Petrol proof adhesive
AJW08/09/2018 19:23:18
388 forum posts
137 photos
Made a start on my new Edgar T Westbury's Centaur engine project. Started with the base, an aluminium casting with a large cavity underneath. As well as supporting the engine it acts as a fuel tank, the base of which it is suggested to bond in an alloy blanking panel.
All well and good I thought so have been cleaning up the casting and have prepared a piece of 1/8 in ally sheet ready to fill the base.
I was going to use Araldite to fix it in but am not sure about it liking being in full time contact with petrol or use something else?
Alan
Ian B.08/09/2018 19:32:07
171 forum posts
5 photos
Hi AJW,
Not too sure if this will help but emergency repairs to MAZAK carburettor parts could be made with insulating tape and chewing gum. Yes chewing gum. From my days in HM Forces etc. I am sure that in Edgar Westbury's days he did not have access to all the sophisticated technology we have now.
However there is a two part epoxy putty used a lot in modelling called MILLIPUT (www.milliput.com) made in Mid Wales. This was originally for plumbing repairs under water however I note from their website a few moments ago that it also can be used for (and I quote) "temporary repairs to car fuel tanks"
regards
Ian
John Rudd08/09/2018 19:47:42
1479 forum posts
There used to be a product calledd "Petropatch" for car petrol tank repairs... May be suitable if still available marketed by Grenville iirc..
JasonB08/09/2018 19:50:13
I've stuck several similar model fuel tank covers with JBWeld Original (red & black tubes) and have not seen any signs of it degrading.
Edited By JasonB on 08/09/2018 19:54:46
Ron Laden08/09/2018 20:34:30
2320 forum posts
452 photos
Araldite chemical metal would be better than standard Araldite epoxy, Devcon do a good range and as Jason suggests, JBWeld is very good and fuel proof.
Dont know if it is true but I was once told that the rapid set adhesives are not fuel proof but the slower set time types are.
Ron
Edited By Ron Laden on 08/09/2018 20:47:04
Edited By Ron Laden on 08/09/2018 20:49:05
Edited By Ron Laden on 08/09/2018 21:01:21
Trevor Crossman 108/09/2018 20:48:57
152 forum posts
18 photos
Most epoxies cannot be relied on for long term 100% resistance against petrol based fuels with the exception of those which are specially formulated for the construction of composite fuel tanks and they tend to be more expensive than standard lay-up epoxies, MAS is one such resin available from www.ecfibreglasssupplies, though I doubt that you would want the stock quantity. A better alternative for such a small task would be to use an aviation standard fuel sealant PR 1440 which is a virtually indestructible synthetic rubber compound and will resist attack from all forms of gasoline and its additives, it can be obtained from Light Aero Spares or other aviation suppliers, maybe you might know an aircraft maintainer who could get you a small amount.
Trevor.
JasonB08/09/2018 20:49:05
That's why I said the "Original" JBWeld as the faster cure ones don't have all of it's properties and I have heard the same said of Araldite.
Few of its properties listed here including petrol Proof
Edited By JasonB on 08/09/2018 20:53:27
AJW08/09/2018 21:33:09
388 forum posts
137 photos
Thanks guys, I have milliput and nowhere in its writeup does it even mention any type of fuel so I am thinking perhaps not. I also have some original JB weld which once again does not mention any fuel exposure.
Edgar himself suggests Bondafiller but unfortunately I think this particular product has disappeared over the years.
The rubber compound sounds good, will look into that, I guess not to be confused with silicone rubber which swells enormously!
Alan
AJW08/09/2018 21:55:42
388 forum posts
137 photos
Just had a thought, at the last ally pally exhibition I was very impressed with some demonstrated aluminium solder. Seemed to give a good fillet, just the sort of thing i am after. Having a thumb through the bay there appears to be quite a selection of aluminium soldering products
Anyone had any experience of any?
Alan
JasonB09/09/2018 06:58:36
AJW did you not read the link in my previous post where it says "When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical"
Edited By JasonB on 09/09/2018 06:58:48
Ron Laden09/09/2018 09:30:18
2320 forum posts
452 photos
Posted by JasonB on 09/09/2018 06:58:36:
+1
I once used JBWeld original to repair a hole in a motorcycle fuel tank where the adhesive was in direct contact with the petrol (hole was in the bottom of tank) and it was a permanent fix, never a problem.
AJW09/09/2018 10:22:47
388 forum posts
137 photos
Jason apologies for missing that, I wonder why it's not put on the packaging and instructions?
Sounds like a solution - I shall update Edgar!
Alan
Benjamin Day09/09/2018 10:31:35
61 forum posts
just to chime in and say the aluminium solders are very good....big grin on my face when i saw it worked. there are some Russian flux brands that work really well with the stuff too
Pete Rimmer09/09/2018 13:51:21
1486 forum posts
105 photos
JB Weld (not the quick one) is advertised as 100% resistant to petrol once fully cured.
AJW09/09/2018 15:00:30
388 forum posts
137 photos
I have just had another look at my pack of original JB Weld and it makes no mention at all of fuel suitability?
Strange as I would have thought that would be a good selling point.
Alan
Ron Laden09/09/2018 15:21:54
2320 forum posts
452 photos
Sounds as if you are not convinced Alan, despite Jason having sent you the JBWelds spec sheet....?
AJW09/09/2018 16:43:43
388 forum posts
137 photos
Yes, convinced and I am currently using it as I have for the past few years just find it surprising that it's not on the pack!
Perhaps it is on a new pack, mine is quite old.
Alan
Ron Laden09/09/2018 16:57:59
2320 forum posts
452 photos
I dont know if its mentioned on a new pack or not but it made me think of one or two items I have used over the years which I always associate with a particular job. You then eventually read the spec sheet and learn that it can be used for much more.
Ron
JasonB09/09/2018 17:28:34
A sometime member here and contributor to ME and MEW has the soft jaws of his chuck stuck on with JBWeld, does not come into contact with petrol but shows that it is sticky stuff. He also tried some pipe joints as you would find on a model stationary engine upto about 300psi which is when his test pump would not go any higher.
