AJW | 29/12/2018 20:29:31 |
![]() 388 forum posts 137 photos | Did a bit of 'fettling' today to enable assembly of parts that I have machined on my Centaur engine. I trial fitted crank with con rod and piston into engine frame with water jacket and cylinder. It suprised me to find the piston protrudes out of the cylinder top by 1/8 inch? Checked through the drawings and it appears to be correct - meaning the piston will be entering into the cylinder head space? Does this sound right, I just assumed the piston would rise to be flush with cylinder top. Alan |
JasonB | 30/12/2018 07:57:37 |
![]() 25215 forum posts 3105 photos 1 articles | Adding up the sizes on the drawing I get that the piston should be Flush the end of the liner at TDC Bed 4.500" + Hopper 2.250" + Liner lip 0.125" = 6.875" Crank Throw 1.000" + Conrod 4.312" + 3/16 + Big End Bearing 0.375" + Pistion 1.000" = 6.875"
Looking at your photos the wrist pin does not look to be in the middle of the pistion
Edited By JasonB on 30/12/2018 12:29:51 |
not done it yet | 30/12/2018 08:26:49 |
7517 forum posts 20 photos | JB, Yeahbut, the other pic, with the piston t’other way up, looks like the piston pin is closer to the other end. Hoptical illusion at work? |
Nick Clarke 3 | 30/12/2018 09:53:23 |
![]() 1607 forum posts 69 photos | Jason - While it doesn't affect your argument I can't get your figures to add up to your second total?? Edited By Nick Clarke 3 on 30/12/2018 09:53:48 |
JasonB | 30/12/2018 10:11:18 |
![]() 25215 forum posts 3105 photos 1 articles | Thank's Nick, it was a typo on the bearing which should have been 0.375, I've edited the post. |
JasonB | 30/12/2018 10:17:40 |
![]() 25215 forum posts 3105 photos 1 articles | NDIY, It does look a longer piston in the other photo, ring and distance of pin from ring groove looks about the same in both. Drawing has a 2" long piston with the pin centrally placed eg 1" from either end. |
AJW | 30/12/2018 11:48:15 |
![]() 388 forum posts 137 photos | Thanks for your replies, must be an optical as the gudgeon pin is in the centre of the piston! Jason, I can confirm the dimensions for the non moving and some of the moving parts but the drawings I have for the connecting rod give an overall length of 4 5/8 (4.625), gudgeon pin c/l to end where big end is secured, which gives the 'moving parts' overall of 7.000in? Which is what's giving the 0.125 bit sticking out the top. I guess it's supposed to end up flush, I will have a measure up of how much material thickness is in the piston crown for a possible mod? Alan |
JasonB | 30/12/2018 12:28:18 |
![]() 25215 forum posts 3105 photos 1 articles | Just looked at the ME series and that gives the conrod as 4 7/16 + 3/16 and overall as 4 5/8 but sheet drawing shows 4 5/16" + 3/16" but with a total length of 4 5/8" which is 1/8" different! |
AJW | 30/12/2018 12:37:18 |
![]() 388 forum posts 137 photos | Crikey, what happened there? Think I might cut 1/8 out of the con rod and super glue it. Alan |
MichaelR | 30/12/2018 14:46:31 |
![]() 528 forum posts 79 photos | I know it's to late now for you, but I took the length for con rod / piston off the job when making my Centaur, the piston finish's flush with end of liner.
AJW | 30/12/2018 15:55:36 |
![]() 388 forum posts 137 photos | Hindsight eh! I've decided to shorten the connecting rod, I silver soldered the big end flange on (quite nicely I thought!) So will remove it, I have a centre in the bore of the shaft so I suppose it could be worse! Wonder if there's any more problems round the corner! Alan |
Howard Lewis | 30/12/2018 17:01:23 |
7227 forum posts 21 photos | Shortening the Con rod will produce more side thrust on the piston, and so more friction. It will accentuate the tendency for the piston to "rock" within the bore clearance, which could lead to problems with the piston skirt and the rings, risking scuffing! My advice would be to shorten the top land, if possible. If the drawing calls for a taper, it would be advisable to maintain the clearances, to minimise the risk of problems. H T H Howard |
AJW | 30/12/2018 17:09:46 |
![]() 388 forum posts 137 photos | Thanks for your info. I did look at reducing the height of the piston but there isn't really enough material at the crown to do this although this is obviously the easiest option. By shortening the con rod I agree it would impart more side thrust to the cylinder/piston but this will then comply with the other drawings which are around. Just annoying! Alan |
Howard Lewis | 30/12/2018 17:30:06 |
7227 forum posts 21 photos | At the risk of teaching granny to suck eggs. You don't hold the Piston in the chuck to face off the crown. You make a dummy Gudgeon pin, with a radial / diametral tapping on the centreline. You then turn up a stepped "bung to be as close a fit as possible to the bore at the bottom of the piston, and drill it to clear a drawbar with the same thread as in the dummy Gudgeon pin. Having done this do not disturb anything.. Insert the dummy Gudgeon Pin, place the Piston on the "bung and clamp it in place with the drawbar. It should now run concentric, so that the crown can be faced off to reduce the compression height of the piston to the correct dimension above or below the top of the liner. Howard |
AJW | 30/12/2018 17:35:59 |
![]() 388 forum posts 137 photos | I realise this is the way to turn material from the piston top, but there is insufficient material on the crown to be able to do this. It would end up too thin to be reliable! Alan |
AJW | 31/12/2018 18:29:15 |
![]() 388 forum posts 137 photos | Today saw removal of the big end flange from the connecting rod, shortening it the required amount and silver soldering it back together. Didn't seem to take as long as I had feared and because I had a centre in the flange end of the rod it was a straightforward modification. Oh well, onto the next part! Alan |
