Tomek | 26/09/2018 12:16:21 |
49 forum posts 25 photos | First of all hello to all forum members. I'm new to the hobby with only little experience so far but after successfully completed few stationery engines i would like to try building a steam locomotive. I was searching for answer which loco would suit me the best and i think 3 1/2 gauge Juliet would be my choice. I could run it in my back garden and castings are cheap enough so even if i make major mistake while machining, replacing a casting with a new one won't hurt as much as it would with 5 inch gauge. I also decide to go for Baker's valve and yes I know Stephenson's would be much simpler but I just love the look of all moving parts on the outside, so Baker's it is I would appreciate if some of the members could share opinions and give a bit of advice maybe. First question would be: where to buy drawings from? Blackgates and Reeves drawings are both 7 sheets where GLR Kennions only 6 and only half a price of the first two? Why is that? Am I missing something? Would let say Reeves drawings be more detailed than GLR? Other thing is where to source castings from? What is your experience about service from different suppliers? Will castings from one be better quality then the others? And finally is there any book describing building a Juliet? I know about ME articles from 1947 and i'm lucky to own some of them but there's lot of referring to previous builds like "machine part as described for Lassie" or "do something as per Lassie notes" and obviously it would be easier to buy one book than collecting dozen of magazines. It's going to be a long time project as i can only spare few hours a week, but certainly any advice from forum members will speed up a build so any comments much appreciated. Thanks!
Neil Wyatt | 26/09/2018 13:31:22 |
![]() 19226 forum posts 749 photos 86 articles | I think the extra sheet is an alternative boiler. I think the series of Juliet was pretty light on build instructions, you may do better to buy a copy of Shop, Shed and Road top cover the bits he left out. There are several online build logs. Neil |
Tomek | 26/09/2018 20:20:40 |
49 forum posts 25 photos | Thanks for your reply Neil. I didn't know there's alternative boiler for this loco. And I will look for a copy of the book you mentioned. Cheers |
Bob Youldon | 26/09/2018 21:16:15 |
183 forum posts 20 photos | Hello Tomasz, Welcome to the forum; I think the GLR drawings are re-drawn, old man Kennion had some sort of trading agreement with the designer LBSC and the others sorce their drawings via the copyright holder Sarick?, look down the adverts to the right if these posts for a link. I have drawings for another of his designs from both Kennions and the then providers and I have to say Kennion's are much clearer. Juliet although a freelance it's a "beginners" engine and I built one with Baker gear many years ago as my first project, There are web sites out there with the whole serial describing the construction (the words and music as LBSC called them). There are loads of Juliets built over the years and they all go well. For a slightly more up market design based on a full sized prototype then I'd suggest Rob Roy, most of the suppliers can supply the castings and materials and again there have been hundreds built; there is a book detailing the construction of the locomotive available and they all go well, a good fun engine. What I would suggest if you have'nt already done so is join your local club or one in your area, generally shed loads of help, assistance, ideas etc. Regards Bob |
Neil Wyatt | 26/09/2018 21:18:34 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Tomasz Osakowicz on 26/09/2018 20:20:40:
Thanks for your reply Neil. I didn't know there's alternative boiler for this loco. And I will look for a copy of the book you mentioned. Cheers The book is useful if you have LBSCs build articles, as he tends to come to a part and say 'as I have described so many times before in these pages...' |
Tomek | 26/09/2018 21:55:59 |
49 forum posts 25 photos | Bob thanks for comment on drawings. Rob Roy would be my second choice but I was worried that 0-6-0 chassis wouldn't take a sharp curves (my garden is about 26 feet wide) not sure what is minimum radius for 3 1/2 but Juliet will manage that. Good tip with joining club. There is actually one nearby and I really should visit them one day. I know they do a public running every Sunday so maybe pop in and have a word with members. Cheers for all replies and if someone could comment on quality of castings from different suppliers that would be great. Thanks |
Simon Collier | 26/09/2018 22:05:24 |
![]() 525 forum posts 65 photos | Good choice, Juliet. Have a look for the build series online as I downloaded it from somewhere a couple of years ago. The book for Tich might be helpful too if you can pick up a copy. |
Fowlers Fury | 26/09/2018 22:19:24 |
![]() 446 forum posts 88 photos | Tomasz, you ask "Other thing is where to source castings from? What is your experience about service from different suppliers? Will castings from one be better quality then the others?" "Same" loco castings do vary in advertised price and the cheaper ones may not match the more expensive ones in terms of machinability or machining allowances. In the past, I have bought cheap and came to regret it.
Bob Perkins | 27/09/2018 07:04:09 |
249 forum posts 60 photos | Tomaz You can download the ME articles from here |
Jan B | 27/09/2018 07:07:20 |
![]() 43 forum posts 11 photos | Welkome to the forum Tomasz. If you google, John-Tom Engine and Model Plans, you can download building instructions copied from articles written by LBSC in Model Engineer. As always you have to check for faults in drawings. I had to make new buffer beams and crankpin was to long. Best is to redraw in Cad, and check that everything fits before starting machining. I have not bought any castings, machined cylinders, wheels and so on from solid material. My track has curvradius of 3 meters and my TICH easily copes with that and I think my Juliet also will. Jan
Tomek | 27/09/2018 08:49:50 |
49 forum posts 25 photos | Thanks everyone for these useful informations. I have found plans before on John-tom website and also manage to find few Model Engineer issues with Juliet articles on Ebay. Jan I didn't realise that drawings can have faults. Obviously errors always happens but I thought these would be corrected by now after so many years. And hats off for building loco without castings, that would probably take me ages ![]() ![]() |
Fowlers Fury | 27/09/2018 09:29:17 |
![]() 446 forum posts 88 photos | " I didn't realise that drawings can have faults. Obviously errors always happens but I thought these would be corrected by now after so many years." If only that were the case ! |
Tomek | 27/09/2018 21:31:03 |
49 forum posts 25 photos | Cheers, will definitely look into this. Well i guess it's time to start shopping for castings ![]() |
