Southbend 13" lathe.
Bill York25/11/2018 09:59:09
55 forum posts
58 photos
Good morning guys and dolls, I am refurbishing a Southbend 13" lathe and it needs complete replacement of the wicks and felts, can anyone steer me towards a supplier, I also need a parts/disassembly/reassembly manual if there is such a thing. Any info would be great and appreciated.
John Rudd25/11/2018 10:56:02
1479 forum posts
This any good?
http://www.lathes.co.uk/southbend/1954-south-bend-rebuild.pdf
Bill York25/11/2018 10:59:30
55 forum posts
58 photos
Brilliant, many thanks. Still need a UK supplier for the wick and felt.
Chris Evans 625/11/2018 11:04:13
2156 forum posts
I had a Southbend "Heavy Ten" of 1942 vintage for 45 years. Eventually parted with it for a bigger lathe.
Boxford lathes are a copy of the Southbend so maybe a look at their spares supply may yield what you need ?
Bill York25/11/2018 11:18:50
55 forum posts
58 photos
Posted by Chris Evans 6 on 25/11/2018 11:04:13:
This one is a 1938 supplied to the Ministery of supplies for the war effort and was on a Royal Navy ship for many years before ending up in a goverment test station. I have included some pics if you want to check my albums.
Pete Rimmer25/11/2018 11:51:35
1486 forum posts
105 photos
Steve Wells' website is pretty much the go-to repository for South Bend info and literature.
http://www.wswells.com/
How much of a refurbishment are you doing? I'm currently renovating a Heavy 10. Bed and saddle re-ground, all the other ways re-scraped. Full strip and rebuild of the rest of the mechanicals and of course re-painted all over.
Edited By Pete Rimmer on 25/11/2018 11:55:06
ega25/11/2018 12:01:20
2805 forum posts
219 photos
Posted by Bill York on 25/11/2018 10:59:30:
If you are cutting your own felts, I can supply the material (thick ex-papermaking felt).
Edited By ega on 25/11/2018 12:01:42
Bill York25/11/2018 12:32:31
55 forum posts
58 photos
Posted by Pete Rimmer on 25/11/2018 11:51:35:
Ground up strip and rebuild, repair as and when needed, no regains or scrape, new paint and I will be keeping it and selling my other lathe which is more suited to a model maker which I an not.
Bill York25/11/2018 12:33:14
55 forum posts
58 photos
Posted by ega on 25/11/2018 12:01:20:
That would be great, how much
Bill York25/11/2018 12:33:22
55 forum posts
58 photos
Bill York25/11/2018 12:34:05
55 forum posts
58 photos
ega25/11/2018 13:42:18
2805 forum posts
219 photos
Posted by Bill York on 25/11/2018 12:34:05:
Just PM me your address and say what size you want and I'll post - no charge, but consider "paying forward".
Brian Wood25/11/2018 19:23:25
2742 forum posts
39 photos
Bill,
I wonder if the Myford S7 front spindle bearing oiling wick is the right diameter for your wicks? From memory they are about 1/4 inch in diameter
Pete Rimmer25/11/2018 19:30:29
1486 forum posts
105 photos
South Bend wicks are much larger than 1/4" Either 7/16" or 1/2" I didn't measure mine but they are quite fat with a spring around them.
Pete Rimmer25/11/2018 19:34:04
1486 forum posts
105 photos
Posted by Bill York on 25/11/2018 12:32:31:
I don't blame you for not wanting to grind the bed, it's quite expensive and now that Brian's retired I don't know who else I'd take it to. For sure though I would give serious consideration to working over the cross slide and compound ways. I don;t think I've ever seen a used lathe more than a few years old that didn't need some kind of attention to the minor ways.
Bill York25/11/2018 19:44:07
55 forum posts
58 photos
Posted by Pete Rimmer on 25/11/2018 19:30:29:
Yes the SB spindle oiler is about 1/2" x 4" and as you say have a spring action that keeps the hard felt tip in contact with the spindle.
Bill York25/11/2018 19:46:35
55 forum posts
58 photos
Posted by Pete Rimmer on 25/11/2018 19:34:04:
I will have to do some work as you say on the minor ways but the lathe will not be needed to work to 2/10ths
Robbo25/11/2018 23:07:51
1504 forum posts
142 photos
You might also like to look at the ebay store (for South Bend) at **LINK**
Bit eye-watering though crying
thaiguzzi26/11/2018 04:02:52
704 forum posts
131 photos
+1.
I'd use this guy. Very helpful, has all the common consumables, parts lists, and his own very good rebuild manuals.
The go-to-guy on 9-14" Southbends.
