Stephen Follows | 25/06/2018 11:43:41 |
![]() 119 forum posts 3 photos | I am building a stationary mill engine with a 1/4" copper steam feed. I want to fit a displacement lubricator with a single pipe fitting. the only ones I can find have 1/4 x 40 fitting for 1/8" pipe. The way round this, I suppose, is to fit a reducing tee in the 1/4" pipe but I can't find one of those either. I'm sure others out there have fitted lubricators on 1/4" pipe. Did you find a suitable lubricator or did you get round the problem somehow? |
Thor 🇳🇴 | 25/06/2018 12:58:30 |
![]() 1766 forum posts 46 photos | Hi Stephen, Is it something like this or this you are looking for? Would it be possible to fabricate from bronze and silver solder? Thor |
Paul Lousick | 26/06/2018 14:32:20 |
2276 forum posts 801 photos | Hi Stephen, I did a quick search for a solution to your problem and drew a blank. As you have said 1/4"x40 fittings on the small lubricators have a 1/8" tube connection and could not find a 1/4"x1/8"x1/4" tee either. Instead of a reducing tee from 1/4" to 1/8" tube, just fit the small tube into the bigger one and solder together. Then use a standard 1/4" tee. Paul. |
JasonB | 26/06/2018 14:38:41 |
![]() 25215 forum posts 3105 photos 1 articles | Buy a tee for 1/4" pipe and then make a custom nipple the outside size of one for your 1/4" tee and rather than drilling to take 1/4" pipe just drill it for 1/8" pipe. or just sleeve down the 1/4" nipple. Simples |
