I have the luxury of a repetition lathe which simplifies production once it is set up: Andrew |
JasonB | 01/01/2019 17:06:08 |
![]() 25215 forum posts 3105 photos 1 articles | As 0BA is 6mm OD you will have more luck finding M6 ones and may even be able to get away with M5 for the 2BA. Accu do both |
AJW | 01/01/2019 18:02:46 |
![]() 388 forum posts 137 photos | Thanks for replies, I know they can be made it's just that I thought they would be easy to source! Thanks for link Jason. Alan |
roy entwistle | 01/01/2019 18:31:32 |
1716 forum posts | Trouble with making washers is that you make as much swarf as washers unless you can find a zero thickness parting tool Roy |
Kiwi Bloke | 01/01/2019 19:44:38 |
912 forum posts 3 photos | Have you tried asking your local nut & bolt supplier for 'T&C' washers (Turned & Chamfered)? |
AJW | 01/01/2019 20:01:39 |
![]() 388 forum posts 137 photos | One of my tomorrow jobs!! Alan |
Vic | 01/01/2019 21:45:57 |
3453 forum posts 23 photos | I’ve not needed to make any for a while but in the past I’ve made extra thick “machine washers” for clamping setups. Standard washers always seem a bit thin for this or is it just me? |
Ady1 | 01/01/2019 23:28:21 |
![]() 6137 forum posts 893 photos | They probbly stamp them out of strip plate nowadays |
Hopper | 01/01/2019 23:34:24 |
![]() 7881 forum posts 397 photos | Posted by Vic on 01/01/2019 21:45:57:
I’ve not needed to make any for a while but in the past I’ve made extra thick “machine washers” for clamping setups. Standard washers always seem a bit thin for this or is it just me? Yes hardware store washers will bend etc as they are made of malleable Chinese cheesium. If you buy Grade 8 washers from a fastener supplier they will last a lifetime for clamping etc. |
John McNamara | 02/01/2019 01:15:34 |
![]() 1377 forum posts 133 photos | Given the small size if you don't have access to a lathe. Get some grade 8 washers. place them on a bolt with a nut to clamp them then chuck them in an electric drill and then carefully file the chamfer. |
"Bill Hancox" | 02/01/2019 06:08:12 |
![]() 257 forum posts 77 photos | Posted by Andrew Johnston on 01/01/2019 16:42:34:
If you have access to a lathe, or know someone who does, why not drill and turn a mild or stainless bar to OD and ID required, chamfer to suit, part off as many as you need.... That's what I do, although I have the luxury of a repetition lathe which simplifies production once it is set up Andrew On this side of the ditch suppliers refer to these as Williams Washers. I keep several sizes under the lathe. The ones I purchase from Fastenal tend to be on the hard side which provides for an even torque without scoring or damaging the material at hand. |
AJW | 02/01/2019 08:51:49 |
![]() 388 forum posts 137 photos | Thanks once again, I have always called these engineering washers! and have searched accordingly. Searching for chamfered washers brings up more possibilities, I found on the bay a seller (zorotoolsuk) selling a variety of sizes and I have ordered 250 M6 chamfered steel (unplated) washers for ?5 post free. Not bad I thought! Alan |
