Alan Waddington 2 | 27/08/2018 14:49:44 |
537 forum posts 88 photos |
My Student 1800 was missing the oft misplaced tapered Headstock bush for turning between centres. I bought one off ebay a few years back and popped it on a shelf.......came to use it today and of course it’s the wrong size Questions are. A- Does anyone have the correct one lying around they wish to sell? Or know where i might obtain one. B- Any idea’s what the one i have is off. Dimensions are 1.622” at the fat end. 1.500” at the thin end. 2.490” Long. With a 3mt oil upt middle. There are a few on ebay, but at least two which are advertised for my machine, clearly are not, so i’m a bit wary, twice bitten and all that. The hole in my headstock measures 1.766”,bit awkward to measure the far end hole, but approx 1.675” with the bush being around the same length as the one i have. |
Simon Williams 3 | 27/08/2018 15:31:55 |
728 forum posts 90 photos | Now here's a knotty little riddle. My Bantam 2 has a bastard size taper up the head stock, which is rumoured to be MT4.5, or some such. It seems Mr Colchester didn't want us buying standard fittings so he made the head stock a funny size, though it may be something to do with the size of the bearings carrying the head stock. Mr Lathes.co.uk has got some comments thereon. Anyway I'd have assumed that your Student was the same, but it can't be. I made a bush for my Bantam, but it's 1.517 - 1.362 by 3.07 ins long. However, when I bought the lathe I was given what was supposed to be the "right" bush, which is much too large. Squirrel that I am I've kept it, and it is 1.809 - 1.656 x 3.036 long. All these dimensions measured with calipers, so somewhere handy but not precise. While those dimensions aren't exactly what you've shown above, they look something useful. You are welcome to try the second bush and see if it is what you are looking for, send me a PM with your address and advise so on here and I'll pop it in the post next week. Hope this works! Rgds Simon |
Alan Waddington 2 | 27/08/2018 15:43:31 |
537 forum posts 88 photos | Posted by Simon Williams 3 on 27/08/2018 15:31:55:
Now here's a knotty little riddle. My Bantam 2 has a bastard size taper up the head stock, which is rumoured to be MT4.5, or some such. It seems Mr Colchester didn't want us buying standard fittings so he made the head stock a funny size, though it may be something to do with the size of the bearings carrying the head stock. Mr Lathes.co.uk has got some comments thereon. Anyway I'd have assumed that your Student was the same, but it can't be. I made a bush for my Bantam, but it's 1.517 - 1.362 by 3.07 ins long. However, when I bought the lathe I was given what was supposed to be the "right" bush, which is much too large. Squirrel that I am I've kept it, and it is 1.809 - 1.656 x 3.036 long. All these dimensions measured with calipers, so somewhere handy but not precise. While those dimensions aren't exactly what you've shown above, they look something useful. You are welcome to try the second bush and see if it is what you are looking for, send me a PM with your address and advise so on here and I'll pop it in the post next week. Hope this works! Rgds Simon That’s very kind of you Simon. Interestingly the dimensions you have given are remarkably close to one on ebay. I suppose the slightly larger fat end could account for the bush sticking out a bit. Will drop you a PM. |
duncan webster | 27/08/2018 16:54:02 |
5307 forum posts 83 photos | When I had a Chipmaster with the taper thing missing I convinced myself it was Jarno, which is as Doesn't help you in finding one of course, but I never needed one, for between centres just chuck a bit of bar i the 3 jaw and turn a point on it |
Neil Wyatt | 27/08/2018 17:06:23 |
![]() 19226 forum posts 749 photos 86 articles | It sounds like it might be the 'thin end' of an MT5 taper. 1.5" is the fat end of MT4.5 so it can't be that. This thread suggests the Student has an MT5 taper: /www.model-engineer.co.uk/forums/postings.asp?th=104715 If that's the case you just need an MT5 to MT3 reducing sleeve - or an MT5 centre. Neil |
Nigel Bennett | 27/08/2018 17:38:32 |
![]() 500 forum posts 31 photos | Yes, it's 4.5MT. It's fairly common, as the Boxford X10 series lathes (280, 330, etc) with the D1-3" camlock have them, as well as the Chipmaster and Bantam lathes. I don't think the Harrison D1-3" camlock lathes are like that. I suppose the thinking was that 4MT was too restricting and 5MT too big for the spindle. |
Alan Waddington 2 | 27/08/2018 17:47:05 |
537 forum posts 88 photos | Good call Neil, just tried a 5mt -1mt reducing sleeve i had lying about and it seems to fit perfectly. No good for my purposes, but proves a point. 👍 |
Neil Wyatt | 27/08/2018 18:44:10 |
![]() 19226 forum posts 749 photos 86 articles | The thanks are due to Les Jones 1 |
John McNamara | 28/08/2018 00:22:18 |
![]() 1377 forum posts 133 photos | Hi Alan My lathe did not come with spindle taper plugs I made two, one Morse and one NC taper at the same time. I did not use a chuck or centres. I posted posted the method here here a while back. Regards
Alan Waddington 2 | 28/08/2018 14:16:29 |
Posted by John McNamara on 28/08/2018 00:22:18: Hi Alan My lathe did not come with spindle taper plugs I made two, one Morse and one NC taper at the same time. I did not use a chuck or centres. I posted posted the method here here a while back. Regards Great Job John, thanks for posting.......however i seem to be getting further from the job in hand evey time i go in the workshop, so this time i will be buying rather than making. No idea if it’s just me, but nearly every job i do requires me to either make or buy something to fix an issue before i can start the job i initially wanted to do. |
Simon Williams 3 | 28/08/2018 19:45:10 |
728 forum posts 90 photos | Alan - I've sent you a PM. Rgds Simon |
Alan Waddington 2 | 31/08/2018 14:11:13 |
537 forum posts 88 photos | Just to update this thread, Simon kindly sent me the bush he had, and it fitted perfectly. (Thanks Simon)The taper is indeed 5mt, but the fat end is larger than a drill sleeve so it sticks out of the headstock a little way. I therefore have a bush going spare. (My ebay purchase) So if anyone can identify it, and make use of it, the same deal as Simon did for me will apply. Let me know your address and i will post out at my cost. If it suits your needs, you make a minimum donation to charity of £10 If it does not fit, you return to me, or someone else who’s machine it may fit. These tend to be advertised between £30 and £70 on ebay Edited By Alan Waddington 2 on 31/08/2018 14:12:17 |
Richard - | 14/02/2019 22:21:12 |
62 forum posts 7 photos | Hi Alan, have you still got the bush, my Harrison is reported to be 41/2 MT thanks Richard |
Alan Waddington 2 | 14/02/2019 23:07:03 |
537 forum posts 88 photos | Posted by Richard - on 14/02/2019 22:21:12:
Hi Alan, have you still got the bush, my Harrison is reported to be 41/2 MT thanks Richard Hi Richard, yes still on a shelf, PM me your address and i will send it to you. |
Pete Rimmer | 14/02/2019 23:40:04 |
1486 forum posts 105 photos | Without drawing it up in CAD your adapter sound awfully close to #13 Jarno taper. |
David Standing 1 | 14/02/2019 23:58:34 |
1297 forum posts 50 photos | Posted by Pete Rimmer on 14/02/2019 23:40:04:
There are three different bush sizes referred to in this thread, which one are you referring to? |
Richard - | 15/02/2019 08:30:38 |
62 forum posts 7 photos | Alan sent pm |
Howard Lewis | 15/02/2019 10:47:44 |
7227 forum posts 21 photos | Jarno tapers all have the same taper, 2 degrees 15 minutes. A 5MT / 3MT sleeve should be available from someone like Warco or Chester, since the BH600 and Craftsman are 5MT Mandrels, and came with a sleeve. Possibly, some of their successors did as well. Howard |
Pete Rimmer | 15/02/2019 13:00:33 |
1486 forum posts 105 photos | Posted by Howard Lewis on 15/02/2019 10:47:44:
Jarno tapers all have the same taper, 2 degrees 15 minutes. Howard Are you sure? I'm no Rachel Riley but I get 2.8664 degrees included angle. |
Howard Lewis | 15/02/2019 17:23:54 |
7227 forum posts 21 photos | Peter! Quite right Taper according to Engineers Edge is 1;20 which I make 2.8624052 degrees (2 degrees 51.44314 minutes) Shouldn't have relied on my memory, from the last time that I turned one! Howard |
