larry phelan 1 | 31/12/2018 12:01:17 |
1346 forum posts 15 photos | I, want to make a mobile access platform to use for cutting my hedges and reaching my gutters [single story house ] I am considering using semi bright box tubing to make up four frames, each frame being welded up as a separate unit,so that it could be taken apart for storage,and bolted together as required. The size I have in mind is something about 8 or ten feet long x 2 ft wide x 4 ft high. I think I may need struts to brace it on the outer side. Having looked up to see what is available,I found two sizes which might suit : 50 x 25 x1.5 or x 2mm 40 x 40 x 1.5 or x 2 mm Anything bigger would be too difficult to move even though the unit will be fitted with wheels at one end and handles at the other. Any advice, suggestions,comments,good,bad,or indifferent,welcome ! It it is considered to be a No-No,feel free to say so,it,s just that ladders and I ,do not see eye-eye anymore. Thanks for any ideas, Larry. |
Farmboy | 31/12/2018 12:20:06 |
171 forum posts 2 photos | If you are not averse to buying one rather than making, it might be worth looking at this site: I don't get on with normal ladders these day but I found these very stable and infinitely adjustable for uneven ground as well. I have the 'Junior' size which should reach the gutters on a bungalow. They aren't lightweight but they do fold flat easily for storage. Someone better qualified than me will no doubt advise on your actual question Mike. |
Sam Longley 1 | 31/12/2018 12:39:48 |
965 forum posts 34 photos | Make a couple of 4 ft square towers of the required height but make them so one will fit on top of the other for double height so you have a tower . ( you could just buy a small tower & use it in 2 halves - they are fairly light & easy to store away) then get a 10,12, or15ft Youngmans with a handrail fitted one side.Plonk the Youngmans on the 2 towers & you have a nice long stable platform.which is safe & easy to move around You can get a 12 aluminium staging( Youngmans) for around £100 & stick your own uprights on one side with a handrail so you do not step back to admire your work & break your neck
Edited By Sam Longley 1 on 31/12/2018 12:44:54 |
DMB | 31/12/2018 12:59:30 |
1585 forum posts 1 photos | Go and look, carefully note what scaffolding companies do and copy them for safety. One example not mentioned so far, is the use of a builders plank secured horizontally to form a kick board so you don't go down feet first between platform and handrail. Health n Safety requirement. |
larry phelan 1 | 31/12/2018 13:24:58 |
1346 forum posts 15 photos | Much useful info there,but does anyone know what size section I should use,even if I go for two towers,rather than one unit ? I,m thinking about moving this alone,on grass,that,s the reason for the wheels. |
Bazyle | 31/12/2018 13:58:10 |
![]() 6956 forum posts 229 photos | You haven't said how high you want your feet to be off the ground. I have a hobbyist level steel tube sectional platform that is made from about 1 1/2 in tube about 1.5mm wall thickness. It is meant to go up about 15 ft but it is so wobbly by bad design that I only go up 5ft and then only when it is attached to something firm like some proper scaffolding. Proper sectional towers are better thicker, heavier, safer, and expensive. When building the Men's shed we used some extendable trestles. I think Axminster have a selection of designs that also can be used for other things like saw horses etc. Another option might be multiple step ladders so they can be strapped together to brace each other. They too have multiple other uses instead of having to be stored for use once a year. Another thing that is very helpful for doing gutters is a brace that clips to the top of a ladder to hold it away from the wall by a foot or so. |
Howard Lewis | 31/12/2018 15:45:42 |
7227 forum posts 21 photos | If you want to buy, you could consider one the four way folding ladders. (Ladder, steps or staging). Depending on where you buy it the price will vary between £60 (LIDL or ALDI) and £100.(Catalogues). Aluminium, with wider feet for stability.,Weight about 25Kg. Folded about 45 inches high, 12" deep, About 15 Inches wide, plus feet bringing overall width to about 2 feet. Most, maybe not all, come with steel platforms to fit when configured as staging. In staging mode, about 5 feet long and 45 Inches high. So useful that tend to be used for almost all jobs, (longer than small aluminium stels, and easier to move that the extending Aluminium ladder stored on the garage wall. Howard |
FMES | 31/12/2018 16:23:26 |
608 forum posts 2 photos | Why not just hire a platform when you want it? No problem with storage, certification, or wasted construction time. Regards |
