Malcolm Harvey | 27/06/2018 19:34:05 |
![]() 30 forum posts 1 photos | I am not particularly a beginner but I thought I would ask this question here as it is likely something that every beginner should know. I have turned a set of wheels for my 3½G Titfield Thunderbolt but I have casting flash between the spokes (of course). I have tried filing this out with swiss files but they clog almost immediately. Does anyone have any suggestion as to what would be the best tool to use for this job? TIA Malcolm |
Weary | 27/06/2018 19:47:57 |
421 forum posts 1 photos | Dremel - or similar - with carbide burrs. (Plus tight-fitting goggles as abraded cast-iron mini-granules get everywhere!)
Regards, Phil |
Jim Nic | 27/06/2018 23:28:48 |
![]() 406 forum posts 235 photos | +1 for a Dremel Jim |
vintagengineer | 27/06/2018 23:52:31 |
![]() 469 forum posts 6 photos | Rub chalk on the file and use a file card to clean the file. |
Baz | 28/06/2018 08:35:29 |
1033 forum posts 2 photos | In my very humble opinion a much better way to clean a file is to use a piece of brass or a fine brass wire brush. |
roy entwistle | 28/06/2018 08:41:28 |
1716 forum posts | Baz The chalk is not to clean the file it's to stop clogging. Definitely a bit brass or copper for cleaning Roy |
Chris Evans 6 | 28/06/2018 08:45:13 |
![]() 2156 forum posts | What "Cut" is your file ? I use "O" cut for those sort of jobs. |
Michael Gilligan | 28/06/2018 09:07:33 |
![]() 23121 forum posts 1360 photos | For small areas of 'casting flash' I have found that diamond 'needle files' work better than conventional ones. A few years ago, this would have seemed an extravagance; but the availability of [cheap & cheerful] sets from the likes of Aldi and Lidl has changed my approach. MichaelG. |
Bazyle | 28/06/2018 09:07:47 |
![]() 6956 forum posts 229 photos | Posted by Baz on 28/06/2018 08:35:29:
In my very humble opinion a much better way to clean a file is to use a piece of brass or a fine brass wire brush. Only really works for single cut files. |
Malcolm Harvey | 28/06/2018 14:22:47 |
![]() 30 forum posts 1 photos | Thanks for the input. Learnt a bit! Never heard of putting chalk on a file to stop it clogging, Never have thought of using a Dremel and I hadn't heard of diamond needle files. I have just looked in Boyes and they have pack of 5 for £4 or thereabouts. Malcolm |
mechman48 | 28/06/2018 15:21:04 |
![]() 2947 forum posts 468 photos | +1 for the Dremel approach. I also use a rough 2nd cut to get under the meat of the flashing then titivate up with Dremel & carbide bit. Edited By mechman48 on 28/06/2018 15:21:37 |
