Motor re-build problems
Keith Wood 1 | 18/07/2018 14:51:59 |
16 forum posts 1 photos | After many years of good service, the DC motor on my X2 mini mill started its periodic popping and arcing. Upon stripping the motor I found the commutator grooved so I skimmed it in the lathe, after finishing the clean up I noticed that there was no meat left for another future skim. I purchased a brand new armature and installed it in the old casing, installing a new set of carbon brushes. After re-installation and power on I noticed that the motor ran up to speed well but was not stable speed wise, also there is no torque on start up and minimal torque during running. I re-installed the old cleaned up armature in order to troubleshoot and there is plenty of torque and the speed is stable. I checked the new armature with a multimeter, the 180 degree check between segments shows good. The adjacent segment check shows good and the individual segment to laminates shows good. Anybody any ideas. I have since purchased a new motor and will keep the old motor with skimmed armature as a spare. Thanks Keith Wood Montreal |
John Haine | 18/07/2018 15:11:31 |
5563 forum posts 322 photos | Presumably your mains is 110 V? Maybe they've sent you a 220 V component? |
Keith Wood 1 | 18/07/2018 15:20:12 |
16 forum posts 1 photos | John Yes, mains supply is 110v. The armature was supplied by a supplier in the US and I believe all the motors use around 90vDC supplied from the controller. Maybe you are correct. Regards. Keith
Neil Wyatt | 18/07/2018 15:25:32 |
![]() 19226 forum posts 749 photos 86 articles | My UK X2 has a motor plate that reads DC 230V. Neil |
Keith Wood 1 | 18/07/2018 15:29:05 |
16 forum posts 1 photos | Neil I think you have clarified the situation. Maybe the armature manufacturer sent the incorrect ones to my supplier. I will relay this information to them. Best regards. Keith Wood |
John Rudd | 18/07/2018 17:03:33 |
1479 forum posts 1 photos | Posted by Keith Wood 1 on 18/07/2018 14:51:59:
After re-installation and power on I noticed that the motor ran up to speed well but was not stable speed wise, also there is no torque on start up and minimal torque during running. I re-installed the old cleaned up armature in order to troubleshoot and there is plenty of torque and the speed is stable. I checked the new armature with a multimeter, the 180 degree check between segments shows good. The adjacent segment check shows good and the individual segment to laminates shows good. Anybody any ideas. Thanks Keith Wood Have you compared the dc resistance between the two armatures? |
Dave Shield 1 | 18/07/2018 17:27:36 |
33 forum posts 6 photos | Had problems like that on a washing machine. The brushes were floating off the armature when the motor was ramping up. Dave Shield |
