Kevin F | 04/11/2018 12:02:09 |
96 forum posts 24 photos | I’m toying with the idea of fitting a myford super 7 quick change gearbox to my myford ML7 . What modifications would I need to make if any ? Thanks in advance .
Nick Hulme | 04/11/2018 12:08:01 |
750 forum posts 37 photos | If you have the end covers and lead screw with the gearbox you shouldn't have any issues. |
daveb | 04/11/2018 13:37:53 |
631 forum posts 14 photos | Not sure about ML7s but you have to change the output gear on the tumbler if retrofitting a gearbox to the Super7. You will probably need a shim between the gearbox and the mounting point on the bed. As far as I know, the shim is needed on all lathes except the PCF models. |
Swarf, Mostly! | 04/11/2018 13:44:27 |
753 forum posts 80 photos | Hi there, Kevin, Do you have the installation Instructions for the gearbox? If not, I suggest you obtain one and read it. (I believe they are available on-line, maybe from the 'Files' section of the of the Yahoo Myford group. ) Does your lathe have the necessary tapped holes (¼" BSF ) in the front shear of the bed? They are between the two holes that have the push-screws that push the head-stock against the back shear. Some early lathes didn't have them, mine included, so I had to drill and tap them. Beeston Myford used to offer a drilling jig for this purpose, though they denied all knowledge when I phoned until I was connected to the late lamented Malcolm - he found me one. You temporarily remove the push-screws and use their tapped holes to hold the drilling jig. The gearbox has a third screw at a lower level - that fixed into an existing tapped hole, from memory, one that previously held the left-hand lead-screw bracket. Best regards, Swarf, Mostly! |
Kevin F | 04/11/2018 14:00:10 |
Posted by Nick Hulme on 04/11/2018 12:08:01: If you have the end covers and lead screw with the gearbox you shouldn't have any issues. It’s all there apart from the lead screw . Thanks for the replies . |
Kevin F | 04/11/2018 18:42:03 |
96 forum posts 24 photos | I don’t have the installation instructions , I also checked to see if I have the 1/4bsf tapped holes , alas I don5 hav3 these either , I’m still waiting on th3 seller to inform me as too wether they have the lead screw .
Posted by Swarf, Mostly! on 04/11/2018 13:44:27: Hi there, Kevin, Do you have the installation Instructions for the gearbox? If not, I suggest you obtain one and read it. (I believe they are available on-line, maybe from the 'Files' section of the of the Yahoo Myford group. ) Does your lathe have the necessary tapped holes (¼" BSF ) in the front shear of the bed? They are between the two holes that have the push-screws that push the head-stock against the back shear. Some early lathes didn't have them, mine included, so I had to drill and tap them. Beeston Myford used to offer a drilling jig for this purpose, though they denied all knowledge when I phoned until I was connected to the late lamented Malcolm - he found me one. You temporarily remove the push-screws and use their tapped holes to hold the drilling jig. The gearbox has a third screw at a lower level - that fixed into an existing tapped hole, from memory, one that previously held the left-hand lead-screw bracket. Best regards, Swarf, Mostly!
Robert Butler | 04/11/2018 18:45:54 |
511 forum posts 6 photos | Kevin I have the jig and instructions somewhere? Robert Butler |
Clive Brown 1 | 04/11/2018 19:08:27 |
1050 forum posts 56 photos | Posted by Kevin F on 04/11/2018 14:00:10:.
It’s all there apart from the lead screw . In that case, won't you will have to modify, ie shorten, your existing lead screw? That was the case when I fitted my Boxford "B" with a gearbox. Fortunately the leadscrew passed through the spindle bore, which allowed machining of the end. Will this be the case for a Myford? |
roy entwistle | 04/11/2018 19:34:42 |
1716 forum posts | Doesn't the Super 7 have a larger diameter leadscrew than the ML7 ? Edited By roy entwistle on 04/11/2018 19:45:04 |
Robert Butler | 04/11/2018 19:59:08 |
511 forum posts 6 photos | Kevin I have found the jig, the instructions as to how to fit, modify the leadscrew and clasp nut carrier are all contained in the Myford Quick Change Gear Box supplement. I would expect as the shears are not tapped for the gearbox it is an early model ML7 and has the small diameter leadscrew. I have a spare small diameter leadscrew as well Robert Butler |
Kevin F | 04/11/2018 20:08:24 |
Posted by Robert Butler on 04/11/2018 19:59:08: Kevin I have found the jig, the instructions as to how to fit, modify the leadscrew and clasp nut carrier are all contained in the Myford Quick Change Gear Box supplement. I would expect as the shears are not tapped for the gearbox it is an early model ML7 and has the small diameter leadscrew. I have a spare small diameter leadscrew as well Robert Butler
Thanks Robert , if I buy the gearbox , I’ll be in touch with you . Edited By Kevin F on 04/11/2018 20:08:50 |
Swarf, Mostly! | 04/11/2018 21:22:01 |
753 forum posts 80 photos | Posted by roy entwistle on 04/11/2018 19:34:42:
Doesn't the Super 7 have a larger diameter leadscrew than the ML7 ? Edited By roy entwistle on 04/11/2018 19:45:04 The ML7 lead-screw is 5/8" diameter, the Super Seven lead-screw is 3/4" diameter. However, the left-hand end of the 3/4" lead-screw for use with the gearbox and Super Seven is reduced to 5/8" diameter so it passes through a bore in the gear-box casing. The coupling sleeve between the 3/4" and the 5/8" sections is secured with two roll-pins - it fouls the lead-screw guard attached to the saddle so one of the instructions is to shorten the lead-screw guard. I had to shorten mine by about 3/4" more than specified to avoid losing saddle travel. Later models of the ML7 lead-screw (non gear-box version) have two Woodruff key slots so you still have one after you've shortened the lead-screw. Early lead-screws only had a single Woodruff key slot. Best regards, Swarf, Mostly! |
Nick Hulme | 04/11/2018 23:34:37 |
750 forum posts 37 photos | I have a Super 7 and flirted with the purchase of a QCGB but thank God I didn't, I now have to cut lots of oddball Metric pitches that would involve as much messing about with a gearbox as without and allow me a full range of Metric and imperial pitches without approximations. |
Gordon A | 05/11/2018 00:05:24 |
157 forum posts 4 photos | According to a drawing I've found on thinternet, using the existing left hand tapped hole as reference, the first tapped hole for gearbox is 1.88 inches to the right, and the second 3.748 inches from the reference. They seem to be very odd dimensions. Could somebody confirm please? Gordon. |
Michael Gilligan | 05/11/2018 07:16:23 |
![]() 23121 forum posts 1360 photos | Posted by Gordon A on 05/11/2018 00:05:24:
According to a drawing I've found on thinternet ... It's only a guess, Gordon ... but I suspect that the design dimensions are 1.875" and 3.75" which would be instantly recognisable as convenient fractions. If the drawing was "made from life" the difference is probably due to either manufacturing tolerance, or poor measurement. MichaelG. |
Gordon A | 05/11/2018 21:40:00 |
157 forum posts 4 photos | What you say Michael makes sense, I should have realised this. My excuse is brain fade from late night posting following daughter's 30th birthday celebrations! Thanks, Gordon. |
Michael Gilligan | 05/11/2018 23:06:30 |
![]() 23121 forum posts 1360 photos | Excellent excuse, Gordon MichaelG.
HughE | 05/11/2018 23:06:37 |
122 forum posts | Can't help with ML 7 but converted S7 which required new banjo , leadscrew , change wheels and cover. The instructions from Myford help. Nick I have no problems cutting both metric an imperial threads with the QCGB, only needed to purchase a few extra changewheels as per Brian Woods book. Hugh |
